Like Tree5Likes
SC10 4x4 Thread
Old 11-22-2012 | 06:51 AM
  #31291
MantisWorx's Avatar
Originally Posted by ryanpatrickgore
drop test.....
with the old shocks the chassis slapped the table (loudly)
with 1/8 shocks no slap on the table at all, just soaked it up
simple as that. dont know how it drove but it is more plush, that is for sure
But you cant compare the two when the oils and piston holes are not the same. now if you tell me that you have 8 hole pistons and 30wt on both sets of shocks then i would take the test more serious. And like Shaun just said dropping your truck 3' is a motion that will never be replicated on the track so really means nothing. Changing anti squat will effect that test, front kickup and shock positions make differences also. landing with your finger on the throttle can also make a difference versus not.
Comparing stock B4 shocks to the new 12mm shocks and then thinking that going from 13mm to 16mm is going to make the same difference is skewed too! 10mm shocks were and have always been undersized from the get go so of course when you put a proper sized shock on a B4 its going to make a huge difference but the 13mm SC10 shocks are not undersized. If that were the case then the next step in 1/8 scale would be 18mm! it has been proven that even 17mm is borderline too much on an E buggy so 16mm on a super light weight truck is overkill. They will work and i am sure that in some situations may even thrive. Think about what you are actually doing, no matter what size your shocks the oil has to flow through the piston holes. The SC10 shocks have a pretty good amount of volume to them compared to most and we all know they work very well. Just food for thought before everyone goes out and buys 16mm shocks.
BTW UFO pistons are in the final stage for 12mm, pre-order starts next week. SC10 4x4 sets will be ready in three weeks or so. I havent said too much about them but I have been doing LOTS AND LOTS of testing so that they will be perfect. In a nutshell (more will be explained on the video) the thinner the piston the faster oil flows through the holes and vice versa. UFO pistons are thick and utilize 2 large holes ( but are spot drilled for 3 and 4 hole options). The results are a piston that allows the use of light fluids but give a "super pack" on hard landings and a plush pack for the med/small jumps and obstacles. Rebound is slightly faster by design since the pack is dynamically increased. Basically a piston that is tailored for the indoor hard fast track crowd!! Driving impressions have been great, the plush pack is most notable on jumps where you have to land and immediately turn and rhythm sections. They dont jump as high or far as 2 stage but sometimes I have found that on large jumps i tend to over jump with the 2 stage since the rebound is so much quicker.
Another major plus is that these piston cut down shaft stiction DRAMATICALLY!! since the pistons are thick and have two contact points this keeps the shaft straight and pressure off of the orings resulting in a better seal, less shaft wear (nitride wearing off) and overall smoother action. Normal pistons only have the piston contact point and the oring so as your shocks go up in travel pressure is put on the upside of the shaft...not anymore!!
MantisWorx is offline
Old 11-22-2012 | 07:36 AM
  #31292
ryanpatrickgore's Avatar
i agree with you guys about the test, a car never lands like that in real life. just wanted to say it was more plush looking on the table.
hope it works out as it sure looks cool
ryanpatrickgore is offline
Old 11-22-2012 | 09:03 AM
  #31293
CraigMBA's Avatar
Not to troll George (or anybody else) but I think he's onto something. And it's not the shocks; it's the springs.
CraigMBA is offline
Old 11-22-2012 | 09:07 AM
  #31294
MantisWorx's Avatar
That would make more sense to me, there is alot of "gray" area with springs. As soon as i get a chance i am going to make a spring tester to try and figure it all out!
Old 11-22-2012 | 09:43 AM
  #31295
Wild Cherry's Avatar
Ryan , the drop test is now stupid ?
and ...... me coffee just went down wrong pipe, C-On !
So what my truck now lands like a cat on a cloud..
Ask anyone how much better their B4 improved with the addition of the 12mm BB shocks ....
This 16mm BB shock mod is the same thing for the Sc10 4x4 ....
BK has 16mm springs on his , don't tell me you guy's didn't see this shock mod coming ....
Wild Cherry is offline
Old 11-22-2012 | 09:52 AM
  #31296
I'm the guy that posted the first chassis brace , 8mm camber mod & now the 16mm BB shock mod ...
I like having fun & sharing it with all ...
No put downs , no calling outs , just respect & polite...
Old 11-22-2012 | 09:58 AM
  #31297
fq06's Avatar
Other than putting words in Ryan's mouth (drop test is "stupid")
fq06 is offline
Old 11-22-2012 | 09:59 AM
  #31298
Cain's Avatar
Come now WC, do you really want to go there?
Cain is offline
Old 11-22-2012 | 10:03 AM
  #31299
i scored 1 set of BBs off of ebay last nite, bidding on a second pair now. worth trying... Don't we just all want to go faster? Whether it's .1 better per lap or landing the fat jumps easier...
Besides, I like tuning and monkeying with my trucks as much as driving them...It's my stress reliever after the wife and kid are in bed...
maddysdaddy is offline
Old 11-22-2012 | 10:05 AM
  #31300
symmetricon's Avatar
Put some losi LST shock on it, it would be very very plush! LOL
symmetricon is offline
Old 11-22-2012 | 10:07 AM
  #31301
Cain's Avatar
shh.. 5ive-T shocks!
Cain is offline
Old 11-22-2012 | 10:12 AM
  #31302
Maddy , Thinking 16mm are not any faster..
But they are way more consistent and you should make fewer mistakes, specially on the jumps & landing's...
Still a work in progress , only got to run a a pack & 1/2 last night before I striped a servo horn running up on a novice too fast ..
Where we are at right now ...
Shocks still have bladder's inside ...
The front shocks still are not quite going with the program as well .
A few more refinements to come ....
  #31303
Oh yeah!
we are just pickin on ya WC, nothing personal
Old 11-22-2012 | 10:54 AM
  #31304
No worries WC, I know they won't actually add speed...
At best, I like 'em and sell my 13mms. At worst, I resell the 16s, and lose a little money but learn a bit in the process. Big whoop. Then I buy MWorx's yoyo pistons....
Old 11-22-2012 | 06:11 PM
  #31305
CraigMBA's Avatar
The "gray area" with springs is the only rate that matters is the wheel rate when mounted in the car. Then, it's only valid vs the other springs you test. The variances between batches can be disturbingly large.
CraigMBA is offline
