The AE FActory Team B44.2 Thread >
Old 11-11-2012 | 06:47 AM
  #556
UN4RACING's Avatar
BTW.... I would in hind sight start with a your current .1 set ups and work with that, You will most likely find it to feel 8+ mm's more stable. With mine all it felt like all it needs is some weight in the rear.
I built mine box stock for heck of it just to see if it was any good on our track. And was not to bad, but it was easier to feel the difference with my set up from the .1 and I did feel a difference. It sure does feel stretched out...LOL
UN4RACING is offline
Old 11-11-2012 | 09:23 AM
  #557
cantrell8's Avatar
Originally Posted by UN4RACING
Tighte
I am highly sold on the slipper.
I learned last night you can mod the pads for more or less bias front and rear slipping. Its as simple as thinner or thicker pads front to rear pads. I am going to need some time to figure this out...LOL.
how it this possible?
cantrell8 is offline
Old 11-11-2012 | 09:25 AM
  #558
Wildcat1971's Avatar
Tech Prophet
it is decoupled?
Wildcat1971 is offline
Old 11-11-2012 | 10:27 AM
  #559
Wild Cherry's Avatar
Think by making one pad smaller than the other ...
OMW to TRCR
Wild Cherry is offline
Old 11-11-2012 | 10:39 AM
  #560
kdub's Avatar
Hi guys...The answer is that you're right. It's not possible. The 2 drive cups are both locked to the center shaft. The slipper is not de-coupled so you can't adjust front/rear bias.
kdub is offline
Old 11-11-2012 | 10:57 AM
  #561
UN4RACING's Avatar
Your right. I was told last night that you could trim out the slipper pad and such. This was a SC truck racer. You make a the point clear ir just wont work. Though I hadn't gave a shot or thought.
Old 11-11-2012 | 04:19 PM
  #562
rigor's Avatar
Finished my 44.2 build. Too pretty not to take some pics of it!
I'm probably going to yank the blue anodized center bulkhead & cap out of my 44.1 to replace the now plastic pieces included with the 44.2 . I don't mind AE no longer including anodized aluminum fr/rr shock tower mounts, as I feel the plastic versions allow for more flex anyway, preventing shock tower breakage.
3rd pic shows that I replaced the blue aluminum shock bushings with plastic ones. The small gold AE 4-40 nuts are just the right spacing (about 2.8mm) to keep the mounting angle the same as the included aluminum bushings.
4th pic shows that I remembered to lay down black duct tape underneath the battery mounting areas. If you don't do this, you will scratch up the nice glossy carbon fiber (wish I had known before it was too late with my 44.1).
I also did not mount the front body mount, and shaved the rear body mount. Will lay down velcro on those two areas and along the side of the new battery trays.
And I will NOT miss dealing with those thumbscrews!
Attached Thumbnails The AE FActory Team B44.2 Thread-img_6384.jpg   The AE FActory Team B44.2 Thread-img_6400.jpg   The AE FActory Team B44.2 Thread-img_6366.jpg   The AE FActory Team B44.2 Thread-img_6371.jpg   The AE FActory Team B44.2 Thread-img_6372.jpg
rigor is offline
Old 11-11-2012 | 05:32 PM
  #563
aeRayls's Avatar
Ae never included the fr/rr alum shock tower mounts.
Pretty sure the alum bulkhead cap from the 44/44.1 will not fit the 44.2
aeRayls is offline
Old 11-11-2012 | 05:45 PM
  #564
rigor's Avatar
My bad, I made an assumption. I bought my 44.1 very lightly used and it came with a ton of extras.
I'll see about the aluminum bulkhead later tonight and post what I find out.
P.S. aeRayls are you in Socal (WCRC / OCRC / etc) ?
rigor is offline
Old 11-11-2012 | 06:35 PM
  #565
aeRayls's Avatar
Nope, I was there for supernats at wcrc. I'm from Indiana
aeRayls is offline
Old 11-11-2012 | 06:43 PM
  #566
rigor's Avatar
Right on. So you were inside that sauna as well. Nothing like SoCal August with a heat wave to boot!
I'll be installing electronics and breaking in the diffs soon, and hope to finally run this 44.2 sometime this coming week!
rigor is offline
Old 11-11-2012 | 07:47 PM
  #567
keidel's Avatar
Default A arms
Since breaking a left front a arm I have dropped the axle out twice now without popping a ball cup. I replaced the arm with a old one I had new in package from my b44.1 could it be that the new arms are stiffer with the reinforced webbing on the arm. Or just bad luck don't remember having too much trouble with old car. I will get the new arms when available but since its the same part # it's not that easy.
keidel is offline
Old 11-11-2012 | 09:11 PM
  #568
UN4RACING's Avatar
Check your droop if its popping out. I doubt we will see the new ones till we break enough old ones....
Old 11-11-2012 | 09:16 PM
  #569
UN4RACING's Avatar
I put some of the furry side of the velcro inside the outer part of the battery holder to make the battery snug side to side, I am running the Reedy 5200.
Old 11-11-2012 | 11:47 PM
  #570
anyone got any building tips for 44.2 ?
also do AE make 12mm front hex wheel for 44.2?
Jarred King is offline
