RC10B4.1 FT/WC
Old 11-05-2012 | 08:37 AM
  #23506
MikeXray's Avatar
What pistons are compatible with the B4.1 shafts? I'm thinking losi based on my searches, but I want to be sure. I see some running the ghea, are the BB ones the same as the 22 or kyosho? thanks.
MikeXray is offline
Old 11-05-2012 | 08:54 AM
  #23507
guys tried the old Losi pistons (XXX shocks) in the V2 shocks. Not sure about the BB stuff though.
Bob Barry is offline
Old 11-05-2012 | 08:59 AM
  #23508
turbo2cam's Avatar
Originally Posted by Waflet
Hideeho
From experience, I can tell you exactly what that is. You are running the avid or jc bell cranks & hit something. This cracked the top of the case where one of the pins that holds a gear stack goes in a hole. If you have it on & move the servo horn, it will move just a little bit while it is sitting @ rest. This causes the servo to bounce back & forth as it tries to find center. If it is under warranty, send it in & then sell it. If they won't fix a 6 week old servo, I'd buy a case & then sell to switch to a different brand. It will break in the same place again. I went through 3 cases for a jr 9100s before giving up on it & getting a radiopost red (this for my agama, but it also broke the case in the b4.1xl with the avid bell cranks). I have had no problems out of my Savox 1258 with the avid cranks.
Oops, this is what happens when you don't read through before responding. See above
exactly what happened to me on my sc10 with avid bellcrank, and also on my sons b4.1 with glued stock bellcrank. and yea, both of us running Savox's now with no issues so far.
turbo2cam is offline
Old 11-05-2012 | 09:07 AM
  #23509
Wild Cherry's Avatar
Originally Posted by CraigMBA
The smoothness in the diff is a result of the thrust bearing. Anyone whos raced 1/12th scale has lost that outer bearing from a hard hit and knows what I'm writing about. That said, I can't get two race days out of a set of carbide balls before mine are shot.
AE doesn't make ceramic thrust balls, how would you know they don't work George? Don't you only run only AE stuff?
The ceramic balls literally last forever if you don't lose one. Mine have been in my SC10 for a year and a half. I ordered them from John Russo, was $9.65 for thrust and diff balls - delivered!
You can use those ceramic thrust balls , never said they don't work...
Last night ?
I reused my stock Ae thrust after I wore out the diff & out drives .
Pulled it out , did not even clean and slap it back in a new set of out drives ...
Diff came out smooth as silk ...
That is after reusing the same stock thrust again !
And
Now ?
That same thrust is going for another tour ...
Just saying ......
The stock thrust does not wear very much , if at all.
Can be reused over & over ....
This is the reason why I suggested save the money , you really need to use ceramic thrust balls ....
PS Craig
my B4 ride pimps
RPM ball cups
AVID TRIAD slipper
AVID springs
Jconcepts silent spur
losi pinion
AVID steering rack
Stainless steel screws , don't even know who makes um ..
So when you tell everyone I only use Ae parts ?
Your wrong again...
Wild Cherry is offline
Old 11-05-2012 | 09:18 AM
  #23510
Tradin Paint's Avatar
Last night ?
And
Now ?
Just saying ......
PS Craig
my B4 ride pimps
RPM ball cups
AVID TRIAD slipper
AVID springs
losi pinion
AVID steering rack
Your wrong again...
How do you run the Avid slipper and the JConcepts spur gears?
Tradin Paint is offline
Old 11-05-2012 | 09:35 AM
  #23511
Wildcat1971's Avatar
Tech Prophet
magic
Wildcat1971 is offline
Old 11-05-2012 | 09:38 AM
  #23512
sorry , was using the JC silent , but just install my Traid a week ago ...
have Traid on my B44 for about a month
Old 11-05-2012 | 09:44 AM
  #23513
my B4 ride pimps
RPM ball cups
AVID TRIAD slipper
AVID springs
losi pinion
AVID steering rack
Your wrong again...
EWWWWWW
RPM ball cups
Old 11-05-2012 | 10:00 AM
  #23514
Bob , Their great ...
Tighter , stronger & smoother then the Ae cup ...
Perhaps the best ball cup you can buy for your B4.....
Old 11-05-2012 | 10:07 AM
  #23515
idrummerboy13's Avatar
the stock ones i liked the best. Rpm ones look crappy quicker. concepts pop off a lot from what I see....
idrummerboy13 is offline
Old 11-05-2012 | 10:16 AM
  #23516
Default Anyone using this rear hub set?
Anyone using this? How does it work for you?
http://www.amainhobbies.com/product_...inum-Hub-Set-2
shagnat is offline
Old 11-05-2012 | 10:17 AM
  #23517
cantrell8's Avatar
geo, look again, you got the vts on your 2wd.
cantrell8 is offline
Old 11-05-2012 | 10:23 AM
  #23518
B.A. Racer's Avatar
smoother? i agree with stronger and tighter but they do bind a small bit.
B.A. Racer is offline
Old 11-05-2012 | 11:46 AM
  #23519
sunco1's Avatar
What should I change when going from low/med bite clay to high traction carpet? I know small pin tires in the rear are the hot ticket usually, what about the front: ribs or pins?
sunco1 is offline
Old 11-05-2012 | 11:52 AM
  #23520
We run an astro/RCP mix for off-road, and Schumacher mini pin rears and Stagger rib fronts are the hot ticket ( yellow compound.)
Rocky8333 is offline
