RC10B4.1 FT/WC
Old 10-07-2012 | 03:10 PM
  #21721
LOSI123's Avatar
Originally Posted by CHIZZLE
According to the Hudy Off Road Book, using the lower holes on the shock tower gives you a higher roll center and vice versa.....
http://www.google.com/url?sa=t&rct=j...itOz-YSkLml4iw
This is only true providing that the outer upper link point is not moved at the same time.
LOSI123 is offline
Old 10-07-2012 | 03:13 PM
  #21722
ryanpatrickgore's Avatar
Originally Posted by 3srcracing
Well need oppinon.
Should I get BB from rear only/front only, or get Traid Slipper?
Get both front and rear shocks at the same time.
Just keep saving for them
ryanpatrickgore is offline
Old 10-07-2012 | 03:19 PM
  #21723
CHIZZLE's Avatar
Originally Posted by Eli
OptimumRC and I are at an agreement on that lol.
Right. I had to re-read what you guys were saying. Oh well, I'm still confused, lol. I'm trying to grasp the diagram.
CHIZZLE is offline
Old 10-07-2012 | 03:49 PM
  #21724
Sorry for the silly question (I did look around but couldn't find an answer), but where/how do you attach weights on the triangles?
NicolasCH is offline
Old 10-07-2012 | 03:58 PM
  #21725
YankeeFan123's Avatar
You could use double sided tape but for me I used tire glue since I never remove them
YankeeFan123 is offline
Old 10-07-2012 | 04:01 PM
  #21726
Originally Posted by slimgravy
He has ½°rear camber listed and could not be worse lol. Car was so loose it wasn't drivable at all. Went to 1° or a lil more and I can slam it hard into a corner and its stuck.
yeah I have about 1-1/2 my self and it feel a bit more planted through the corner.......
But sometimes its a little loose when the boost comes on, on the straightaway!
Jason Snyder is offline
Old 10-07-2012 | 04:41 PM
  #21727
3srcracing's Avatar
Well it would take me awhile to get it online. I have like $37 to spend. Any ideas what to get? {Aside from track time}
3srcracing is offline
Old 10-07-2012 | 04:43 PM
  #21728
1armed1's Avatar
Holy smokes, a slimgravy sighting.
You back to racing or just playing a bit?
How bout paint slingin?
Dayton
1armed1 is offline
Old 10-07-2012 | 04:50 PM
  #21729
savannahmick's Avatar
I have been racing 17.5 SCT and Nitro Buggy for two years with good results but decided to give 2wd buggy a shot. I bought a B4.1 FTW from a pro who ran it once at Nats it had all the good Avid gear 12mm collars/Triad/alum. steering also has Losi BB spring sets. Anyway can someone help me out with a decent starting setup with 10mm v2 shocks and Losi 12mm bb springs? I went out today for some laps but rear grip was not there really I am running m3 Calibers on outdoor with a little dust had yellow rear springs and red front springs not sure about shock weight. I have got my 2wd SCT dialed and ran better laps with it so I know it's in need of a setup change/rebuild. Looking for any suggestions I have searched but get so many unrelated answers. Also foams I trimmed mine down to round edges but have a few soft spots in tire. One more thing the diff feels a little bumpy when I rotate wheels opposite how smooth should it feel? Thanks!
savannahmick is offline
Old 10-07-2012 | 05:03 PM
  #21730
ovalracer1m's Avatar
I would get rid of the calibers and rebuild the diff. The diff should feel smooth with out a gritty feel. Should feel absolutely smooth. 2wd buggies are VERY diff sensitive. I have never felt calibers on any track has been the "fast" tire to run. If the surface is loose/dusty, maybe double dees, ifmar pins, maybe 3ds. look at what the fast guys are running in 2wd as well. I would bet 95% of the problem you are having is tires and the diff.
ovalracer1m is offline
Old 10-07-2012 | 05:25 PM
  #21731
JEFFs SC10's Avatar
Someone please give me honest advice.
A b4.1 WC edition with big bores will be better/same/equal than a TLR 22?
Have you any of you first hand driving both. I had a b4.1 but regretfully sold it. Now I want one again LOL.
JEFFs SC10 is offline
Old 10-07-2012 | 05:31 PM
  #21732
Originally Posted by fullsyzz
Amain!
It has won nearly every race for the last several years, including the worlds. Where is the debate? They are both clearly very fast and capable cars.
Kave is offline
Old 10-07-2012 | 05:42 PM
  #21733
JEFFs SC10's Avatar
Ok good point, but I think driver plays a big part in winning races as well.
Old 10-07-2012 | 05:50 PM
  #21734
ilanstylz's Avatar
Well considering in my area of socal even at the club level the b4.1 is very dominant , its still one of the best buggy's and even better now with the big bores..........
ilanstylz is offline
Old 10-07-2012 | 06:05 PM
  #21735
JEFFs SC10's Avatar
what's up ilian! I'm running a SCTE now, got ride of the sc10 4x4 this wknd.
I have located a deal from a local racer, trying to see if it is still available.
id def put on the big bores, avid stuff, etc.
