Tekno RC EB48 Thread >
Like Tree2Likes
Old 10-04-2012 | 10:28 AM
  #2776
ChrisAttebery's Avatar
The plate will weigh less than 1/2 oz. I'm not sure what the Tekno part weighs but even if it weighed nothing you could easily adjust the battery to compensate. Most guys are running the packs full forward to get more on power steering anyway.
Originally Posted by papymini
If some drivers balast the front of the EB48, they can stop with these parts:rolleyes
What weights ???
ChrisAttebery is offline
Old 10-04-2012 | 10:29 AM
  #2777
The Ackerman and Skid plates are now available for pre-order at: http://www.ape-rc.com/#ecwid:categor...=0&sort=normal
Thanks for the great response!
Chris
Old 10-04-2012 | 10:51 AM
  #2778
Chris
Thanks you for making quality stuff like this available to us so quickly!
MX304 is offline
Old 10-04-2012 | 12:21 PM
  #2779
teknorc's Avatar
Default Option parts in stock
http://www.teknorc.com/2012/10/04/ne...-for-the-eb48/
Steel spurs, complete brake kits, complete shock kits, aluminum steering posts are all in stock now.
We also got our revised Ackerman plates from the factory today.
teknorc is offline
Old 10-04-2012 | 02:00 PM
  #2780
G SquareD's Avatar
Questions??
Originally Posted by teknorc
Options.
I think only one of us is running the rear brace right now. There are 3 braces on the car. One front brace (always recommended), a center diff brace (optional) and a rear brace (optional). You can tweak the flex to your liking. The best combo so far is front and center, no rear, but I want to test front/rear, no center a little bit more.
BTW, we will have setup sheets available at launch! We plan on releasing 3 setup sheets that you can start from. Basically a setup that pushes slightly (easier to drive), a balanced setup (recommended), and an aggressive (MAJOR steering) setup.
One of the things we found is that the car is very responsive to setup changes and you can really tune it to your individual driving style. You can setup for tons of traction or tons of steering and it's easy to adjust that bias to your driving.
But, the car doesn't just push OR steer. During testing, we drove dozens of other 1/8th scales back to back with ours to see what was working on other cars. Where were the other cars beating us. Did they steer better off power? Did they stay flatter in the corners, etc.. What we wanted to do was to beat every car in every category. That's not always 100% possible since a gain in one attribute usually results in a loss somewhere else. But when you combine the features, weight, suspension geometry, etc we've come very close to having a setup that is better in almost every way than the conversion we've been driving up to this point.
Hi Danny
You mentioned in this post that Tekno would post 3 "guide" setup sheets with a pushes slightly setup, balanced setup and aggressive setup. I see the Team Driver & User Subs, but are there still plans to submit the "guide" setups? I think this will help a lot of people with a good starting point and tune from there.
Thanks!
G SquareD is offline
Old 10-04-2012 | 02:28 PM
  #2781
teknorc's Avatar
Originally Posted by G SquareD
Hi Danny
Thanks!
Well, we'd still like to do that, but it seems we're still tweaking and I'm not sure that having 3 completely separate setups is a good idea anymore. I think what we'll end up doing is have our base and then in the notes section we'll list a couple things to make it more or less aggressive. This way, customers won't have to cross-reference and compare the different setups to see what to change to do what. We're going to need some more time with this and it will evolve.
teknorc is offline
Old 10-04-2012 | 02:37 PM
  #2782
The EB48 jumps well. Check out the blue buggy at the 1:05 mark. It was after the race was over so I gave the big jump a shot.
Tekno jumps at 1:05
sstoffer is offline
Old 10-04-2012 | 02:54 PM
  #2783
G SquareD's Avatar
Thumbs up
Tekno jumps at 1:05
NICE!!! Now that's what u call BALLS to the WALLS!!!
GO TEAM TEKNO!
Old 10-04-2012 | 03:03 PM
  #2784
justpoet's Avatar
Fun watching the orange car try and fail to do the same thing shortly after too.
justpoet is offline
Old 10-04-2012 | 03:54 PM
  #2785
GO TEAM TEKNO!
No joke. The ceiling was almost the limiting factor there.
MX304 is offline
Old 10-04-2012 | 06:21 PM
  #2786
Steel spur, outdrives and couplers ordered!
Old 10-04-2012 | 06:39 PM
  #2787
Tekno jumps at 1:05
If you hadn't hit the door release cord, you might have stuck the landing!! Awesome
rcmiket is offline
Old 10-05-2012 | 12:19 AM
  #2788
Outtacontrol58's Avatar
Do the shorty packs stacked on top of eachother make contact with the body? Also what are the pros/cons to this setup as opposed to a normal stick pack. Also what kind of runtime can i expect from dual 4100mah shortys with a 2100kv motor? Thanks!!
Outtacontrol58 is offline
Old 10-05-2012 | 04:05 AM
  #2789
superslow's Avatar
Think the lightweight driveshaft would help at all?
superslow is offline
Old 10-05-2012 | 04:12 AM
  #2790
1fastdude's Avatar
Trying to place an order today and the Ackerman plates shows as out-of-stock?
1fastdude is offline
