RC10B4.1 FT/WC
Old 09-07-2012 | 08:10 PM
  #20026
B.A. Racer's Avatar
Originally Posted by bilster44
No shaving needed...
Just a 2mm spacer
B.A. Racer is offline
Old 09-07-2012 | 08:48 PM
  #20027
RC_nooberton's Avatar
I found out that my local track runs a 13.5 2wd buggy class. The track is a small to medium sized, medium to high grip indoor clay track. According to the RC10B4.1 manual, I should start with a 28/75 gearing. I run a Brushless Hobbies 120 amp ESC and a 13.5 Hobbywing that doesn't have end bell timing. So based on this, can someone give me a starting point as far as ESC settings go?
Anyone else run this ESC?
Thanks for the continued assistance!
RC_nooberton is offline
Old 09-07-2012 | 10:52 PM
  #20028
Barrett50.cal's Avatar
Originally Posted by rigor
Yo Copeland do you know if Hartson has already had these new shock towers all this time ? When I've looked at his car at OC_RC, it looked like the towers were fine (granted I was looking at the shocks & springs far closer than the towers).
These pics of Maifield & Denny's cars from the Hotrod Shootout don't look like mangled shock towers either
Jesse H.
http://blog.jconcepts.net/wp-content...ifield-2wd.jpg
http://blog.jconcepts.net/wp-content.../07/Denney.jpg
the rear tower doesnt look like the current one
Barrett50.cal is offline
Old 09-07-2012 | 11:17 PM
  #20029
Originally Posted by Atomicsickness
Looks cut pretty good to me.
Its about the same amount as we had to do with the RB5 when we mounted bog bores on them. a 2mm spacer seems to allow the front shocks to clear without grinding so much off the front tower, the rear tower either needs a new mounting system, or a new tower. Shimming will not work as it will just cause the springs to grab on the rear camber link and thats a big problem. It does not work right with the components that will come with the production big bore shocks most noticably the aluminum cap and spring load collar.
jpcopeland1 is offline
Old 09-07-2012 | 11:26 PM
  #20030
STLNLST's Avatar
Shimming properly gives clearence to the rear camber link.
STLNLST is offline
Old 09-07-2012 | 11:27 PM
  #20031
Originally Posted by ilanstylz
You know I never thought of that but it makes perfect sense. I can't remember how many times I've change out my front rims at home or the track and had a bearing or two get away from me only to go rolling all over the place and me chasing after it. Not a good sight for a big guy to be crawling on the ground looking under pit tables lol.....
I think AE did it just for convenience, and the ability to usew aftermarket rims since AE still does not have rears out. I will tell you one thing though, Losi rear rims are brittle. First day I had them, no crashed, no punts from other drivers and still had one crack on me. Changed to Pro-Line and JConcepts and have not had those issues. Losi drivers down here complain alot about the brittlness of their wheels (and leaky a** shocks) lol.......
Old 09-07-2012 | 11:31 PM
  #20032
Originally Posted by STLNLST
Shimming porperly gives clearence to the rear camber link.
The shocks you saw were using the old style pivot ball with eyelet or the new style which are slightly longer and eyelet is not just a round ball anymore and is spaced further out for the shock to clear the spring?
Old 09-07-2012 | 11:33 PM
  #20033
if you look super close you can see its been milled out just under the mounting holes.
Old 09-08-2012 | 01:03 AM
  #20034
STLNLST's Avatar
The shocks we are running are straight out of the package Kyosho BB and Losi BB. I dont know if Kyosho changed from a pivot ball or not. The Losi shocks are still the same as they were when the 22 was first released.
STLNLST is offline
Old 09-08-2012 | 03:23 AM
  #20035
Default i got bored...
Attached Thumbnails RC10B4.1 FT/WC-2012-09-08_03-05-02_831.jpg   RC10B4.1 FT/WC-2012-09-08_02-31-14_723.jpg   RC10B4.1 FT/WC-2012-09-08_02-38-13_543.jpg
associatevalley is offline
Old 09-08-2012 | 03:26 AM
  #20036
Default a few more.
Attached Thumbnails RC10B4.1 FT/WC-2012-09-08_02-29-37_994.jpg   RC10B4.1 FT/WC-2012-09-08_02-32-53_425.jpg   RC10B4.1 FT/WC-2012-09-08_02-32-13_52.jpg
Old 09-08-2012 | 05:54 AM
  #20037
UN4RACING's Avatar
Nice I like it....
UN4RACING is offline
Old 09-08-2012 | 06:51 AM
  #20038
tedstryker's Avatar
Originally Posted by associatevalley
love the red...
tedstryker is offline
Old 09-08-2012 | 06:58 AM
  #20039
CnR's Avatar
CnR
Wow man that looks sweet !! Please tell me how !!!! I have been wanting to do so,etching like that but with green.
CnR is offline
Old 09-08-2012 | 07:34 AM
  #20040
Grasschopper's Avatar
Ok talk to me about slipper adjustment. Currently have the stock V2 slipper assembly from the 4.1 Worlds, and am running a 8.5t non boosted motor (if that matters). My slipper had been WAY too tight and the diff was slipping...I have that figured but how tight should I make it? I loosened it to the point where the front lifts a few inches (3-4 maybe) when holding the rear wheels and hitting full throttle but if I put it on the carpet and gun it it will do a back flip (obviously not holding it).
Should I loosen this more?
Grasschopper is offline
