Like Tree2991Likes
1/12 forum
Old 09-04-2012 | 09:41 PM
  #38251
The Paragon ones were tapered
InspGadgt is offline
Old 09-04-2012 | 10:46 PM
  #38252
Radio Active's Avatar
Originally Posted by LonnyJ1950
Yep, that's the leading contender at the moment (or the 3mm offset version, not sure what advantage that has). Can anyone do better than $52.16 US?
Radio Active is offline
Old 09-04-2012 | 11:08 PM
  #38253
LonnyJ1950's Avatar
I believe the offset one fits the brushless centered pods. It uses a shorter diff hub.
LonnyJ1950 is online now
Old 09-04-2012 | 11:12 PM
  #38254
LonnyJ1950's Avatar
Yes. the straight tubes tend to break near the antenna mount. The tapered ones beef up this part. I have 2 but I hesitate to use them because they would need to be shortened.
Old 09-04-2012 | 11:16 PM
  #38255
The top 2 or 3 inches of the Paragon ones used to break off all the time but since they were so long anyway it really didn't matter.
Old 09-05-2012 | 09:38 AM
  #38256
DesertRat's Avatar
In switching from 17.5 or boosted 13.5 to mod, my car loses its balance of high and low speed steering and starts going around high-speed corners in grabby pulses of traction while exhibiting a low-speed push. Would some thicker shock oil or damper fluid help slow the weight transfer or do i have the cause wrong?
DesertRat is offline
Old 09-05-2012 | 11:44 AM
  #38257
RacinJ's Avatar
The heavier damping will make the weight transfer more aggressive and direct. Going to lighter damping will slow the weight transfer by letting the springs take it up some of the energy.
RacinJ is offline
Old 09-05-2012 | 03:29 PM
  #38258
wingracer's Avatar
Are you using the same tires you did in 17.5? Black fronts or something similar tend to be the norm in stock but lack the grip for mod speeds. For mod, magentas all around or double pink/pink or magenta/pink are more common.
wingracer is offline
Old 09-05-2012 | 04:03 PM
  #38259
DesertRat's Avatar
I am using an enneti "grey" front, but if i switched to a CRC Magenta the car was less consistent, sometime pushing sometime gripping hard and pivoting on the nose. I am currently using an Enneti yellow rear tire as well.
Old 09-05-2012 | 04:09 PM
  #38260
wingracer's Avatar
I would try a totally different tire set-up, like double pink/pink.
Also, are you running an AMR-12 body by any chance? I find that I hate that body on tracks with a mix of fast and slow corners as the body handles very differently fast vs. slow. Tracks with no fast corners, I love it.
Old 09-05-2012 | 07:33 PM
  #38261
CypressMidWest's Avatar
What's the rest of your set-up, specifically front suspension wise? Short-arm/Long-arm, springs etc.
Agreed on both points. The Black Market, and Bomb'R or Parma Speed8 HD all seem better balanced on tracks with extreme variances in cornerspeeds.
CypressMidWest is offline
Old 09-05-2012 | 09:02 PM
  #38262
Anyone using Gravity RC G12 foams?
Nexus is offline
Old 09-05-2012 | 09:56 PM
  #38263
LonnyJ1950's Avatar
I've been running the soft rears with the harder fronts with some success, but they seem almost to be 1 run tires. The more I sauce them, the less they seem to grip.
Old 09-05-2012 | 10:04 PM
  #38264
Miholc's Avatar
Hello,
does anyone have more information about the narrow chassis from the Worlds?
I like it a lot, looks like it will be the best choice for very technical tracks.
events.redrc.net/wp-content/gallery/2012-ifmar-112th-world-championships/sun-harpercrc-5.jpg
Miholc is offline
Old 09-05-2012 | 10:22 PM
  #38265
DesertRat's Avatar
Bs
Well, I run the long-arm front, .50mm crc front springs, ten degree caster blocks with the arms centered on the block for maybe six degrees of initial caster, about 1mm of droop in the front end at rest, 30k wt on the front pin, a degree of camber, two degrees of toe-out, and a stand-up style servo. I also run the Gen-Xi front axles and hubs.
I run a CRC Mohawk body.
