Like Tree130Likes
TA-05 ver.2
Old 07-20-2012, 02:13 AM
  #2191
Originally Posted by k_bojar
anyone here run a fan on their motors?? if so, how and where did you mount them??
I was thinking the little air scoop might be enough, but don't wanna take any chances
I've found the best solution for motor cooling on a TA05 is the Yeah Racing heatsink that's really minimal and 2 Yeah Racing Tornado fans. I've used other heatsinks that enclose the motor but I reckon that they do a better job of keeping the heat on the motor rather than dissipating it. The enclosing heatsinks will only really work if you have the whole heatsink contacting the motor (which usually isn't the case, there is almost always a very small gap which holds the heat). The minimal heatsink allows the fans to blow directly onto the motor which cools the motor way more efficiently than the typical enclosing heatsink. I can't post pictures of my setup cause I haven't got enough posts yet, but search flickr for "ta05 cooling" and hopefully my pics will come up.
I dremelled off the fins on one side so the centre shaft clamp thingy doesn't come into contact with the heatsink.
I've also heard of guys mounting a fan on the chassis brace that goes around the motor that blows cool air into the motor rather than onto the motor. Apparently this works incredibly well but I haven't tried it myself.
cain.c is offline
Old 07-20-2012, 02:25 AM
  #2192
wtcc's Avatar
If you use heatsink paste then that little gap between heatsink and motor should be no problem...
wtcc is offline
Old 07-20-2012, 08:15 AM
  #2193
cdwilliams1's Avatar
Trader Rating: 38 (100%+)
I'm using this guy. Seems to work well so far.
http://www.ebay.com/itm/360470741270...84.m1497.l2649
cdwilliams1 is offline
Old 07-21-2012, 03:03 AM
  #2194
Agreed - however that sounds really messy to me. I'd much rather just have the fans blowing straight on the motor.
cain.c is offline
Old 07-21-2012, 05:18 AM
  #2195
k_bojar's Avatar
Trader Rating: 30 (100%+)
thanks all - gotta figure out what I have that'll work for tomorrow
I might just mount the fan to the motor brace and call it a day - gotta look and see how much time i have today to play with the car before tomorrow's TCS race
k_bojar is offline
Old 07-23-2012, 12:18 AM
  #2196
Can anyone tell me if the standard kits come with the hardware to run the front shocks in the upright position? Or is it only possible to run lay down f1 type shocks without buying extra parts?
And also can someone point me in the right direction as far as what size spur I can fit that will give me a FDR range of around 3.7-4.3 (Im just not sure what will fit)
Glarke is offline
Old 08-10-2012, 10:02 AM
  #2197
doen08's Avatar
up for Glarke.
doen08 is offline
Old 08-10-2012, 03:47 PM
  #2198
robk's Avatar
Trader Rating: 22 (100%+)
All you should really need to run upright shocks is the shock mount (same as regular TA05), and the gear cover (same as the rear cover) if I remember right...
A spur in the 90's should work
robk is offline
Old 08-10-2012, 04:56 PM
  #2199
Trader Rating: 13 (100%+)
use this shock tower:
http://www.speedtechrc.com/store/ebp...d=865&id=12914
stitchy is offline
Old 08-30-2012, 09:30 AM
  #2200
edhchoe's Avatar
Trader Rating: 41 (100%+)
Just ordered my second ta05v2. I thought about getting a ta06 pro but could not convince myself on the extra moving parts. Ta05v2 chassis is just too efficient.
edhchoe is offline
Old 09-03-2012, 03:47 PM
  #2201
Zac_with_no_K's Avatar
Questions??
I'm finally attempting to set-up my car and have a few questions..
1. For rebound stroke, the set-up sheet I'm using says 0mm front and rear. Does this mean I should just take that screw out? Also, what effect does this screw have when raised or lowered?
2. Where are the best spots to measure ride height at? With the bumper and wheels in the way I'm having trouble finding a spot up front where I can read the height guage.
3. How/where do you measure droop and how do you adjust droop front and rear?
I'm using a Team Magic ride height & droop guage. The set-up sheet has a "memo" that the droop was taken by a Tamiya guage. Are all droop guages different or something?
Zac_with_no_K is offline
Old 09-05-2012, 04:41 PM
  #2202
414MPH's Avatar
If anyone is interested...
available for sale.
I have a very clean, very low usage TA05V2 with a '09 Tamiya Worlds (Japan) pedigree for sale including many new, unused spare parts.
PM if interested or just courious......
Marty
414MPH is offline
Old 09-30-2012, 07:14 AM
  #2203
???E-Racer's Avatar
OK guys my 4000mAh 25C duratrax lipos wont fit my chassis.
The standoffs are way too short even with spacers.
Im gonna pick up some industrial strength VELCRO and just Velcro my lipos in.
I just want some input if anyone has tried this before.
How much Velcro do you think I'll need?
???E-Racer is offline
Old 09-30-2012, 10:47 AM
  #2204
Oortael's Avatar
Hi,
these tapes are ok unless you have a bit more ride heigt. Because the chassis doesn't have any pits on the bottom side.
regards
Oortael
Oortael is offline
Old 10-01-2012, 07:29 AM
  #2205
???E-Racer's Avatar
I beileve this will work. It takes alot of strength to pull the lipo off the chassis.
http://i224.photobucket.com/albums/d...g4life/001.jpg
http://i224.photobucket.com/albums/d...g4life/002.jpg
It's industrial strength Velcro you can buy at walmart in the craft department.
