Like Tree5Likes
SC10 4x4 Thread
Old 08-19-2012 | 08:20 PM
  #28546
Wildcat1971's Avatar
Tech Prophet
Originally Posted by SC Shaun
I have a buddy's brand new ran "1 pack" Factory Team Sc10 4x4. ~
He got the Exotek locker for the slipper and mounted it up all wrong. So it melted some stuff. (put the pad in the wrong spot etc) - I fixed this and rebuilt all that.
The other problem he had during this same event was suddenly the truck started clicking.
- Clicking started half way through his first run (guessing around the time the VTS melted from stated reason above)
- It's rhythmic to the rotation of the system.
- Truck is put together correctly. I just went through it myself.
+ There's no drag on the system, it's one of the smoothest truck's i've seen roll. Mine doesn't roll this nice.
+ Again, Brand new 1 pack through it Factory Team kit.
Anyone help me? Nothing's got any scratch marks, it is not the clicker, it is locked and I know the sound it makes, and it doesn't sound like metal on metal.
take the belt off does it still do it? if not check the pulleys to make sure they dont have a rock stuck in them. and check the front clicker. Check the spur and all you gears also. does it do it without the pinion attached?
Wildcat1971 is offline
  #28547
For the clicking, are you sure you've added extra spacer in the rear diff? it's been a well known issue.
nicholasxuu is offline
Old 08-19-2012 | 08:28 PM
  #28548
With the front and rear seperated, It's the rear making the noise.
all gears are pretty and clean. No buffed contact or grit. Motor spins to a perfect hum, and the pinion is true.
Diffs are beautiful. I know that sound too. Hate it very much. Thanks for the suggestion though!
SC Shaun is offline
Old 08-19-2012 | 08:32 PM
  #28549
Found it.
The thrust washer has a notch in it. I'm really not sure how the hell that happened since i've had my truck the past 15 months with no issue, and on pack 1, his gets a ding from what looks like a rock.
Oh RC. Thank you so much for the immediate responses. Made my brain reboot, been staring at the truck for 2 hours.
SC Shaun is offline
Old 08-19-2012 | 08:47 PM
  #28550
[QUOTE=vito;11110923]
Originally Posted by twisted
no you dont need to pull the motor and anyway the pinion wont fit through the motor plate hole.
yea have to take a little off the belt guide plastic to get a pinion wrench on or drill a hole in the bottom of the chassis to access the pinion gear.[/
if it dont fit in the hole how do i get it on and off
remove some plastic off the belt guide. i thought i had a picture but i dont. next time i have the cover off ill take one.
twisted is offline
Old 08-19-2012 | 09:43 PM
  #28551
rsgonza's Avatar
I have a 4x4 sc10 I recently put a viper copperhead 4500 in it .this thing rocks.Now I recently got my hands on a losi scte I have a sidewinder esc with a 4 pole 1410 y motor
what do you all think?Im sure the motor will be ok but i have my doubts with the sidewinder speed controll.It will be running 2 cell.should i invest in a better esc? or do you thing this sidewinder will be ok if i pull the copperhead combo and install it in the losi and put the 3000 4 pole in my sc10 4x4? also have a 550 novak 6.5 sensored motor should i try that in the sc10 4 wheel drive i put a 10.5 viper vtx combo in my 2 wheel drive that thing run.ok let me know.Please also any tips on a decent escc for the 3800 or should i try the sidewinder?
rsgonza is offline
Old 08-19-2012 | 11:17 PM
  #28552
For guys running the VTS slipper, are you running it stock or with the Exotec inside slipper locked.
Anyone have thoughts on both who has actually used both setups?
Anyone using the MIP bypass pistons that has any setup tips for a bumpy outdoor loose track?
RossNZ is offline
Old 08-20-2012 | 02:02 AM
  #28553
Loved how he said a lot of people said bad about the Sc10 4x4 and they were all wrong .
So you guys that said all the bad ?
Braaaaaaaa !!!!!
All of you have no clue ....
So he was racing on a large blowin out dusty bumpy track like joe blokks race's on, or an offroad track you could drive a touring car around?
Pretty sure if it was my job and could practice all day i'd be pretty good as well, not knocking anybody, but come on, somebody's got to say it.
RossNZ is offline
Old 08-20-2012 | 05:32 AM
  #28554
symmetricon's Avatar
congtatz to the sc10 4x4! glad to se the losi knocked down a peg.
symmetricon is offline
Old 08-20-2012 | 06:32 AM
  #28555
Tech Prophet
I ran the vts with the inside locked. It pulls pretty hard from the front. Kinda weird, I could see my front wheels balloon while the rear stay normal. Might need to tighten my slipper more though, lol. If you tighten too much you wont be able to feel the difference.
Old 08-20-2012 | 08:58 AM
  #28556
Wild Cherry's Avatar
O I get it , like Mayfield had a advantage on all the other drivers ?
O-sure ...
Your right...
After all, he drove a Ae and had the best team in the world behind him for help.....
Wild Cherry is offline
Old 08-20-2012 | 09:26 AM
  #28557
vito's Avatar
wahts up wc how much speed or top end will i pick up now with a 15 tooth i got on the way from a main?
vito is offline
Old 08-20-2012 | 09:31 AM
  #28558
guessing with that 12T you can get maybe 28mph with your Novak .
With the 15T can go maybe 33mph ?
check the motor temps after the first few minutes, and never run more than 8 to 10 min with the 15T....
so maybe the 15T goes faster , but the 12T will run way longer & cooler
Old 08-20-2012 | 09:33 AM
  #28559
vito's Avatar
my motor runs way cool right now after ten min
vito is offline
Old 08-20-2012 | 09:39 AM
  #28560
thinking you will see about 150 <> 160 with the 15T
