NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 08-17-2012 | 12:11 PM
  #9706
lewis110's Avatar
CRC is Hobbywing USA
lewis110 is offline
Old 08-17-2012 | 01:10 PM
  #9707
Fred Hubbard's Avatar
Originally Posted by syndr0me
If FalconSekido is "Hobbywing of North America" then what is CRC?
They along with Schuur Speed are all authorized North American distributors.
Fred Hubbard is offline
Old 08-17-2012 | 01:35 PM
  #9708
Originally Posted by Pro10noob
With a FDR of 4.3??
No wonder the motor is running hot.
Go up to 5.5 and temp again.
I was running a FDR of 7.5 on a tech track with a straight of 50 meters.
Motor temp was 71 degrees celcius after 7 minutes.
regards Roy
Thanks i'll try an Fdr higher 5.5 / 6.0
pauper is offline
Old 08-17-2012 | 01:54 PM
  #9709
Pro10noob's Avatar
To make it clear for me and yourself, it was the motor that was getting hot and not the ESC??
regards Roy
Pro10noob is offline
Old 08-17-2012 | 09:22 PM
  #9710
Originally Posted by SeanV
Thanks Angelo, I got the files and copied them into the correct folder.
C:\Program Files (x86)\Hobbywing USB Link V3.1
I overwrote my existing files but when I start USB Link, I still get stuck on the same scree.
Woohooo... this morning it actually got through the update without any problems.
Not sure why it started working again but no complaints here.
SeanV is offline
Old 08-17-2012 | 10:03 PM
  #9711
ScottyTC4NZ's Avatar
Hey guys, can you run v3 with out capacitor on as I had a issue and smoke came out of capacitor,so took it off and the esc works find, I have a capacitors upgrade kit here, which has 4 cap head on it, will this be ok to used? They have on 93A1 471 16
Need to know ASAP as I have to race tomorrow
ScottyTC4NZ is offline
Old 08-17-2012 | 10:51 PM
  #9712
kermit's Avatar
Originally Posted by ByteStream
Angelo,
Can you explain the differences between v3_120612 and v3_120808 USB software?
What was changed/added/removed/fixed/etc?
Please explain!
kermit is offline
Old 08-18-2012 | 01:08 AM
  #9713
COBRARACING's Avatar
All three are hobbywing Authorised north American Ditributors plus crc is also Canadian Authorised .
COBRARACING is offline
Old 08-18-2012 | 01:11 AM
  #9714
Originally Posted by kermit
Please explain!
More power for the v3 ,smoother plus better at low rpm you dont get thst stepper feeling from the motor.We will also implement neutral range in a week or two as a function.
Old 08-18-2012 | 02:14 AM
  #9715
Default V3 Question
Hi people
When I connect my V3 to the digital program box and turn it on it comes up with V1.11_120331_V3 is this the current version/software for my V3 ?? If not what is the new one and how do I get it and install it
Many Thanks
FLAT OUT is offline
Old 08-18-2012 | 03:29 AM
  #9716
hello all
Today I paired my new hobbywing motor 4000 Kv (the 4.5T sensorles). I also connected the cable to the sensor but my program box 2 in 1 does not find the option to enable or disable the sensor. I wanted to know if i could only do via PC, I have no way of being able to connect to the computer and test now. Thanks for the replies. (The ESC is always 150A)
puma303 is offline
Old 08-18-2012 | 03:45 AM
  #9717
pmc
Keep the Good Work
pmc is offline
Old 08-18-2012 | 05:16 AM
  #9718
Then there's a problem in every naming since North America = USA+Canada :
CRC should be "Hobbywing North America distributor" (and not USA only)
FalconSekido and Schuur Speed should be "Hobbywing USA distributors" only (and not North America)
FFred is offline
Old 08-18-2012 | 06:48 AM
  #9719
can anyone give me a set up boost turbo
for x12 10.5T and xerun v3 120 a?
I always ride zero timing no boost but want to try.
ezh_m5 is offline
Old 08-18-2012 | 07:32 AM
  #9720
ByteStream's Avatar
Sounds good as the neutral range I feel is a needed function.
ROAR currently has V1.1_120511_beta as the approved version of the V3 software which is not the current version .. are there plans to get the current version approved ... (IIC is the first week of October)
ByteStream is offline
