Like Tree5Likes
SC10 4x4 Thread
Old 08-10-2012 | 08:34 AM
  #28111
Wildcat1971's Avatar
Tech Prophet
Originally Posted by BlueGlowBoy
Back end always wants to break loose off power. On-power, it used to just keep oversteering. Since going to the overdrive pulley, I have been able to correct the off-power oversteer with a bit of throttle. Now it pushes through corners nicely as long as I have SOME throttle on.
From what everyone is saying, I really need to invest in the centre diff. (And yes, Centre is spelled RE in the queen's english.)
Have you tried adding forward trim? to negate the drive train drag?
Wildcat1971 is offline
Old 08-10-2012 | 08:52 AM
  #28112
BlueGlowBoy's Avatar
Nope, I haven't. Didn't think that would be a problem given that with zero forward trim, I can coast for more than 100 feet from full throttle. There is less drag in this car than there is in a 3-diff car.
BlueGlowBoy is offline
Old 08-10-2012 | 09:04 AM
  #28113
Cain's Avatar
for the aka sc10 4x4 rims, do these have the +3mm offset like the hazards or are these stock offset?
Cain is offline
Old 08-10-2012 | 09:05 AM
  #28114
Wild Cherry's Avatar
Originally Posted by Evil Genius jr.
Just re-setup my car with 30K up front, 2.2/2.0 bars, and Blue/FWhite springs. That should solve my over-steer and traction roll.
*Note: I specifically tuned my car for over-steer and traction before as I had a ton of push but was still loose.
By the looks of that ?
on our track ?
the truck would not steer enough & step out on the sharp turns. Also when ever accelerating for the jump ? Wheel spin will cut the jump short and truck will case bad instead...
blame it all on the rear spring you installed...(Too stiff)
Wild Cherry is offline
Old 08-10-2012 | 09:12 AM
  #28115
vito's Avatar
is a 4 540 4.5 trun faster then a 550 4.5 trun motor?
vito is offline
Old 08-10-2012 | 09:13 AM
  #28116
Whats Sup Vito
no , less torque mostly
Old 08-10-2012 | 09:14 AM
  #28117
vito's Avatar
my novak 4.5 550 it a tad slow has no get up and go
vito is offline
Old 08-10-2012 | 09:25 AM
  #28118
Its not the fastest motor Vito .
It is very smooth and can be quick if you use some boost , 15t pinion max
Old 08-10-2012 | 09:29 AM
  #28119
Misinformation.
Yes, a 540 will have less torque than a 550....but he didn't ask about torque.
a 4.5T 540 will be faster than a 4.5T 550 running the same gearing and same voltage (assuming that you are not overgeared to the point of overloading the motor)
From novak's own chart....
The 4.5T 540 is a 9000kv motor.
The 4.5T 550 is a 5000kv motor and the 4.5T 550 with the High Torque rotor is 3850kv.
The 540 is nearly 2x faster than the 550 when using the same batteries, same gearing.
Where the caveat comes in, is that you generally have to gear a 540 much lower than a comparable 550 so that it doesn't overheat...even with fans...because it is not suited for heavy 4x4 trucks. The SC104x4 is twice as heavy as the touring cars and 1/10th scale buggies that 4.5T 540s are typically intended for....
  #28120
Evil Genius jr.'s Avatar
You win WC.
I'm copying Kodys setup with some minor changes because I don't have the spacer/oil.
I've got nothing to lose.
I'm only going 5mm on the rear ballstud cause that's all I have, 30K instead of 20K up front, a no VTS although I hope to pick one up this weekend.
Evil Genius jr. is offline
Old 08-10-2012 | 09:31 AM
  #28121
Or he has too much binding in his drivetrain and has cooked the motor....
Old 08-10-2012 | 09:32 AM
  #28122
the fast guy at my track runs an AE 4x4 and used grid irons soft on all 4 wheels. He does not use a locker or C diff or 2 stage pistons and uses a stick pack. He is like WC and AE stock. So it might just be like people say. in the hands of a good driver the truck is fine, but in my mortal hands, it needs a lot of work. heck the fast guy does not even use lead in his truck or exo chassis.
i totlely understand the 3s if the truck feals on ege you need to try the mip piston like i said in the last post
cain the truck will roll when it is wet on race day but al i do is take the outside line in those corners or slow down a little the tires have ae foam in them and i glued the foam with uerathain 3m i dont no how much that matters on the same track holeshots are good on my b4 if you stay on the line
blue the center diff dos help but not ass much as blue f springs in the rear and if you run 550 us yellow f and if that dont fix it go to higher w oil in front and rear the oil will calm the truck down most of the problems all the guys on here have i have had at one point i cant say my setup is a fix all but it works vary well for me but the mip pistons are key it was fast befor but now it is consistant and more stable
9turn is offline
Old 08-10-2012 | 09:36 AM
  #28123
if you wont fast get a tekin 4600 or beter i have 2 i can sell you one
9turn is offline
Old 08-10-2012 | 09:37 AM
  #28124
http://www.youtube.com/watch?v=asA9KwKlT7w
http://www.youtube.com/watch?v=xZzsJ60TvJc
These two vids both show the SC104x4 with a Novak 4.5T 550. If your truck is WAY slower than these, you either have it geared wrong, have too much binding in your drivetrain, or have fried your motor or ESC.
Old 08-10-2012 | 09:44 AM
  #28125
You win WC.
You can trust Kody ....
He is a awesome driver IMO..
Get that VTS on there pronto !
