SC10 4x4 Thread
)..I thought about it and Saturdays race my truck was actually pretty damm good..just had eletrical problems, when it was running (
) it was working pretty good..I went through it today and resolved a few issuses..Dustin wasn't catching me and when it stuttered (speed controler) I let Dustin go by and stayed right behind him so my truck did work pretty good..
Hey Craig (
) it was working pretty good..I went through it today and resolved a few issuses..Dustin wasn't catching me and when it stuttered (speed controler) I let Dustin go by and stayed right behind him so my truck did work pretty good..What spacers did you use under your inner ball stud? Those are the best solution I've seen yet, but I have no idea what they are...
Oasis ran Yellow Fronts in the front, and Blue Fronts in the rear. Here is the track we ran on last night.
If somebody could teach me how to avoid hitting turnmarshals in the foot who walk onto the driving line, or avoid cars heading the wrong way on the track at full throttle, I'd never loose a race. It was fun to win last night, but it wasn't any fun to take Seth's kid off his feet to do it.
Well I'm just going to start over and copy either BKs or Kodys setup except for tires.
So which one will work better on this track? More medium bite than high so I am guessing Kody but want to make sure. Thanks!
| + YouTube Video | |
forgot
If you do choose the BK ?
You need to buy a couple shorter Ti rods.
The kits rear rod is too long for you to achieve his rear camber position...
do you guys have any problems with the ball diff losening up and how tight are you seting it i am thinking of safty wire ing my lock nut striped one of the top shafts the better i run the more shit gos rong
i cant deside between inside or out side holes on the arms outside faster insde more consistant
If you are considering using safety wire still to secure your nut.on the top shaft, I would use CA glue before that if the above method fails for you. If the CA fails I would probably considerJB WELD even before safety wire.
But just out of curiosity, how would you secure a rotating part with it? I can only imagine maybe drilling a hole through the nut, through.the shaft and twisting the wire together.
I would try the above first....
Tower Hobbies lists the I.D. of the SC10 4X4 springs at .51 inches, which is obviously impossible given the size of the shock. Can someone with a dial caliper measure a SC104X4 spring and post the measurement?
5Likes
