RC10B4.1 FT/WC
Old 08-02-2012 | 10:12 AM
  #17671
mxracer458's Avatar
i run anywhere between 1.5 pads to 2.5 pads.
mxracer458 is offline
Old 08-02-2012 | 12:28 PM
  #17672
jf+'s Avatar
jf+
lol, just get the rpm ends, lol. You can even get a pretty color. Cars that are pretty go faster.
The new Mugen MBX6 Eco USA goes 954mph.
jf+ is offline
Old 08-02-2012 | 12:59 PM
  #17673
F18engineguy's Avatar
Originally Posted by F18engineguy
Iknow there a many differant ways to position the shorty pack, I have noticed that Hartson runs 1 1/2 foam behind the pack and fills tj front with foam until the gap is closed. This is how I run mine as well. I use SC10 foam rather then a bunch of small ones.
Attached Thumbnails RC10B4.1 FT/WC-shorty-foam.jpg
F18engineguy is offline
Old 08-02-2012 | 01:01 PM
  #17674
Wildcat1971's Avatar
Tech Prophet
SCR foam?
Wildcat1971 is offline
Old 08-02-2012 | 01:06 PM
  #17675
SCR foam?
Sorry, SC10 foam
Old 08-02-2012 | 01:10 PM
  #17676
Jmuck69's Avatar
New Slipper system from AVID. Seems to use the clutch basket type of system.
http://www.avidrc.com/product/5/acce...ccesories.html
Jmuck69 is offline
Old 08-02-2012 | 01:12 PM
  #17677
Originally Posted by blingy
Does anyone know what set up hartson and mayfield were running at hor rod shoot out?
Hartson ran the Spring Indoor Nationals setup at Hot Rod Shootout, Only changes were 32.5wt oil front/30wt oil rear and tires. Seems he found a dialed setup for all track conditions.
http://www.teamassociated.com/pdf/ca..._JC_Spring.pdf
*In his setup he list AE Green/brown spring but when I saw car at JC race he was running Kyosho pink/gold. Also if running bigbores he said to run piston equivalent to losi 55(4 hole)
SAGISI is offline
Old 08-02-2012 | 01:14 PM
  #17678
Tech Prophet
looks like a vts. I dont get it. and wtf is wrong with the b4 slipper?
Old 08-02-2012 | 01:16 PM
  #17679
Tech Prophet
that is what is nice about the b4. no drastic changes from track to track. just drop it and work on your line.
Old 08-02-2012 | 01:18 PM
  #17680
Looks a little like the slipper Ryan C. was using at the Cactus this year
Attached Thumbnails RC10B4.1 FT/WC-img_0256.jpg
Old 08-02-2012 | 01:22 PM
  #17681
The pads Ryan was running look like Kyosho pads
CT RACER is offline
Old 08-02-2012 | 01:24 PM
  #17682
Tech Prophet
yeah, they look a lot like that. What is with all the AE guys running kyosho parts lol
Old 08-02-2012 | 01:34 PM
  #17683
skrichter's Avatar
Speaking of AVID, do you need to shave down the front shock tower or add a spacer for the spring collars to not rub?
skrichter is offline
Old 08-02-2012 | 01:37 PM
  #17684
Tech Prophet
nope. I have put the avid rack into 3 cars. no rubbing. But dont over tighten it, or it will bind.
Old 08-02-2012 | 01:40 PM
  #17685
Jmuck69's Avatar
I ground into my front tower just enough to clear but you can space out the upper shock mount about 2mm, just need a longer screw as well.
Jmuck69 is offline
