Like Tree5Likes
SC10 4x4 Thread
Old 07-21-2012 | 06:14 PM
  #26941
Originally Posted by Evil Genius jr.
My diff and shokc oil becomes black after one run. I must be missing something?
its the aluminum and dirt mixing in the oil.
twisted is offline
Old 07-21-2012 | 06:24 PM
  #26942
drolmaeye's Avatar
Wow! mines with the stock chassis and 540 motor. lol I think I added to much weight.
I just weighed the body (Flotek with two cans of paint and the number plates) and it came out to 260g, which make mine exactly 3000g race ready with the body! No, weight (see what I did there), with the body clips it will be at least 3001g.
I have not added any added weight (but added the exotek to make it heavier for outdoor, haven't had the chance to test it yet!). I think the Exotek adds about 150g +/- 10 or so. So if you run stock with a 540 can and added weight, it makes sense.
drolmaeye is offline
Old 07-21-2012 | 07:14 PM
  #26943
Evil, you running shock boots? Not sure about the others but I notice a big difference in how much cleaner the oil stays with them on.
AzFittin is offline
Old 07-21-2012 | 07:33 PM
  #26944
I have the RTR version and my battery, esc, and motor get really hot. My motor was around 180(the other day it was 210), esc was 120 and so was the battery. The wires on the motor side were around 220 and the motor smells like burnt wires. The wires is what concerns me. I rebuilt the diffs, reoiled the bearings. I have done everything i can think of. I loosened the diff case screws and it freed up some binding. I do notice that the front wheels turn a little more freely than the back wheels with the slipper and belt removed. So I took apart the rear again and can't find anything. All the bearings feel good. Is this a sign of the stock RTR motor is going bad? Also I took apart the motor and didn't see anything. It was clean and I reoiled the bearings. It still ran hot after I did everything above. Is there anything I am missing?
xtremevol is offline
Old 07-21-2012 | 07:42 PM
  #26945
i started off with the rtr and the motor runs on the hotter side to begin with. sounds like you are checking for all the right stuff. one thing to do is set the profile on soft and add a fan to the motor.
twisted is offline
Old 07-21-2012 | 10:42 PM
  #26946
Wild Cherry's Avatar
Originally Posted by itchy b
Regarding the original blue shocks vs the FT grey ones, was there a problem with the blue that they rectified with the Ft or are the blue ones fine?
I bought a pair of FT for the rear as i was told that they can be a problem.
No problems with either , both perform almost the same .
Both share the same shock cartridge , pistons , cap & seal's..
Team shock has a Teflon base coating inside & out & TiZ coated shock shaft
Blue shock has no Teflon base coating , just anodize blue coating & chrome steel shock shaft.
Technically the Team shock will be smoother and have less striction .
( brings a extra plush ride & traction)
Wild Cherry is offline
Old 07-21-2012 | 10:45 PM
  #26947
BorackBasher's Avatar
well... just got home from the track.. and all i can say is my truck felt the best it ever felt.. since replacing all the cva's and slipper hardware.. night and day difference.. found a pretty good set up i think for my home track. i will post set up later
BorackBasher is offline
Old 07-21-2012 | 11:24 PM
  #26948
Wildcat1971's Avatar
Tech Prophet
shock boots ftw.
Wildcat1971 is offline
Old 07-21-2012 | 11:30 PM
  #26949
Tech Prophet
My night with the truck was utter fail. I qualified second after the first heat and then it went horrible wrong. Darn truck would not go straight the rest of the night. When the water comes up after the first heat, the front gets soooo planted that the rear just swings around. I had the fast guy who actually won the main drive my truck. He said my truck seemed fine but my radio was crap on a stick and he could not get a solid bead on the truck because the radio was impossible to drive. Sign............. Is it possible that the amp draw on the esc or servo would cause glitching? The servo is not a high amp draw at all. Its an airtronics 94358. It should be fine. Anyway /sadface. This truck hates me. Finished 4th in the A main with my b4 though.
  #26950
Tech Prophet
I hate you...........
Old 07-22-2012 | 01:08 AM
  #26951
I did the 8mm mod "properly" last week, by using the carbon c-hubs. I used the long rear turnbuckles instead of shortening them (effectively putting the turnbuckle over the outer hole) and I love it. The rear is a little more loose, but well controllable.. I can kick out the rear when I want to slide through turns, and catch it as soon as I need to. I only use 5mm on the inside, though.
Arakon is offline
Old 07-22-2012 | 04:36 AM
  #26952
1M's Avatar
1M
Any way to increase rear toe in?
1M is offline
Old 07-22-2012 | 06:38 AM
  #26953
fq06's Avatar
STRC makes a hub with .5 more toe in... thats the only way.
http://www.teamstrc.com/index.php?ro...product_id=912
fq06 is offline
Old 07-22-2012 | 06:41 AM
  #26954
1M's Avatar
1M
Thanks,
Which will tighten up the truck 19 tooth pulley in front or rear?
1M is offline
Old 07-22-2012 | 06:47 AM
  #26955
fq06's Avatar
The 19t pulley is an overdrive so if you use the front one, the front tires will turn faster than the rears giving you understeer.
Put the overdrive pulley in the rear and you get oversteer.
fq06 is offline
