RC10B4.1 FT/WC
Old 07-16-2012 | 05:56 PM
  #16711
Wildcat1971's Avatar
Tech Prophet
oh, and i got my front to pop up about 2 inches with the slipper.
Wildcat1971 is offline
Old 07-16-2012 | 06:13 PM
  #16712
Yeah but can you wheelie down the whole backstraight?
vw addict is offline
Old 07-16-2012 | 06:14 PM
  #16713
Jmuck69's Avatar
Originally Posted by 3srcracing
Kind off topic.. But I have been looking for some decent tools for some time now and I have been looking at this:
http://www.hobby-pros.com/Team-Assoc...le-_p_152.html
But I couldn't find out what was done to the tips to make them stronger.. So I wasn't sure if it would be worth buying. Because my current tools are the EXI from hobbypartz... How is that tools?
Get the MIP/Thorp hex wrenches and be done with it.
Jmuck69 is offline
Old 07-16-2012 | 06:18 PM
  #16714
3srcracing's Avatar
I would but I dont have $120 to spend on tools.. I'm on a tight budget.
3srcracing is offline
Old 07-16-2012 | 06:31 PM
  #16715
madweazl's Avatar
I understand not wanting to spend a ton of money but cheap tools are never a good investment. I'd stick to MIP, Losi, or even the Dynamite tools if you're on a budget. Better to buy a couple at a time as needed if you cant buy them all at once.
madweazl is offline
Old 07-16-2012 | 06:34 PM
  #16716
The Associated Team set SAE/metric is like $50, and they are great tools. I use them as backup to my Losi sets, or when I need extra reach (shafts are long). The Associated tool you linked is cool because you can use it with a cordless hand drill if you have one or get one.
Old 07-16-2012 | 06:53 PM
  #16717
Asharus's Avatar
I've had this set for over a year now and all of the tips are still good as new.
Asharus is offline
Old 07-16-2012 | 06:56 PM
  #16718
ilanstylz's Avatar
I have the same set as well, I use the handpiece it comes with as well as on my ryobi drill. I've had mine for 6months and still in great shape......
ilanstylz is offline
Old 07-16-2012 | 07:23 PM
  #16719
3srcracing's Avatar
Sick I'm going to get that
Also if any of you have Avid rack that you bought and dont like I'm looking to buy one.. I know it's lite chance but might as well check before I spend money on a new one.
Old 07-16-2012 | 07:30 PM
  #16720
F18engineguy's Avatar
When you use the avid rack do you use the small plastic bar that joins the 2 arms together? I'm talking about the one under the screws not the one that the ball studs attach too. Thanks
F18engineguy is offline
Old 07-16-2012 | 07:34 PM
  #16721
I have a used set of the factory team that I can sell you. I just PMEd you.
Since we are talking about tools does anyone have a factory team nut driver in 7mm they can sell me? I want to match my other nut drivers but I found out that the 7mm is only avalible if I buy the nut driver set. I only need the 7mm. Not the others. PM me. Thanks
Old 07-16-2012 | 07:37 PM
  #16722
Jmuck69's Avatar
I use the brace. I place shims between the link and bearings so I can tighten them down with no slop or binding.
Jmuck69 is offline
Old 07-16-2012 | 07:42 PM
  #16723
Great. What kind of shim? Thickness. Thanks again
Old 07-16-2012 | 07:48 PM
  #16724
Slipstream's Avatar
Autocratic,
Nice sharp clean lines............well done, looks great
Slipstream is offline
Old 07-16-2012 | 07:53 PM
  #16725
CraigMBA's Avatar
I dunno, I found it very sensitive to adjust. I didnt like it. I am told it works well on SC10 2wd and of course 4wd.
Because you were running it too tight.
It needs either a half height nylock or an old compressed spring from a SC10 4x4.
CraigMBA is offline
