RC10B4.1 FT/WC
#1711
Finally got some $$ to get my T4 fixed but now I have a very small problem.. It appears that the topshaft is slightly bent. Very very slightly.. I barely notice less than a half a mm in wobble on my spur gear in either direction.. Now, should that be fine to run? I'd much rather not put out another 10$ just to buy a new topshaft but if I have to I will.. I'm heading out to the track again this week for a few practice laps so any input will be read/thought over I'm just excited to have my truck up and running again!
#1712
#1713
#1714
#1715
Well, the wobble is so minute it would be very very hard to see any wobble on the topshaft, especially since it has different size components to it.. I tried looking but I couldn't tell just by looking at the topshaft and spinning it by itself. Is spur wobble something common? I'm beginning to think that it might just be the spur.. I will most likely get the kimbrough spur gears as soon as I have a little more spending $$
#1716
I've noticed that they "seem" like they dont fit, but they do. I just put the BHS on the tip of the driver, then press firmly against bleeder hole and start turning as if it fits... then it does...
#1717
The gear and slipper assembly will usually wobble.
When assembled the slipper may need a push in certain direction to run strait.
#1718
I noticed mine is quite wobbly, was planning on running the slipper fairly loose at first to get it to settle properly. run it a bit, readjust the motor and the slipper tightness, rinse and repeat til its dead true and the slipper is where I want it.
#1720
So I just got a RTR 4.1 in a trade, and I want to go through the work to make it a FT.
Now I will probably not buy the whole shock kit if I can get away with the shock bodies, but what all will I need to get?
I know I 'll need a ball diff, and the v2 shock bodies but what else?
#1722
Hey guys. I just picked up the buggy and truck today. I will be running a novac 8.5 in them. Andy gearing suggestions? I will be racing on a high traction smooth track. Thanks!
#1723
For those two cars you'll want a final drive ratio of around 9.5 (buggy) and 11.5 (truck). The truck you could start out with something like 87/20 (spur/pinion) and for the buggy try out 81/22 (spur/pinion). The buggy will be geared a little aggressively and the truck will be a little aggressive too But both of those would be fine temperature-wise
#1725
Not to say it wont or cant happen, but i cant imagine bending a top shaft. I DID bend a top shaft on my Losi Hydra Drive for my AE T2 back in the day... but that was some really light aluminum. The current AE part is far beefier.
