Like Tree5Likes
SC10 4x4 Thread
Old 07-12-2012 | 01:58 PM
  #26476
fq06's Avatar
Originally Posted by Pellefa
Back from a good day at the track, although I had quite some issues with traction rolling in the high speed sweeper at the end of the straight. Track is astro turf, so high grip. I run the FT version, setup as per the manual. 540 can, saddles, yellow rear springs in rear, no 8mm mod etc. Tires proline hole shots M3.
Any idea on where to start for reducing traction rolling? At low speed corners I have no issues, can be fairly agressive....
My .02
In the rear, less washers under the ball studs or if there are none now, shorten the camber links by changing the mounting location.
Or if the front end is where the traction roll is starting, thicker sway bar as said above.
I think adding negative camber will also reduce side bite as well, someone correct me if I'm wrong. Trade off is less straight line traction with more camber though.
fq06 is offline
Old 07-12-2012 | 02:15 PM
  #26477
Originally Posted by Cameron Kellogg
Are you using the yellow front sway bar?
I run blue sway bars front and rear, should I switch to yellows?
Pellefa is offline
Old 07-12-2012 | 02:25 PM
  #26478
Maddog94's Avatar
There is A LOT of stuff to adjust on this truck. Probably too much!
I gave up trying to figure out what does what. There are most likely 2 or 3 ways (maybe more) to achieve any given setup goal with this vehicle.
I am slowly learning NOT to take anyone else's setup advice. No 2 tracks are exactly alike, and no 2 drivers drive the same. Just pick one thing at a time to adjust, try it, be ready to change it back immediately if the desired effect is not achieved, and then try something else.
One thing I'm working on now is adding weight. A metric shyte-ton of it. I currently race on a 1/8 scale outdoor track and I think more weight is essential to compete the wind and against the heavier Losi's.
Maddog94 is offline
Old 07-12-2012 | 02:31 PM
  #26479
fq06's Avatar
That's for sure. More than 10 ways to skin this cat (and get lost)!
fq06 is offline
Old 07-12-2012 | 02:36 PM
  #26480
Jake S's Avatar
did anyone else notice on Bks truck, the personal says for the id "dirtinator"
i had a good laugh over that
Jake S is offline
Old 07-12-2012 | 03:05 PM
  #26481
Wild Cherry's Avatar
Not a good plan ....
Instead use good set-ups like those listed on www.rc10.com...
A Tip
a good set-up will always perform great on the track conditions it is meant for ..
Thus a good set-up always works and not just for someone who thinks they have a particular style....
When making changes to your set-up only change one thing and test till you are satisfied the change was good or bad before changing something else.
Wild Cherry is offline
Old 07-12-2012 | 03:15 PM
  #26482
JEFFs SC10's Avatar
I say go to a standard factory team setup then fine tune.
I just put 60g of ballast in front of servo. I also swapped to a 14 tooth pinion. I am ready to run. Gonna try to go down south to run on an outdoor track.
JEFFs SC10 is offline
Old 07-12-2012 | 03:25 PM
  #26483
JEFFs SC10's Avatar
Originally Posted by darryl80
i am not a guy that can be patient and wait. if i have to i will take the best offer i can get so i can move onto something else.
If it's a cheap price I may pick it up for my son to bash lol.
Old 07-12-2012 | 03:58 PM
  #26484
BlueGlowBoy's Avatar
Kinwald has been known as The Dirtinator for YEARS! Probably for 15+ years... Kinda like how Lutz has been known as the Lutzinator.... And pretty soon, Tessman is going to be the Winninator....
BlueGlowBoy is offline
  #26485
xxfile's Avatar
Wellll there are NO setups on rc 10 for a real dirt track they all seem to be for those Socal clay(asphalt) blue groove tracks where u guys run slicks lol.
We run on a loose dirty dusty almost 1/8 scale track and the thing is hard to get balanced.
The rear end wants to pass the front in sweepers or coming out of tight corners.
Currently started with the FT stock manual setup. running a castle 4 pole with M4 calibers.
took off both swaybars and it helped... reduced preload a lot and that helped.
after a couple of batteries the rear diff seemed to be locking up so that was it for night one.
Now digging deep to access the diff.
Is this diff a shim issue?
xxfile is offline
Old 07-12-2012 | 04:07 PM
  #26486
Wildcat1971's Avatar
Tech Prophet
Can you post your setup?
Wildcat1971 is offline
Old 07-12-2012 | 04:13 PM
  #26487
Tech Prophet
If you lpok a few pages back I was given a good base setup
Old 07-12-2012 | 04:15 PM
  #26488
fq06's Avatar
Did you add clips to the shock shafts to limit up travel?
fq06 is offline
Old 07-12-2012 | 04:17 PM
  #26489
So my SC104wd has been collecting dust for a few months. The other day I decided to dust it off and see if I can breathe some new life in it.
I noticed that my 16mm 8.2 shocks actually fit on the Sc10. All I you have to do is use the 8.2 shock holders and a washer or two for the shock end eyelet. The lenght of the front shocks is almost the same as the rears on the Sc10.
Bottom line, has anyone run the sc10 with the rc8 shocks on their car? The Losi guys around here all pretty much use 8ight shocks on their cars.
Edumakated is offline
Old 07-12-2012 | 04:58 PM
  #26490
xxfile's Avatar
Setup is FT by the book setup...
Nowhere did we see the up limiters in the book but it came with lots of them.
we are not newbs have been running losi scte and slash platinum since it came out.
You can see the potential in this truck once we can get a handle on the handling...
xxfile is offline
