Serpent 811E Buggy Thread >
Like Tree5Likes
Old 07-05-2012 | 09:13 PM
  #2521
Originally Posted by bigjayjay1
Just take the shaft pieces go to the store and compair
Thanks but I wont have time to get to the shop until race day. I was hoping one of you guys new a direct replacement from one of your race days when you needed a quick fix and didn't have the oem part on hand. I don't want to waist my time driving to the track if they they don't carry a possible replacement that can get me through the weekend.
400units is offline
Old 07-05-2012 | 10:32 PM
  #2522
Well I've ran my car a couple times and it's very very different than my MP9, I was using the box setup and this thing was loose. I've since gone to 600CST weight oil in the front shocks and 37.5 in the rear. Using the 27/28mm ride height respectively as well as 5-5-3 in the diffs. Any suggestions on a good setup for indoor hard packed clay?
f41stryker is offline
Old 07-05-2012 | 11:30 PM
  #2523
weavty1's Avatar
Remove the sways, then give it a whirl
weavty1 is offline
Old 07-06-2012 | 07:03 AM
  #2524
nogarats's Avatar
Just to let you know, a temporary fix, I replaced the center diff with an xray 808 center diff (with bearing), changed the spur for the Kyosho 46t (I am normally running Kyosho spur on my Serpent) and it worked. Used only one seal but after 10 min, it let the oil out but I had 2 that were very loose.
It worked for me, it permitted me to bump up in A main !!
Nog.
nogarats is offline
Old 07-06-2012 | 02:51 PM
  #2525
Chad Millikan's Avatar
I drove mine at OCRC for the first time the other day, box Stock set up, and I thought it was pretty darn good. That track is indoor hard packed clay
Chad Millikan is offline
Old 07-06-2012 | 03:08 PM
  #2526
RCmayor's Avatar
I think what that guy meant was the MP9 didn't have any steering.
RCmayor is offline
Old 07-06-2012 | 04:04 PM
  #2527
ChrisIso's Avatar
How many times a month do you guys change your diff oils? I practice every weds and race every Sat, Sun.. I figure ill change one every week, you think that's not enough or too much?
ChrisIso is offline
Old 07-06-2012 | 04:07 PM
  #2528
RCmayor's Avatar
I would say every 1 to 2 hours on the car is good. You are probably safe to go every other week as long as you don't see any leakage.
RCmayor is offline
Old 07-06-2012 | 04:24 PM
  #2529
Pretty much only when I'm changing weight to try something different.
Stealth_RT is offline
Old 07-06-2012 | 04:39 PM
  #2530
ChrisIso's Avatar
Thanx,
ChrisIso is offline
Old 07-06-2012 | 06:37 PM
  #2531
vedardo49's Avatar
does anyone know where i can get a used 811be?
vedardo49 is offline
Old 07-06-2012 | 07:15 PM
  #2532
bigjayjay1's Avatar
EBay has one
bigjayjay1 is offline
Old 07-06-2012 | 07:57 PM
  #2533
KIK's Avatar
KIK
http://www.rctech.net/forum/r-c-item...b-e-buggy.html
KIK is offline
Old 07-06-2012 | 08:23 PM
  #2534
vedardo49's Avatar
that guys says he has a deal pending its really hard finding a used one it must be a good car thats why everyone wants to keep it
Old 07-06-2012 | 08:24 PM
  #2535
vedardo49's Avatar
EBay has one
i can't really afford a new one haha
