SC10 Thread Part 2 >
SC10 Thread Part 2
Like Tree24Likes
SC10 Thread Part 2
Old 06-15-2012 | 05:40 PM
  #241
also wondering what gearing is the best too run on each of the trucks as well as battery choice. i have a ton of 2s and 3s lipos. thanks
mharding1993 is offline
Old 06-15-2012 | 06:43 PM
  #242
Zac_with_no_K's Avatar
Exclamation
would anyone recomend dremeling part of the chasis so the servos wires aren't being stressed?
- just enough so the servo wire doesn't need to bend so bad. Or would this weaken the chassis? It wouldn't be much
Zac_with_no_K is offline
Old 06-15-2012 | 07:25 PM
  #243
You should be good man. Ive got slots cut in my sc 10 for the servo wires. Makes everything alot cleaner and u dont gotta worry about the wire stretching out of the housing. Ive also done it on my slashes as some of my lipos have large diameter wires. It works fine. Ive seen some people dremel away there chassis to swiss cheese and they dont have any problems. Small cut like that would be fine. Round off ur edges tho as rubbing can cause the wire to run alot
Old 06-15-2012 | 08:40 PM
  #244
Thank you mharding!
Old 06-15-2012 | 08:50 PM
  #245
Is there a way to find out what spacer to use, if any, for the Savox SC-1258TG?
I've been trying to eyeball it by putting it on top of a futaba servo but am worried I might mess something up if my guess is incorrect. I'm guessing it's no spacer but just want to be sure.
Old 06-15-2012 | 11:11 PM
  #246
J_Bone's Avatar
Count the splines and match it up. 25t....
J_Bone is offline
Old 06-15-2012 | 11:24 PM
  #247
Jokermayhem's Avatar
I'm running a 7.5 Tekin RS set up and was wondering what people thought of running the gear ratio 23/84 on a HUGE track?
Jokermayhem is offline
Old 06-15-2012 | 11:30 PM
  #248
The futaba servo horn fits like they said it should. I meant the spacers you use with the piece that's used to attatch the servo to the chasis.
Old 06-15-2012 | 11:33 PM
  #249
J_Bone's Avatar
Loosely mount the servo mounts to the chassis and set the servo in and see which one it needs, if any.
J_Bone is offline
Old 06-15-2012 | 11:56 PM
  #250
Thanks for the quick reply. How do you tell if it needs one? I've installed it without a spacer but the servo makes A LOT of noise, even when still..
Old 06-15-2012 | 11:58 PM
  #251
J_Bone's Avatar
If it's not hitting the chassis, then it's ok. I don't have a Savox, but I've read that they make noise. Most do.
J_Bone is offline
Old 06-16-2012 | 12:18 AM
  #252
nismomike's Avatar
Thats a final drive ratio of 9.5 and it will be geared to top out at around 60 mph. When I ran a Fantom 8.5 with a high torque rotor (lower kv) the highest I could gear it was 21/84. It had an unloaded kv of 4000. The Tekin Redline 7.5 has an unloaded kv of 6100. I'm still gonna go with Hethcox and say 18/87 or 18/84. I have a buddy in NC who runs at Cape Fear Raceway which is one of the biggest tracks in the U.S. and we run identical electronic setups. He only gears up 1 more pinion tooth than me (22/84).
nismomike is offline
Old 06-16-2012 | 09:44 AM
  #253
Acill's Avatar
If you have never used a digital servo the noise is a bit strange, but all of them do it. Its just the servo keeping itself centered. Don't worry about it.
Acill is offline
Old 06-16-2012 | 11:58 AM
  #254
skengines's Avatar
Anyone running the Lunsford Turnbuckles. Which ball cups are you using?
Is this the correct one to get? http://www.amainhobbies.com/product_...nd-Set-Grey-12
I see they have a set specifically for the Super duty series but I am not running Lunsford ball studs.
skengines is offline
Old 06-16-2012 | 12:05 PM
  #255
elex300's Avatar
No spacers needed for the Savox servo and they are noisey,nothing you can do to change it.
elex300 is offline
