SC10 Thread Part 2
#391
sorry, basic question, but I need some help: got an sc10. Replaced my ball diff. I'm almost positive I set it correctly (holding 1 tire & spur and not able to turn opposite wheel). However, I can't seem to tighten my slipper tight enough so that it has enough torque when I hit the throttle. Did I flatten my diff balls and have to rebuild it again? Or is there another problem? It seems like a slipper issue, but my slipper pads are new. any help would be appreciated.
FYI: using FT ball diff. In the past, I've used b-fast ball diff's with ceramic balls and they were always easy to set.
#392
#393
What noise are you getting from the truck? duck call=diff is slipping a whine is the slipper slipping. what motor are you using? what are you looking at for torque?(wheel lifting/ wheelies down the straight?) My tekin redline 17.5 blinky will not lift the tires off the table. it just bogs down. Maybe your slipper spring is worn out and cant compress enough?
Thanks for the help.
#395
Find Chris Krieg on facebook and send him a message. He is the guy behind the X Factory Carbon Fiber SC Truck. He is also a local to the phoenix area and im sure you will end up meeting him if you move out there, nice guy.
#396
he's a really good Guy. I haven't talked to him or Alex in 6 years.
#398
Thanks for the info. I am going to be moving out there for sure no later then October. Im just waiting for my start date to get final, looking like Sept 17th if all goes well.
#399
That setup was on the other truck that has bn sitting n the house. The truck I'm speakinng about has 32.5 wt up front on 2 piston and 5 limiters, the rear is 30 wt with 2 piston and 2 limiters
#400
What do you think about my painted shock tower?
Build thread http://www.ashevillerc.com/showthread.php?tid=617
400th post WOOT WOOT !
24Likes
