SC10 Thread Part 2
#212
#214
Yes. I run yellow ₣ront and red rear. I will E-mail you the setup for pistons.
#217
ITs time to pull my ball diff and do a rebuild. Im thinking of using an MIP this time. Will this fit the stock FT diff case? Im sure it will but wanted to ask just in case. It mentions it replaces a gear diff in the writeup.
http://miponline.com/store/mip09130.html
#218
Gamedog wanted MIP bypass1 setup as well, were you inquiring about that or just the SC10 setup?
#219
#220
#221
Hey Guys we have more screw kits available.
http://www.rctech.net/forum/r-c-item...nd-raiser.html
Vince
Vince
#223
the setup look very similar to mine, except a few small things. is it very aggressive,i ask because u have ur steering expo to neg 50 lol and in the washers is that 5 rear and 3 front? and when i get the pistons in the mail ill hit u up on the phone so i can put em together right so i dnt mess em up bro. cnt wait to try it out and will let you know how it runs man
#224
#225
Front-yellow Avid [can use blue AE springs], 40wt. Losi [37.5 AE], blue + blue + washer + tan. If your track is fairly smooth, you can use blue+blue+tan+washer in front.
Rear-Red Avid [can use silver AE springs], 30wt.AE, blue + blue + washer+tan.
My ride height, I run 33mm front and 32mm in the rear. Its higher than most but. it for the big jumps at my track. You can run what you normally run.
With bypass pistons, I don't use the drop method. It will rebound higher dropping it than when your driving it. I press it down till chassis hits table and then let it up. Use that measurement.
24Likes
Picked up a new 2w with all the goodies this week. Time to put some work in at the track.
