Like Tree5Likes
SC10 4x4 Thread
Old 06-14-2012 | 08:14 AM
  #24991
darryl80's Avatar
are the shocks hard to put together? this is my very first kit truck I have put together.
darryl80 is offline
Old 06-14-2012 | 08:16 AM
  #24992
fq06's Avatar
Their easy.
Go to AE's site, there is an instructional video on how to build the shocks.
fq06 is offline
Old 06-14-2012 | 08:28 AM
  #24993
Cain's Avatar
The assembly in general is not hard.
Just remember, do not FORCE parts together or gorilla down screws (ie- remember how you snapped those screws on the hitec servos? big no no).
Just take your time and all will be well. Its not a race.
Cain is offline
Old 06-14-2012 | 08:55 AM
  #24994
Resqnu's Avatar
Default 8mm hub mod
Just got my parts in. Do the parts just bolt onto the hub? Any mods to make it work?
Resqnu is offline
Old 06-14-2012 | 09:02 AM
  #24995
t0p_sh0tta's Avatar
You know the one area that Losi really has a leg up on AE is the TLR Blog. It really sucks to follow their lead, but getting the info straight from the source would be great.
t0p_sh0tta is offline
Old 06-14-2012 | 09:23 AM
  #24996
What I do this time ?
Nothing at all. Just pointing out how boring this thread would be without your factory inside tips and tricks from an unbiased Professional RC Racer as yourself.
JLinney is offline
Old 06-14-2012 | 09:25 AM
  #24997
Amen, we get it all second hand from Cherry.
JLinney is offline
Old 06-14-2012 | 09:41 AM
  #24998
Wild Cherry's Avatar
When Ae had a forum ?
Not many used it.
Believe
most of the Ae drivers were still coming to RcTech with their support anyway ..
Try using the PM , you can find more than a few Factory Reps using the board .
I usually get a prompt reply from any of them too .....
Wild Cherry is offline
Old 06-14-2012 | 09:43 AM
  #24999
Cain's Avatar
It would be cool to have some of the AE guys drop in, heck, if they could just take a few questions and report back that woudl be awesome.
Cain is offline
Old 06-14-2012 | 10:06 AM
  #25000
Default 8mm C-Tab Mod
Finally tried the 8mm C-Tab rear hub mod.
I reversed the rear hubs L/R to get a better angle on the camber links.
The turnbuckles just clear the rear shock springs by 1mm or so. As I stated before, if they do hit you can space the top shock bushing out with shims.
I am running the mod with 12mm Ti ball studs and 6mm shims.
Previously I ran the middle hole on the rear hubs. With the C-tab mod it moves the rear camber link right above the inside hole on the stock hub. This was a shorter camber link than what I typically run. While I did try the inside hole on the stock hub previously, I did not like the shorter rear link. With the C-Tab mod it did feel better. It loosened up the rear end just enough but still carved a good turn.
I am running the Exotek center chassis with blue front springs in the front, white front springs in the rear with 32.5/27.5 shock fluid F/R, stock 1.2 pistons. The rear feels a little soft so I am going to try moving up to the blue front spring in the rear and maybe move up to 30wt shock fluid.
Had a 2 week old RX8 fail on me for no apparent reason. Reinstalled my MMP with external BEC and runs flawless. Why did I buy an RX8?
F_ME is offline
Old 06-14-2012 | 11:07 AM
  #25001
ilanstylz's Avatar
If you don't want the RX8 I'll take it
ilanstylz is offline
Old 06-14-2012 | 11:09 AM
  #25002
Evil Genius jr.'s Avatar
No me!
Evil Genius jr. is offline
Old 06-14-2012 | 11:10 AM
  #25003
ilanstylz's Avatar
Originally Posted by Evil Genius jr.
No me!
I was first, besides your supposed to be buying my spares
Old 06-14-2012 | 11:12 AM
  #25004
I will if my RX ever sells! 40% off BNIB and not even one lowball
Old 06-14-2012 | 11:17 AM
  #25005
ilanstylz's Avatar
Put that sucker on ebay and you'll get more for it....
