SC10 Thread Part 2
#4381
Now this is more like it. No idea what the springs are. The color sleeves are missing. They appear to be v1 big bore AE springs. I’ll have to compare them to the gray and blue f/r v1 springs I have.
#4382
Here is my SC10. First R/C since the original rustler I had mid 90s. Dug it out of my dads garage after probably 8 ish years. Had tons of fun with it bashing around. Ended up breaking the rear chassis plate....and that's when I realized how rare this car has become haha. So I went down the R/C rabbit hole and cruised ebay for hours and visited almost every hobby store in San Diego. Walked into the stores and asked to see the Team Associated stuff and everyone kinda laughed and was like let me dig em out...Usually hands me a old dusty box. I found some pretty sweet scores. Wheel bearings..diff rebuild kits...servo saver stuff. Probably collected enough to build a second car. But anyways here it is.....I don't want to call it a basher anymore..im way careful with it but man it is fun. I would say more fun then my new Baja rey.
I do need to find a new ESC I think. The throttle is literally on/off. It is plenty fast to have fun with. I may turn it into a clay racer, we will see.
#4385
The servo arm wont make a difference. And it is all original anyways. The linkage that runs from front to back is what hits the top of the servo. The stock servo "top" is angled slightly. The aftermarket ones are squared off. If i could post pictures or even links to pictures it would make more sense.
#4386
#4387
Gott Cha. Sounds like a standard servo with no wiggle room when mounting it. Reminds me of one of my JX servos that had a lot of material on the top of the case. Little bit of Dremel grinding and it turned out really well. There was a moment I thought this was a bad idea.
#4388
Hi all, anyone know if there are any stronger outdrives that fit the db10 / trophy rat platform?
I don't race, and I do keep the slipper a little on the tight side because I like the acceleration. However, after only about 5 packs, the outdrives have massive divots worn into them. They are definitely catching the dogbones and preventing the rear suspension from cycling property. The dogbone pins do NOT have flat spots at all, which makes me think the outdrives are just too soft or, more likely, too thin.
I will replace the outdrives for now with stock parts, and I'll run the slipper a little looser, but that will be a band-aid. Anyone know of any parts that fit this diff/gearbox which are much beefier?
Thanks!
Thanks!
#4389
SC10 & PRO SC10/PRO2 SC10 GEARBOXES:
The "old school" SC10 9826 gearbox and the new Pro SC10/Pro2 SC10's 91430 gearbox are very similar. If anyone has a side by side comparison picture of the two, it would be great to see. TIA
- Has anyone ever tried to do a mockup of the Pro SC10/Pro2 SC10 #91430 gearbox on a SC10 chassis?
- Would the rectangular part of the new gearbox be a drop in fit with little, or no modification?
- How far off would the gearbox's brace/tab be to matching up to the chassis brace?
#4390
I guess the question before pursuing might be what was your reason/hoping to accomplish to even want to try it, as they each had their strong/weak points in comparison? ...
#4391
Thanks!
Thanks!
#4392
I am amazed at the amount of people, newer and those who've been in the hobby for quite some time now, that are picking up used SC10 rides to "fix up". The whole notion/idea of putting a Pro2 SC10/Pro SC10 gearbox on an old SC10 chassis was to give those, who are in need of parts, an option to keep their beloved newly acquired ride, and/or "old faithful" up and running.
#4393
...Has anyone ever tried to do a mockup of the Pro SC10/Pro2 SC10 #91430 gearbox on a SC10 chassis?
- How far off would the gearbox's brace/tab be to matching up to the chassis brace?...
...I am amazed at the amount of people, newer and those who've been in the hobby for quite some time now, that are picking up used SC10 rides to "fix up". The whole notion/idea of putting a Pro2 SC10/Pro SC10 gearbox on an old SC10 chassis was to give those, who are in need of parts, an option to keep their beloved newly acquired ride, and/or "old faithful" up and running.
24Likes
