RC10B4.1 FT/WC
Old 05-17-2012 | 10:28 PM
  #14866
B00t13g's Avatar
I'm not sure what theyean by align the c clip with the d shape? I assume that's just how you get the axle to fit through the knuckle? Anyway, thank you for the help, I greatly appreciate it!
B00t13g is offline
Old 05-17-2012 | 10:49 PM
  #14867
Default avid steering
Are their bushings that go on the top? If so where do you get them ? On my old plastic servo saver it has bearings.
Thanks, Brian
bribtb is offline
Old 05-17-2012 | 10:54 PM
  #14868
B00t13g's Avatar
Thanks, Brian
My kit came with bearings, but I'm using the avid rack and never messed with the servo saver shenanigans.
B00t13g is offline
Old 05-17-2012 | 11:01 PM
  #14869
When using the Avid rack does it use bushings? The holes on the top and bottom are recessed.
bribtb is offline
Old 05-17-2012 | 11:05 PM
  #14870
B00t13g's Avatar
I have bearings in all four holes.
B00t13g is offline
Old 05-17-2012 | 11:10 PM
  #14871
[QUOTE=B00t13g;10747797]I have bearings in all four holes.[/QUOT
Mine that were in the old setup are to big.
bribtb is offline
Old 05-18-2012 | 06:54 AM
  #14872
Wildcat1971's Avatar
Tech Prophet
Originally Posted by CraigMBA
If it doesn't look exactly like this, and go together exactly like this, you'll be likely to have that problem:
Uploaded with ImageShack.us
Is this an upgrade kit? Or from another kit? The B4.1 Worlds is not hex out o the box right?
Wildcat1971 is offline
Old 05-18-2012 | 07:10 AM
  #14873
20 SMOKE's Avatar
its the hex option that came out for the sc10 first and now for the b4,been out for some time
20 SMOKE is offline
Old 05-18-2012 | 07:31 AM
  #14874
Tech Prophet
Do I have to piece it together or can I buys it as an upgrade kit?
Old 05-18-2012 | 07:37 AM
  #14875
Avid RC sells front/rear hex together. The rear hex is a simple replacement . The front you need to buy the option threaded axle AE sells shown above.
Chase1472 is offline
Old 05-18-2012 | 08:24 AM
  #14876
20 SMOKE's Avatar
this is my question,do you own a rb5 or have tons of fr hex wheels,if not why would you want fr hex,you cant rotate them to the back.i'm not doing fr hex on a buggy in my opinion its a waste of money
20 SMOKE is offline
Old 05-18-2012 | 08:28 AM
  #14877
Asharus's Avatar
i wouldve went front hex a long time ago if i didnt have so many standard wheels for the front. i'd love to be able to borrow tires from fellow K drivers.
Asharus is offline
Old 05-18-2012 | 08:29 AM
  #14878
Tech Prophet
I currently have a B4 FT ( I am sure this question was asked before). What are the differences between the B4 FT and the B4.1 FT? I went throught the manuals and this is what I discovered. Let me know if i am missing anything.
1) Rear Alum Hubs (.5 deg), but most setups are 0deg hubs.
2) V2 shocks
3) V2 Slipper? (Worlds only?)
4) Chassis? B4 to 4.1, not worlds.
5) Battery Strap (has thumb screws
6) Body/Wing (lol)
7) TI Nitride Ball Studs?
Old 05-18-2012 | 08:31 AM
  #14879
Asharus's Avatar
there's too much to list and it will cost almost if not as much as just getting a new kit.
Asharus is offline
Old 05-18-2012 | 08:33 AM
  #14880
Tech Prophet
I agree. After looking at it, I decided not to bother. I like hex better than wheel bearing, but not a good enough reason. I have a 4-5 year old B4 FT that I am dusting off and trying to decide what I want/need.
