RC10B4.1 FT/WC
Old 05-18-2012 | 08:38 AM
  #14881
Wildcat1971's Avatar
Originally Posted by Asharus
there's too much to list and it will cost almost if not as much as just getting a new kit.
Yeah, I would never buy all that stuff. I am trying to decide if the 250+ for a new buggy would really benefit me over what I have. The only upgrade I kinda like is the read hubs. The larger outside bearing might be nice. I tend to destroy that bearing. I just wanted to make sure I was not missing anything before I decide. If that is all that is different, then I will probably just keep my b4 as is.
Wildcat1971 is offline
Old 05-18-2012 | 09:05 AM
  #14882
20 SMOKE's Avatar
all i have is a ft b4 with +8,does just fine
20 SMOKE is offline
Old 05-18-2012 | 09:17 AM
  #14883
AngryRog's Avatar
Originally Posted by 20 SMOKE
this is my question,do you own a rb5 or have tons of fr hex wheels,if not why would you want fr hex,you cant rotate them to the back.i'm not doing fr hex on a buggy in my opinion its a waste of money
+1, got caught up with the "this is what you need" hype at my LHS when I bought the new car. Kind of stuck as I have a number of hex wheels mounted up, and my kid wants to run buggy with me now...
AngryRog is offline
Old 05-18-2012 | 09:33 AM
  #14884
B4TravSC10's Avatar
I ran my original b4 with a +8 and BB springs on the first version shocks also. I did have the better hubs. I bought a Worlds just to get everything fresh again. Ran almost identical times.
B4TravSC10 is offline
Old 05-18-2012 | 09:39 AM
  #14885
t0p_sh0tta's Avatar
The "Worlds Kit" isn't some mystical buggy.
It's a B4.1 with a long chassis. Everything is else is just a tuning option. If you've got an old buggy, get whichever hubs fit your needs and use tape weights.
The hexes are bling. I got my the plastic ones so I can use my 22 wheels in the back. The only reason I see to go with the front is so I don't have to worry about losing those stupid little screws.
t0p_sh0tta is offline
Old 05-18-2012 | 10:52 AM
  #14886
Asharus's Avatar
The hexes are bling. I got my the plastic ones so I can use my 22 wheels in the front. The only reason I see to go with the front is so I don't have to worry about losing those stupid little screws.
i swapped the axle out with the old b4 axle (sc10 axle too) that uses the locknut instead of that BHS
Asharus is offline
Old 05-18-2012 | 11:35 AM
  #14887
OK, I concur. I will just upgrade the rear hubs and as weight as needed. I drove my buggy a couple weeks ago and it felt good. I might get the 8+ chassis
Old 05-18-2012 | 11:37 AM
  #14888
I thought the reason for the flush screws was to prevent the axle from snagging on objects? Maybe I just hit too many things...lol
Old 05-18-2012 | 11:41 AM
  #14889
Asharus's Avatar
http://www.youtube.com/watch?feature...1wWY-qus#t=32s
Asharus is offline
Old 05-18-2012 | 11:43 AM
  #14890
Asharus's Avatar
yes that's exactly why. ive never had a problem snagging something with the axle/nut specifically though.
Asharus is offline
Old 05-18-2012 | 12:21 PM
  #14891
JEFFs SC10's Avatar
The chassis made the biggest difference. Then tires.
Now the rest is driver.
JEFFs SC10 is offline
Old 05-18-2012 | 12:41 PM
  #14892
20 SMOKE's Avatar
never drove it with the stock chassis,when straight to the +8 so i cant compare
20 SMOKE is offline
Old 05-18-2012 | 02:19 PM
  #14893
intimdator10's Avatar
Default Need for Speed
This may be the wrong place for this question, but hopefully you guys can give me some suggetions. After a long retirement, I have bought a RTR B4.1. I want a little more speed out of it, so will changing the pionion help any or should I just buy a 13.5 motor? This brushless stuff is Greek to me.
intimdator10 is offline
Old 05-18-2012 | 02:24 PM
  #14894
The pinion will make you go a little faster. Might cause your esc/motor to get hot and possible burn up if you go to far. What esc came with that RTR because you may not be able to upgrade the motor to a lower turn?
If you have the brushed kit, its limited to 17 turn per AE's documentation.
If its the brushless kit, then you can go up a 6100 kV with 2S Lipo motor.
Motor Limit: 3900kV w/3S LiPo, 6100kV w/2S LiPo
Old 05-18-2012 | 02:27 PM
  #14895
Tradin Paint's Avatar
That RTR motor is just as fast or faster than a 13.5. It all depends on what your doing. If your gonna be racing I suggest you stay with that motor. It is plenty fast for most tracks especially if you are "restarting" the hobby. If you are looking for more speed to bash with you can look at one of the Castle setups
Just my $.02 take it for what ita worth
Tradin Paint is offline
