SC10 4x4 Thread
I just replaced both pulleys due to wear and it was $6. The bag with the clicker, tensioner pulleys, and gear pulleys is $12. 1 drop of loctite has worked just as well for me instead of glueing. I loctite almost everything even if it has a nylock. Old habit from desert racing open class motorcycles. I was just stating what I prefer to do since I already waste too much money on this hobby and don't want to throw away more than I have to. Glue it if you want but there are other options just as good.
Then follow up using CA to make sure that it never. moves. again.
Hey guys! I'm waiting on a brush less system that I bought (stock 3500kv 550 from sc10 4x4 rtr) but in the meantime I was wondering about gearing... The setup is 32p with a 5mm motor shaft and the only pinion I have for that is 17t is that too large? What is a recommended place to start at? Can't wait to drive this thing!!!
Hey guys I have a mostly stock rtr and was curious what to do next. I drove it on a high bite clay indoor track over the weekend and it drove pretty good with only swaybars being the major hopup on it.
When ya'll refer to the "clicker" what are you referring to? I'm totally new to the sc10 4x4 and aren't familiar with all the parts on it.
Should I buy a center diff next or the factory team upgrade that comes with the V2 slipper? Is the slipper on my truck worth running for long? It's the factory rtr one.
What other upgrades should I do? I feel the truck was planted good on the track but I want faster lap times. The truck will also be driven outdoors a lot on my own track.
I wish AE would make a solid replacement unit for those that don't want to use the clicker.
Not stupid , VTS slipper also fits the Sc10 2w drive & B4.1 .
Reason for no part # change is they no longer make the old cover & the new cover takes it place....
Just clean your pads if glazed .
If your glazing the ft drive pad prematurely you may have not assemble correctly..
Seen it happen
Seen it happen
That being said, if you get the wrong cover call Associated and they'll send the correct part.
So I the real world we change part numbers if the update effects "fit form or function". Not changing the part number when there is new old stock in the pipeline is stupid. It's wrong.
So in the real world we change part numbers if the update effects "fit form or function". Not changing the part number when there is new old stock in the pipeline is stupid. It's wrong.
There's a plus side by making it just a running change ...
No changes needed for inventory , labels , order forms, ect, thus fewer expenses.....
GLUING CLICKERS ?
You shouldn't need to ....
| + YouTube Video | |
FT Update Kit.
The clicker is the pully setup on the front of the sc10, when the nut is tightened down all they way the sc10 is in 4wd at all times, when it is loosened up the sc10 will turn somewhat into a 2wd meaning when you break only the rear will break etc..........
Other good upgrade options are rcshox 2stage pistons, ackbar, and AE's carbon fiber rear hub's that are made for the b4/t4/sc10 etc.......
5Likes
