Like Tree5Likes
SC10 4x4 Thread
Old 04-29-2012 | 09:12 AM
  #22306
CraigMBA's Avatar
Originally Posted by Lon_L
Then I plug them into my Hyperion and charge them at 20 amps without a hiccup. Try that with any other battery available and see how it works out.
I do it all the time, with every battery I own, all of them "any other batteries", without issue.
CraigMBA is offline
Old 04-29-2012 | 09:13 AM
  #22307
Take the pinion off and the belt and check for binding.
Beachbuggyphil is offline
Old 04-29-2012 | 09:44 AM
  #22308
Wild Cherry's Avatar
Tech Legend
Originally Posted by SAMCRO
Also, what is the proper setting for the front clutch?
Don't use glue, bad advise !!!!
Just tighten down till the nut bottoms out for full time 4w drive ....
Most use the full time 4w for best performance...
Wild Cherry is offline
Old 04-29-2012 | 10:59 AM
  #22309
Thats awesome Craig. I however did not have the same luck. I have some puffy Orion 90c carbon pros, as well as an IP. I never even attempted more than 10 amps on the Gens I had, they got warm enough running a 10 min run on our large outdoor track.
Cheers, I hope your batts treat you well
Lon_L is offline
Old 04-29-2012 | 11:29 AM
  #22310
SCTDan's Avatar
I agree with no glue. I use a touch of loctite since I have had the nut back off. If you glue it you will have buy the whole pulley assembly with clicker ect instead of just the pulleys when they wear down.
SCTDan is offline
Old 04-29-2012 | 11:32 AM
  #22311
rcuser67898578 is offline
Old 04-29-2012 | 11:43 AM
  #22312
fq06's Avatar
Originally Posted by Johnny-RC
What are you guys doing as far as replacing the o-rings and washers in the diff's? I see A-main has a rebuild kit that come with everything including gears and shafts for about $14, but all I need are the o-rings and washers.
Don't really want to spend $30 to rebuild 2 diffs that only needs $4 in parts.
Also I hear you guys are shimming the outdrives somehow to help with the wobble. How are you going about this?
Lastly I guess you guys are also putting up travel limiters on the shocks to keep them from pushing against the out drivers when the suspension is compressed. Does this help with some of the premature wear of the o-rings and wobble of outdrives?
There are a few posts that give a part number for a buggy shim thats a little thicker than stock so you don't have to stack shims, forgot if it was a x-ray or ofna buggy part.
For sure clip on a 2mm and a 1mm spacer (total 3mm on each shaft) below the rubber bumper on the shock shafts to limit up travel or your stock a arms and the cvd will push the outdrive up and ruin the shim.
fq06 is offline
Old 04-29-2012 | 11:56 AM
  #22313
BlueGlowBoy's Avatar
http://www.amainhobbies.com/product_...r-5x15x03mm-10
1 under each sun gear.
Tons of time on this setup and haven't had to replace them yet.
BlueGlowBoy is offline
Old 04-29-2012 | 12:01 PM
  #22314
Old 04-29-2012 | 12:02 PM
  #22315
Old 04-29-2012 | 12:03 PM
  #22316
I got my VTS slipper finally the other day and put it in. Unfortunately, not even with lots of dremel work, I couldn't get the standard cover to fit over it.. I tried using a heatgun, but the plastic started melting at the center before it even got soft enough on the flat part to shape it at all. I am now leaving the screws slightly loose, it doesn't seem to rub that way.. bloody stupid of AE not to include the right cover with the slipper and giving it the same part # as the old one.. I ended up with an old set of covers due to that, of course.
I got a question about the other side of the slipper, though.. I run a high torque pad there, and it was glazed and showed clear signs of heat damage.. will the VTS slipper also take off the load of that side, or will I have to continue sanding down that side?
Arakon is offline
Old 04-29-2012 | 12:20 PM
  #22317
fq06's Avatar
OHHH ok maybe I will do that then. Does this take the place of the large stock washer, or in addition to it?
In place of, its thicker than stock so you dont have to run 2 washers.
fq06 is offline
Old 04-29-2012 | 12:23 PM
  #22318
Tech Legend
The limiter's (external) are just for as you described , limits the CVA from pushing outdrive on hard landings...
Don't use any extra shims inside diff , just replace any that that are not smooth & flat....
Advise to replace metal gears & shims together as both wear and need replacement together...
# 9831 seal set
#9829 gear diff rebuild kit
Old 04-29-2012 | 12:26 PM
  #22319
fq06's Avatar
Im pretty sure Marcus is making these for the ft slipper, they work way better than stock.
http://rcshox.com/shoxshop/catalog/p...dc5c8df2f52249
You may want to ditch the slipper though and go with his center diff. Way better than any slipper IMO.
fq06 is offline
Old 04-29-2012 | 12:27 PM
  #22320
Thanks man! I will for sure be putting the up travel limiters on.
Does anyone know if these are the same o-rings that are used in the 4x4? This is from the 2wd sc10.
http://www.amainhobbies.com/product_...ial-O-Ring-Set
If they are the same this would be great, but I would still need the large inside washer as mine are concaved and has a bad groove worn from the sun gear pin.
As far as shims go I have some Traxxas shims that i plan to stack.
Yes, those are the same.
These will replace the stock ones.
Sofa King is offline
