Serpent 811E Buggy Thread >
Like Tree5Likes
Old 04-19-2012 | 03:09 PM
  #2071
RCmayor's Avatar
Are you sure about that? Usually a company will advertise that on their site. that rccoh site isn't a Tekin site.
RCmayor is offline
Old 04-19-2012 | 03:57 PM
  #2072
mrnizzles's Avatar
Its too late on east coast (Indiana) to call, so I emailed them... will let ya know!
even though rccoh states "you can be assured"... its better to hear from the horses mouth!
http://www.rccoh.com/rc.companies/made.in.usa.html
Also, that page lists some other "vintage" RC manufacturers that I know are strictly made in the USA.. they've been around since before the whole "global economy" crap.
Parma, Kimbrough, Pactra, MIP, Robinson Racing, RPM.. these guys been around since the '80s! their as American and GI Joe n Cobra!
mrnizzles is offline
Old 04-19-2012 | 04:50 PM
  #2073
RCmayor's Avatar
If you have a RX8 check the packaging or product, one should disclose the country of manufacture. Usually if a product is made in USA it is plastered all over the product. They are designed here though, I think.
RCmayor is offline
Old 04-19-2012 | 05:28 PM
  #2074
ohiostatechamp's Avatar
I saw a company listed on the web-site that should not be listed. Kinda makes me wonder how the site did its research and if that is the only company listed.
from the rx8/t8 combo package. ESC designed and manufactured in the USA using foreign and domestic components. Motor designed by tekin USA: Made in China
ohiostatechamp is offline
Old 04-19-2012 | 08:21 PM
  #2075
Chad Millikan's Avatar
Well after finally getting my buggy built and running and having some time to run it, I only got to drive it for a measly five minutes before a broke a flanged frontdiff bearing. I was pretty bummed. I got some Tony's screws and avid bearings. Will see how she goes next time
Chad Millikan is offline
Old 04-19-2012 | 08:28 PM
  #2076
mrnizzles's Avatar
just got home to check packaging myself and u are right... damn... almost American. *sigh... its like going down the aisle in Home Depot...
probably due to the damn freggin magnets.. China is sitting on the worlds largest precious metals reserves...
Old 04-19-2012 | 08:35 PM
  #2077
schmoey's Avatar
Default rear shocks
guys i have a issue with my rear suspension, it seems to not have the body roll and seems to stiff. i am using the stock setup with the white springs a stock pistons. i have ordered the tapered pistons and lighter springs, you think that will fix it? i have used between 20-40wt oil in the rear and has not helped. what do you recommened?
schmoey is offline
Old 04-19-2012 | 09:21 PM
  #2078
bronc4now's Avatar
I'd try a lighter sway bar if you didn't try that yet..soft spring will help to
bronc4now is offline
Old 04-19-2012 | 11:59 PM
  #2079
bigjayjay1's Avatar
Check your droop make sure nothing is binding a good test take your shocks off the arms everything should drop fast. Also are you take a height measurmemt on the front and back check out the serpent site believe there are a few setups but as stated your sway bars are key make sure the balls that go in the arm are free if you over tighten the sway bar holder it will bind the bar attachment
bigjayjay1 is offline
Old 04-20-2012 | 07:01 AM
  #2080
Maxthepersonz's Avatar
You simply can NOT get a brushless motor made in the USA. Its impossible. The cost of the magnets in the USA alone cost 2x more than it cost's to buy the whole motor from china. This is because we have a more limited supply of the rock's than China does, and our workers will not mine it for 3 cents an hour obviously. The magnets are used in several of the U.S.M.C, Airforce, Army Etc... Aircraft/vehicle guidance systems and this is why there expensive. The motor and speedo are 100% designed in the USA but 100% [B]MADE IN CHINA[B]Just like every other electronics brand unfortunately
Maxthepersonz is offline
Old 04-20-2012 | 08:56 AM
  #2081
mrnizzles's Avatar
just dont tell me the "Baroness" was made in China... LOL
Old 04-20-2012 | 10:27 AM
  #2082
On the rear hubs the 5mm shims,what is the meaning of moving the shims 2.5 either side. Just that my rear end to stay one way when I lay down the power, shocks on 50 rebound blue springs front half weight down on oils,rear purple 553 hard packed mostly has we use it for 1/5 aswell so you can guess we have some loose corners,big straight aswell, was just looking for a good set up thanks
No Idea!! is offline
Old 04-20-2012 | 11:03 AM
  #2083
blade329's Avatar
The stock setup is definitely very stiff. Probably due to the way tracks are in Europe. I went to lighter front/rear sway bars and down to 30wt (from 35wt) rear shock fluid. I also moved the shocks one hole out from the stock position. Made a huge difference. I hear the webbed shock bladders also help.
blade329 is offline
Old 04-20-2012 | 01:29 PM
  #2084
I think the most costs comes from the labor of winding the wires etc. And yes, those ladies work for a couple of peanuts an hour...
Ive seen an official statement from Steve Neu about this. Not about those peanuts though...
puttekula is offline
Old 04-20-2012 | 01:41 PM
  #2085
RCmayor's Avatar
ya, but it only costs a few peanuts a month to live so it is all relative. Word is though China's cheap labor a bad environmental practices are catching up to them and it is actually starting to look better for US manufacturing.
RCmayor is offline
