Like Tree5Likes
SC10 4x4 Thread
Old 04-16-2012 | 08:37 PM
  #21586
JEFFs SC10's Avatar
Originally Posted by Mizchief
I would try goose bumps or bandlands if it's really deep and/or tacky.
depending on how loamy, wet, etc I recommend subcultures, Holeshots, bowties.
just see what the fast guys are running.
JEFFs SC10 is offline
Old 04-16-2012 | 09:06 PM
  #21587
kingkole's Avatar
any one have a rc shox v1 center ball diff they wanna sell or trade
kingkole is offline
Old 04-16-2012 | 09:13 PM
  #21588
PastaBoyNY's Avatar
Thumbs up
Originally Posted by CraigMBA
LMAO!
Well said!
PastaBoyNY is offline
Old 04-16-2012 | 09:15 PM
  #21589
tom2tone's Avatar
Quick question... What is the best replacement body for the stock body? I have to say the stock body is crumbling on me. I've only raced it about 8 race days and it's quickly falling apart.
tom2tone is offline
Old 04-16-2012 | 09:16 PM
  #21590
PastaBoyNY's Avatar
Originally Posted by Farmer_John
I think WC has had issue with his home made brace because it's a 2 piece aluminum tube from revo compression rods. I would imagine where the two rods butt together would lead to be a weak spot, where using a hacked off knitting needle would disperse the load along it's entire length.
Could be wrong though.
So far so good! I think it's the fact that the needle is 6.5mm and the length of threaded rod is 8-32. Not much room for deflection.
Sal
Old 04-16-2012 | 09:24 PM
  #21591
kingkole's Avatar
i have alot of good luck with the j concepts ford raptor x flow or hi flow
kingkole is offline
Old 04-16-2012 | 09:27 PM
  #21592
Hey guys what's best setup in shock oils and pinion and spur on grass and dirt track running a tenshock 411 4600kv
Zangetsu is offline
Old 04-16-2012 | 09:34 PM
  #21593
fq06's Avatar
Originally Posted by wolf16731
Might try playing with the push feature of my RX8. I hold the throttle in air and all of that goodness but maybe I am not realizing something. Once I get it figured out, then I will invest and play with the dual stage pistons.
Sounds like the track I race on. Loamy when wet with great traction from any tire and when it dries you have to really work to get any 2wd to hook and some 4wds. My SC10 4x4 loves the Proline Caliber 2.0, wet or dry.
I run my push setting at 20. Try even more just to pronounce the effect, it only takes a couple minutes in the pits to change it on your laptop.
fq06 is offline
Old 04-16-2012 | 09:37 PM
  #21594
fq06's Avatar
Same motor, I run 13/62. Start there and see what your temps are.
I come off a 7 minute main at 145 so there's more gear if you want it but its already scary fast.
fq06 is offline
Old 04-16-2012 | 09:38 PM
  #21595
What spur gear size
Zangetsu is offline
Old 04-16-2012 | 09:39 PM
  #21596
fq06's Avatar
What spur gear size
Just edited to 13/62.
My opinion is that the 32 pitch is the only spur to run and stock 62t has plenty of range you don't need to vary from that just play with the pinion size.
fq06 is offline
Old 04-16-2012 | 09:50 PM
  #21597
Wild Cherry's Avatar
[QUOTE=PastaBoyNY;10612967]Mr Cherry...dont knock it until you have tried it! My brace has yet to even Scratch! I made it before the FT brace came out and it has worked wonders. Seeing as you are such an AE Fan I have to wonder how you can use that brace made from Traxxas Parts? Isnt it going to break or bend? (grin). Not as good as the AE FT brace...........PRACTICE what you preach. Help others instead of knocking when they asked a simple question.
With unearned respect.....
I do practice what I say , look at my recent pics and you will see the new Team brace on my ride...
Not intending to diss your brace , only trying to recommend the best way & part that has just become available from Ae ...
Wild Cherry is offline
Old 04-16-2012 | 10:12 PM
  #21598
SCTDan's Avatar
I'm running 14/60 and temp 150 after a full pack. Pretty fast if you have good straight sections to run on.
SCTDan is offline
Old 04-17-2012 | 06:39 AM
  #21599
wolf16731's Avatar
Originally Posted by fq06
Are you holding a decent amount of throttle while in the air and not just up the face of the jump? Coming from nitro I was struggling with the same problem, my mbx-5 does not need nearly as much throttle held while airborne as my Associated does.
I also programmed in some push on my rx8 esc to help it roll through the tight corners and also in the air like my nitro does. To me even with no drag brake it feels like I am giving it a slight amount of brake in a turn when I try to roll through it. Push fixed that.
Don't know if you have a rx8, but if you do that may help and if not maybe your esc has something like it... not sure.
If that does not help, I agree with bumping up the rear shock oil because you ass end could be slapping the face on takeoff and kicking you.
Oh yeah, I forgot about your piston question. Yes, the rcshox pistons are great.
Originally Posted by Barrett50.cal
proline calibers
Originally Posted by easye
Is your drag brake set at 0?
Yes it is, lol. That I already thought of beforehand.
wolf16731 is offline
Old 04-17-2012 | 06:43 AM
  #21600
Default Thinking out loud.
I am not a fast racer and race for fun although I do try to improve my skills so I will not make comments about who is fast, faster, or fastest... but...
I love Associated but someone on this forum has their head so far up Team Associated's arse it isn't funny!
Lots of good stuff out there that works and works well. One manufacturer is not the catch all end all to answers of winning races! To close one's mind completely to other products demonstrates where that head is.
Stepping off my pedastal.
Ronborsk is offline
