Serpent 811E Buggy Thread
#1981
well got to race my buggy again yesterday and it didnt go so well. Car was very loose. I was basically a non contender. We had A threw D mains and I was in the middle of the C!!! Car would just spin out to easy. I had the correct tires on for the track as well. My current setup is close to stock minus blue front springs with 40wt. Yellow rears with 35wt, bottom inside hole on the front tower and inside on the hub, Rear, bottom inside hole on the tower, furthest outer hole on the hub. Opt 2 rack. If anyone has suggestions let me know. I went with the long rear camber link trying to slow the reaction down. Nitro car wasnt much better either but thats another story.
when was the last time you rebuild your diffs?
whats your sway bar setup? I would think softer in the rear instead of longer rear camber link. maybe stiffen up the front shock oil/springs as well..
I love nitro stories!
#1982
#1983
Finally got my pro painted bodies back from Paint Monster. http://www.freewebs.com/paintmonster/ He does awesome work and charges around $60 for 1/8 scale bodies. I've had him do about 7 bodies for me and they all came out great. Here are a couple of them.
The black and red body is one rattle can painted for practice days.
Absolutely loving my Serpents, very durable and they handle great. So far the only broken parts have been a shock standoff, wings and mount, and fuel tank post.
And lots of AKA wheels
#1984
Also check your diffs and make sure there is grease on the out drives. Some guys run them dry or don't maintainence them often enough and they can get locked up. Our diffs typically don't leak so you don't get the diff fluid on the outdrives like other buggies.
#1985
#1986
I rebuild my cars after every race day. Yes i use mobil 1 red grease on all the outdrives and o rings. My cars are very well maintained. Sway bars are stock. The setup i posted is all stock minus what i posted. The track conditions didnt change threw the day. Car was loose from the begining of the day till the end of the day. My nitro car has basically has the same setup on it and it had traction but it pushed all day but had traction. The track was bumpy as hell so i put chad phillps setup on it from the hut, since that place is bumpy as well
#1990
You can put some tape around the pack and leave a tab sticking up to use as a pull tab to get the batteries out easier.
#1991
Tony... sounds like your elec is opposite your nitro? the elec spins out vs. the nitro is pushing?
On the elec, start with a softer sway bar in the rear, stock is 2.5, so then 2.3 then 2.0. Also, stock front springs are pink, which is pretty soft, so try stiffen them up to blue or purple.
That should get you in a better direction.
Since the elec version of these cars have more weight front, I would think the nitro version is a little different, but I haven't raced one.. yet.
Soften up the front on your nitro a tad to to dial out some of that pushing. If you like the feel when jumping, then just try a softer front sway bar... then slightly softer front oil.
next would be a little more caster, couple degrees at a time. I love the caster adjustments on the front of these cars, very tune-able.
_
_
#1993
Ok cool just making sure.
Chad always said his car pushed so that sounds about right
Email me and I'll send you a few nitro setups to try [email protected]
#1994
#1995
I don't know if I missed the part or something but can you buy just the center portion of the motor mount that the motor actually mounts to? My motor slipped and "Slightly damaged it" just scratched I guess... Still sucks though. I think it'd be convenient to have them to change motors for different tracks easily.
@Vortexted those body's are sick!
5Likes
