RC10B4.1 FT/WC
Old 04-06-2012 | 12:24 PM
  #13456
Jake S's Avatar
Originally Posted by aeRayls
Try those greens on the truck with Losi 57's with 35 ae oil. Middle on tower inside on the arm!!!
what are you runnin in the rear with for losi piston & ae oil? 57s and 30?
Jake S is offline
Old 04-06-2012 | 12:29 PM
  #13457
aeRayls's Avatar
Originally Posted by idrummerboy13
no u don't. I feel they make me slower lol, car feels lazy. I am slowly going back. Full back, stock springs. 8mm chassis is always staying on tho. I may try standard. Why not.
I run 57 35 front and 55 35 rear. This is with no added weight to the truck!! When I ran weight I used 56 30 in the rear. I love both my cars with no weight. PM me if you wanna take a look at the full setup for b4/t4
aeRayls is offline
  #13458
Jake S's Avatar
My "go to" setup is ae 32.5 #2's in front and 27.5 #3 drilled 55 in rear.
last time i was out i was using 32.5 #1 in front (in/out) and 27.5 #2 rear (in/in) the buggy drove soo nice with 3-deg of rear toe. had alittle more steering then i really could use with the silver/pink so going to just increase the rear wing angle from 3 to 6 and keep it all the same.
i just wish i was as good as my cars
Jake S is offline
Old 04-06-2012 | 12:42 PM
  #13459
idrummerboy13's Avatar
silver/pink doesnt feel lazy at all
just wish i could find a front truck spring that would make it drive as good as blue/green.
green/pink reacts well on the truck, just feels like it needs stiffer up front... trying #3/32.5
yes your right, but i have not gotten my pinks i gave to someone who denys i gave them to him. :roll eyes: they felt great!!!
The old old car was and is still good. The problem from the beginning with the 4.1 was the chassis material. Way too soft and The whole car is made of it. Made it numb and dull on the track. The +8 is better in certain situations because it's made of the older (stiffer) plastic.
A properly built/setup and DRIVEN old school 2003 B4 is just as competitive.
We all just want new stuff to buy and play with!!!
yea the plastic sucks. Sorry, it just does. lol carbon is the way plastic should be as far as wear.
idrummerboy13 is offline
Old 04-06-2012 | 01:40 PM
  #13460
C Verano's Avatar
Default Spring Cups
I know its been answered somewhere but which spring cups are people using to run the Kyosho springs? Thanks!!
C Verano is offline
Old 04-06-2012 | 01:48 PM
  #13461
Asharus's Avatar
my 22 cups fit them fine
Asharus is offline
Old 04-06-2012 | 02:13 PM
  #13462
brian cox's Avatar
TLR5095
brian cox is offline
Old 04-06-2012 | 04:29 PM
  #13463
racer1812's Avatar
Super Moderator
I'ld like an AE rep to confirm that.
racer1812 is offline
Old 04-06-2012 | 04:34 PM
  #13464
If that's the case couldnt you run the carbon chassis instead of the +8 and get the same results?
PFKAOG is offline
Old 04-06-2012 | 04:51 PM
  #13465
just look at it , its carbon. the whole kit should be. or w.e losi and kyosho makes .
Old 04-06-2012 | 05:04 PM
  #13466
DanielC.'s Avatar
Going to give silver/ red a shot while I wait on pinks. Think that may be too stiff on the rear?
DanielC. is offline
Old 04-06-2012 | 05:06 PM
  #13467
racer1812's Avatar
Super Moderator
Chad Due is a local to me and never said the +8 chassis is carbon.
As far as I know the +8 from AE is the same plastic as the rest of the .1 kits
Old 04-06-2012 | 05:30 PM
  #13468
B.A. Racer's Avatar
I do not believe the +8 is carbon , But it is made of a different plastic than the regular b4.1 plastic. The old b4 plastic is stiffer than the .1 plastic.
B.A. Racer is offline
Old 04-06-2012 | 05:40 PM
  #13469
DanielC.'s Avatar
I think it is some form of FRP (Fiber Reinforced Plastic). Either Fiberglass or Carbon infused plastic basically. Could be wrong though
DanielC. is offline
Old 04-06-2012 | 06:30 PM
  #13470
mdwaeracer's Avatar
It's a carbon composite. Meaning that plastic and carbon mixture liquid injected into the mold. I've had all three b4, 4.1 and now wc. The material seems to be exactly like the ft b4. The +8mm calms the vehicle down.
mdwaeracer is offline
