SC10 4x4 Thread
I love the set-up and the weight distribution it provides. This build is my RE-introduction back into racing as we retired from racing in 2004. I'm looking forward to getting back into action with this rig.
Previously we ran 1/8 buggy and truggy. With these trucks, we can FINALLY race each other!!
No more pitting for each other.
I am now debating on whether to run stick packs that I have 5500 60c reedy packs, or the saddle packs gen ace 25c 6000 mah(if they will fit they are slightly shorter and more narrow, but are 5mmish taller. Don't want to buy new saddle packs right now. Which way would you guys go? Less c batteries(if they fit) and better balance, or more power. At the moment I am leaning toward the saddlepack setup.
http://www.hobbies4life.com/Associat...p/asc29222.htm
And that's most likely the best price you'll find it for too!
2.4ghz antennas are really short, next time you should try to keep the antenna inside the body so there's no chance of it getting ripped off.
hey guys,
i was taking the car apart to shim the rear diff and noticed that the washer that sits against the thrust brearing of my centerdiff is hollowed out like a hat and I didn't remember it being like that when installed. just wondering if the 2 washers that sit inside that pulley are supposed to be the same or if the hat design is correct and for the thrust bearing balls to run in.
thanks
jody
thanks
jody
also if anyont has a pic of where the shim goes to keep the rear diff from clicking that would be great. i know its the sun gear but this is my first time in an rc diff so just want to do it right.
thanks
jody
thanks
jody
A couple of users have already built them.
http://www.rctech.net/forum/electric...c10-2-4wd.html
jody #91007
1 small washer on outdrive first,
then insert outdrive into diff case,
install 1 large washer inside case on outdrive
then install pin, then install sun gear
5Likes
