Like Tree5Likes
SC10 4x4 Thread
Old 03-20-2012 | 09:11 AM
  #19561
vito's Avatar
they say the c s much higher that on the pack
vito is offline
Old 03-20-2012 | 09:16 AM
  #19562
Cain's Avatar
They most likely underrate there C value. TrueRC lipos does that or at least, that is what people say. So if you need say a 30C pack, and it really performs like a 40C, great. Better that way than a 20C pack actually being overrated at 30C.
Cain is offline
Old 03-20-2012 | 09:31 AM
  #19563
rcmark17's Avatar
MY truck was running good this past week with the blue FR on. Then this past Sunday after our oval racing we setup a new layout,took the truck out for some quick laps and thought it felt good and was happy with the times I was getting. The local hotshoe then asked to try a couple of laps and beat my best time by 1.5 seconds. So guess it is not the truck at times but maybe the driver
rcmark17 is offline
Old 03-20-2012 | 09:37 AM
  #19564
vito's Avatar
i got my set up from the new guy in town its a novak sport man gbt 2 esc with a 550 4.5 trun motor a dxs c radio with a sr 300 rx and 12 62 gearing to start with.
vito is offline
Old 03-20-2012 | 09:39 AM
  #19565
Mizchief's Avatar
Yea to me the "C" rating should be how much current it can supply before any noticeable drop in voltage, not how many amps you can pull prior to it catching on fire which I what I think the cheaper guys do.
Mizchief is offline
Old 03-20-2012 | 10:39 AM
  #19566
Cain's Avatar
LOL. I had that happen to me in a way with 1/8 E buggy, a super fast driver wanted to try it out as he was a nitro guy, and promptly was whipping up on the track. He commented on how much steering my buggy had ... I thought it was not enough.
Make sure and get a glitch capacitor just in case.
Some of the expensive guys have C Ratings that are not really clear, and unfortunately, have removed the "clarifications" from there site.
Cain is offline
Old 03-20-2012 | 10:42 AM
  #19567
Speedteck rc has the orions for 89 dollers, it says out of stock but he gets them too u in a week
rickybobbyxxx is offline
  #19568
vito's Avatar
i have one cap. did i miss some suff like a bec and do i need one.
vito is offline
Old 03-20-2012 | 04:47 PM
  #19569
SPEKTRUM Plus 1
Reedy 4.5 550
Reedy 5200 60c
Lrp V2 Sxx
Xp DS 1015 digital servo
Cherry, any reason for double the fun on the chassis braces there?
AzFittin is offline
Old 03-20-2012 | 04:48 PM
  #19570
Originally Posted by ilanstylz
Your servo is a great choice, but unf. the spektrum tx/rx's are one of the major reasons why setups get brownouts especially using a HV servo like the s6100....... I am not familiar with the LRP SXX for a 4x4 so I couldn't tell you if it could handle a S6100 and a tenshock motor especially with it being paired with the spektrum tx/rx.......... I know you said you like to be different but to me the tekin rx8 is the best esc you can put on the sc10 4x4 (out of ones I've tried, I hear good things about Orion's R10 pro as well though)..... So if others can chime in on the LRP Sxx on whether or not it would work would help out. Also get really good lipo's, I personally don't run anything that has lower then a 40c rating (sometimes I'll use a 30c but that's just to mess around with)..
Sorry this is kind of unrelated. But, i've got a spektrum tx/rx and planning on getting the same spektrum servo 6100, except with an orion 550 4.0t motor. Already got the r10pro. Even if the servo is on on a voltage regulator, would the esc still be able to handle it? Thanks!
Eaglesrx is offline
Old 03-20-2012 | 04:53 PM
  #19571
ilanstylz's Avatar
Unfortunately I couldn't answer you, I have no experience with the R10 pro......
I don't think spektrum HV servo's are as bad as the savox ones so I don't see an issue but I'd still install a cap just incase.....
ilanstylz is offline
Old 03-20-2012 | 05:45 PM
  #19572
Does anyone run the smaller 32 pitch spur gear(smaller than the 62 tooth, I think its a 58 tooth)? If you do what pinion size are you using? If I was running say 12/62 and put the 58 spur in will a 14 pinion make the same equal performance as the 12/62?
coconut is offline
Old 03-20-2012 | 06:04 PM
  #19573
darryl80's Avatar
Cool
what are good front and rear sway bars?
darryl80 is offline
Old 03-20-2012 | 06:07 PM
  #19574
darryl80's Avatar
Thumbs up
how about these sway bars?
http://www.ebay.com/itm/Hot-Racing-A...item231ab5d74f
darryl80 is offline
Old 03-20-2012 | 06:15 PM
  #19575
JEFFs SC10's Avatar
go with the factory sway bars.
I believe my spur is a 60 tooth, I run a 13 tooth pinion with a 4600 and come off around 146 deg.
just divide the pinion into the spur and get your ratio.
JEFFs SC10 is offline
