Like Tree5Likes
SC10 4x4 Thread
Old 03-10-2012 | 11:55 AM
  #18961
BigBrute_347's Avatar
Default Ball stud spacers
What are some of you using as ball stud spacers? Also, what is the thread size of the HD ball studs? Does AE make 1 mm spacers this size? Thanks!
BigBrute_347 is offline
Old 03-10-2012 | 12:15 PM
  #18962
Mac The Knife's Avatar
thread size is 3 mm, and for spacers,,, https://www.ssl-stormerhobbies.com/c...=ns&pn=ASC4617
Mac The Knife is offline
Old 03-10-2012 | 12:33 PM
  #18963
SCTDan's Avatar
I just use 3mm flat washers from the hardware store.
SCTDan is offline
Old 03-10-2012 | 12:45 PM
  #18964
Thanks Mac and Dan!
Old 03-10-2012 | 02:11 PM
  #18965
vito's Avatar
what esc to use with a new reedy 550 motor ?
vito is offline
Old 03-10-2012 | 03:21 PM
  #18966
I really like my Hobby Wing Exrun 150amp esc. I run it with a Novak 5.5 Hv motor
sbrewer is offline
Old 03-10-2012 | 03:37 PM
  #18967
Originally Posted by JEFFs SC10
Well Max Flurer was running the FT SC10 but dont know his setup and haven't seen his truck with body off. He TQ'd in 2wd at PNB which is awesome and is 2nd in 4wd sct.
Also, I think he got 2nd in 4wd sct on a big, 1/8 size track with loose dirt with his FT sc10 4x4.
Eaglesrx is offline
Old 03-10-2012 | 03:49 PM
  #18968
vito's Avatar
iam thinking mmp or one of the lrps or rx 8
vito is offline
Old 03-10-2012 | 04:13 PM
  #18969
vito's Avatar
some one got pics of a jc ford hi flow body with the vent in back opend up?
vito is offline
Old 03-10-2012 | 04:17 PM
  #18970
JEFFs SC10's Avatar
Had a good test n tune session today. I ran at a much better prepped track, smooth, very fast, hardpacked, clay, with some loam on top, medium traction.
This was my first time running on this track in weeks, so I was excited!
I had to drop down to a 13 tooth pinion, I was temping 187 with the 15 tooth.
came off at 143. Ran the front blue springs on the rear, once I set the ride height correct the truck really was awesome. I have to learn not to drive so aggressively, the truck really does reward you for driving smoothly.
As far as jumping goes, the truck was nose down or level the whole time. I had my drag brake set at 10 and I think this is what was keeping nose down. I could give it a quick blip to bring up the front so it would land on all 4.
I first ran on double dees and it was fun dong the powerslide in turns but that's not really my style but its great if you nail it. I was also pushing on the turns. I(f they blow off loam tomorrow I'll go back to these cause they were working pretty good.)
I moved the shocks in board on the bottom and switched to Subcultures on on stock rims and got more steering. Truck ran great. I just have to watch my trigger finger but the truck is so much better now than the last time I ran at this track.
the only thing I want to try is bumping up shock oil 2.5 wt all around cause it was absorbing the bumps but looked a little too soft.
also ran with the new body, love it jconcepts silverado hi flow bright orange!
so I'm going to keep fine tuning. Overall pretty happy with the truck. Just need to work on getting more practice.
here's some pics of the track and my ride. track is about 95 x100
Attached Thumbnails SC10 4x4 Thread-imag0710.jpg   SC10 4x4 Thread-imag0712.jpg
JEFFs SC10 is offline
Old 03-10-2012 | 06:22 PM
  #18971
lodhammerdin's Avatar
LRP SXX TC SPEC v2 or Tekin RX8 would be my suggestion.
lodhammerdin is offline
Old 03-10-2012 | 06:32 PM
  #18972
vito's Avatar
http://teamassociated.com/lrp/parts/details/LRP80955/
is this the one ty
vito is offline
Old 03-10-2012 | 07:28 PM
  #18973
JEFFs SC10's Avatar
you will have to solder wires from the esc and to the motor. and solder a deans connector.
I added another washer to my rear camber link, hoping that helps it bite harder in the turn.
Old 03-10-2012 | 07:42 PM
  #18974
vito's Avatar
i have a friend back in ny that will hook it all up for me. i just pay the shipping to him.
vito is offline
Old 03-10-2012 | 07:49 PM
  #18975
MantisWorx's Avatar
Adding the link in the rear doesnt add bite , it adds rotation early in the turn. The 2 stage pistons are going to look soft, thats how they work. dont worry about how it looks, concern yourself with laptimes and how it feels. Worst thing you can do is add oil so it "looks" like every other truck. The stiffer you make them the further away from their benefits you get.
MantisWorx is offline
