SC10 4x4 Thread
Craig, would u think that due to rear weight bias that the rear should be sprung heavier than the front. Only have one set of yellow fronts and thinking of running blue fronts and yellow rears. Not sure if this is correct. I saw u run yellow fronts front and rear but if a heavier spring was available would u run it on the rear. Just curious.
Where can I get a good deal on some scales. Anyone?
I'm going to take some liberties with the next paragraph because I don't want to write a novel on the subject. Suffice to say, there is some debate out there on what wheel rates are supposed to be. For a passenger car, the rear wheel rate (chassis spring rate once you correct for the angle and the leverage of the control arms and the tire) is usually about 20% stiffer than the front, assuming 50/50 weight split front to rear. This is mostly for passenger comfort because the front wheel hits the bump first and you'd like the harmonics to be slightly different. Many race cars run the rear softer because the driver likes it that way. And that's not wrong.
For the last couple of race days, I've been calculating wheel rates/wheel frequencies on any chassis I can get my hands on (user Oasis Losi included). None of them were as poorly mismatched front to rear as the out of the box SC10 4x4.
You might find the yellow front (front) and blue front (rear) to your liking. If you already have the parts, I'd recommend you go that way and see if you like it because it won't cost anything.
http://www.amazon.com/Digital-Pocket.../dp/B0042E4AG0
You need a flat surface, a bubble level, and a way to level the flat surface if you expect your weights to be consistent and accurate.
Wow, looks good to me. Think I'm gonna order one. Gets around 110-115 in the summer here, the extra cooling can never hurt.
Have tried other motor's. \
Keep coming back to my Novak 5.5 Ballistic 550 ...
16T , Lrp SXX using a lot of boost(6)
Found the Novak's power is perfect for the tracks I run on , not to much rip, smoothest motor I have run yet .
Comes in about 130 to 135 & I get 15 min run time easy...
Unless there's someone on here in your area the best bet is to try it yourself if you feel comfortable enough, here is a video that shows you how:
There are a ton more on youtube on how to solder so you may want to watch a few for tips and tricks...... One tip I can offer is to take your time and make sure you have the right equipment.......
| + YouTube Video | |
| + YouTube Video | |
5Likes
