Like Tree5Likes
SC10 4x4 Thread
Old 03-05-2012 | 10:01 AM
  #18661
Mizchief's Avatar
Originally Posted by Attacker
Thank you very much for the reply, very helpful. So I think my first step is to properly run the truck, with my setup, just checking temps, then gear accordingly. Hopefully, the 25c packs will be enough.
How could one go about figuring out what amps a motor will draw?
Also, if I am to go up to a 3s, which I won't, but just for knowledge sake, would the amps go up or down?
I might be way off, but I heard the 1410 has an amp draw of 160A, and with my calculation, my battery's will only be able to supply 75A, is this correct or am I wrong?
Cheers
Ramon
It's kind of a crap shoot on land. I come from an Air background as well and with air it's easy to static test with a cheap amp meter since draw sitting on the bench pulling against the plane while attached to the ground is pretty much the most amps you could expect in air (except for heli's with all the 3D stuff) where a car it's really hard to measure in real time. You can probably find a meter that records max amp draw and let it ride around the track with the truck, but point is that you really don't need to think about it that much.
Basically you buy the ESC rated for the scale/class of model and smoothness of throttle, programming options, etc. become much more important than how much power it can handle since the most popular ESC are fine.
From there it's all about motor temps and gearing just high enough to get top speed on the fastest part of the track without over temping the motor or ESC. Usually the motor will have heat issues before the ESC in my experience.
Mizchief is offline
Old 03-05-2012 | 10:05 AM
  #18662
CraigMBA's Avatar
Slightly OT:
What chassis did Mark A. run? I used to race with him at SoCal, he was no slouch as a driver and an even better wrench.
CraigMBA is offline
Old 03-05-2012 | 10:09 AM
  #18663
Cameron Kellogg's Avatar
Originally Posted by Wild Cherry
hey cameron !
nice job dude ....
Thanks! AE did well in Kyosho's house.
Taking the win in
2w mod invitational
4w mod
Truck mod
4x4 SC
Cameron Kellogg is offline
Old 03-05-2012 | 10:11 AM
  #18664
pakk's Avatar
Originally Posted by JEFFs SC10
You're running way too heavy shock oil. go to 25-30 all around. Then your shocks will actually compress and absorb the landings. Also run them as emulsion, that should help.
My tuning skills are not very good, but I was thinking that direction. I did go from 37/32 and found that 40 all around made the truck handle the turns better. Since then, I have been playing with roll center and feel the truck is very dialed in the turns. I just need to get the right combo now. Maybe messing with the shock oil was a mis-stepped dirction.
I'll try 27.5 all around and go from there.
pakk is offline
Old 03-05-2012 | 10:12 AM
  #18665
Originally Posted by CraigMBA
Slightly OT:
Losi
Yeah Mark is very good and we battle often.
Old 03-05-2012 | 10:14 AM
  #18666
jsamarin's Avatar
i would try 35f 30r, or 30f 25r
jsamarin is offline
Old 03-05-2012 | 10:26 AM
  #18667
Cain's Avatar
Tech Legend
If I were you, I would put a 4mm limiter inside of the shock (which I'm assuming is too much) and adjust from there. If you need to unscrew more than 2 turns, I'd take the shocks apart and pull out 2mm of limiters.
Particularly with the 550 motor, I would not be afraid to go straight to yellow fronts in the rear if blue fronts made it better. Frankly, if I could get a spring that was stiffer than yellow fronts, I would - and I'd put the 550 back in.
Thanks for the info. I am definitely going to try more front springs combos on the rear and see how it goes as the blue felt really good.
Cain , your set-up looks really good .
Your set-up is almost just like way I run my ride ....
Rolling over ?
Try installing external limiter's on all four shocks , use 3m or 4m thick spacers.
Picture of your track ?
Do you run on carpet?
Here is a link to pics from one of the races. The track configuration is different now, but gives you an idea of the available space.
Can you elaborate on what the externals will do? I don't play much with limiting the uptravel of the shock unless I had an issue it was causing like part damage on other vehicles.
As it stands, the current setup may only need a few tweaks.
What swaybars are you using? Are you playing with roll center? Try a simple 2 mm washer in rear camber link under shock tower.
I didn't have time to play with any of that as I was running 3 classes, and pretty much cornered before the next class started. The swaybars I am using are yellows all around.
Originally Posted by rcmark17
I just installed a Tekin 7.5 550 sc4x paired to a GTB last night. The indoor carpet track i race at is 60x40. I geared it at 62s-14p the motor never went over 100* with 20 minutes of run time on it and it ate up all the other lousys there. Also to help with my rolling over it has been lowered and 125000 oil in front diff and 30000 in rear diff. Not sure if it is right but drives smooth and works for me.
Considering I was running a 5.5 with a 13T pinion, 62T spur on what I think is a smaller track, I can see why my temps were higher than I liked.
The 7K Front, 5K rear felt really good. I should get in some 10K to try again, just wish I could get to the front diff a little faster LOL
I do get a bit of rear bounce off of the jumps, basically smacking the rear end more than what I would call normal. I think I will up the oil a tad there, maybe 2.5W more and see how it goes too.
Unfortunately the track is an hour away and the practice times available are during the week, can't make it.
Cain is offline
Old 03-05-2012 | 10:39 AM
  #18668
Wild Cherry's Avatar
Tech Legend
Cain , I race at three Indoor tracks in the Puget Sound area of Washington state.
BRCR , TRCR, 4-Seasons
all clay , bout med in size , med traction conditions for all.
The external limiter will stop the truck from tipping over as far as with out.
, will stay more level on sharp turns .
external limiter good solution for roll over problems on tight layouts
Wild Cherry is offline
Old 03-05-2012 | 11:19 AM
  #18669
Cain's Avatar
Tech Legend
Thanks. I'll look into giving that a try as well. I can easily use some clips I have that will fit on the shock shaft to do the limiting quickly.
Really wish AE had made the option for droop screws somehow ...
Cain is offline
Old 03-05-2012 | 11:31 AM
  #18670
Tech Legend
So U know
I never use droop screws , a little dirt or a small rock & your droop gets "screwed"...
Internal limiters will never have that issue ...
The clips will do great , I use Ae 1/10th pistons ,looks yeah know ..
Old 03-05-2012 | 11:50 AM
  #18671
ilanstylz's Avatar
2nd day out yesterday and I'm still not very happy with how this truck lands. It's not very forgiving. The truck has to land perfect or else it tends to bounce on landings. When it does land perfect, it's perfect. But I'm far from a perfect driver and I'm looking for some forgiveness in the landings. Everything else on the truck seems to be good and handles good. I do have the 2 stage pistons, but I wanted to get a few more race days under my belt to really compare how they do.
Currently I'm running yellow front, blue rears, and 40wt front and back. I forget what pistons I'm running.
What direction, as far as tuning, should I be going to trying to help this?
I'm no expert so maybe Mantis or some others can chime in, but I think your problem is the shock oil, IMO your running to heavy a wt for the front and rear. If I remember correctly Mantis states that a good starting point is 20w rear and about 25w or so in front. And I read somewhere he stated that if you use to heavy wt shock oil can damage the lower piston. So try dropping down your shock wt and see how it goes from there.........
ilanstylz is offline
Old 03-05-2012 | 11:54 AM
  #18672
Cain's Avatar
Tech Legend
So U know
I don't dissagree limiting is better overall, but to quick test out a setting, definitely easier.
Cain is offline
Old 03-05-2012 | 12:05 PM
  #18673
pakk's Avatar
I believe you are referring to the starting point when running 2 stage pistons. It does seem to be the consensus that my shock oil is heavy though. I'll give it a shot.
pakk is offline
Old 03-05-2012 | 12:12 PM
  #18674
CoyoteSlash's Avatar
Taking the win in
2w mod invitational
4w mod
Truck mod
4x4 SC
All Cav? Or what did he race? I avoided the place like the Plague all weekend.
It is 'way' too heavy.
CoyoteSlash is offline
Old 03-05-2012 | 12:48 PM
  #18675
Cav just raced 2w mod (Invitational class) and Mod truck. The Locals took care of the rest.
in A1 of Mod truck he ran the last two laps on three wheels and still took the win. He did loose A2 pretty fair and square then punished everyone in A3. Fun to watch for sure.
