Like Tree5Likes
SC10 4x4 Thread
Old 03-06-2012 | 07:28 PM
  #18766
Mizchief's Avatar
Originally Posted by jodyfj40
Guys I am stiil trying to figure out the clicking under hard acceleration and turning. I looked it over and also had the LHS tech take it apart and he said the rear diff was good but found a bearing going bad. replaced all the hub bearings and and it still clicks. I wanted to make sure it was in the rear so i removed the belt and the clicking is still there. Also the motor is still running hot which I feel may be related to the clicking issue. Please help
Jody
Headphones?
Mizchief is offline
Old 03-06-2012 | 07:35 PM
  #18767
Originally Posted by Mizchief
However by that logic they also repel bears since I haven't been attacked by a bear since then.
jzpilot is offline
Old 03-06-2012 | 07:52 PM
  #18768
Jody, make sure that the diff and idler gears are installed correctly. Move the pinion away from the spur and make sure the topshaft spins freely (belt off). It should spin very free. If it doesn't, check to make sure you have the motor plate screws in the correct positions. One is longer than the other two. The long screw might be rubbing the inner slipper hub.
Good luck!!!
rcmiket is offline
Old 03-06-2012 | 07:58 PM
  #18769
Devigili22's Avatar
Originally Posted by lethal19
its really not that bad I took out the 5 screws and removed the front of the chassis then took out the longer screw holding the top of the steering gear in and removed it off the chassis.
The hardest part that I struggled with for a bit was making sure I did not mess with the belt much but since I have done it a few times over the last few days I think it gets easier and easier everytime
Not really sure about which 5 screws you are talking about, sorry.
Devigili22 is offline
Old 03-06-2012 | 08:10 PM
  #18770
Cameron Kellogg's Avatar
Originally Posted by Sofa King
Dude, you take the belt covers off, but worry about mud guards for the rear arms..... on an indoor track?!
I am sponsored by DE Racing. I run all the products my sponsors offer so to rep them the best I can and so racers can see what they offer. I do run the rear gear cover but not the belt cover.
You should see the belt without the cover you would would be surprised how much it flexes, vibrates and hits inside the covers.
Cameron Kellogg is offline
Old 03-06-2012 | 08:16 PM
  #18771
CraigMBA's Avatar
Originally Posted by ilanstylz
Should I have weighed them without the tires for a more accurate total, and I remember people mentioning things about cross weight how is the weight on either 4x4 good or bad when talking it comes to the cross weight?? Thanks
I use grams, but if you're using oz that's fine too.
I always weigh with tires on, ready to run, less the body. That way I can quickly weigh at the track quickly and without any changes. When they are new, I weigh the tires and write on the inside of them how much they weigh. Occasionally I'll reweigh them to make sure I didn't fill one of them full of loose dirt when I was running it.
Cross weight is where you want the LF+RR=RF+LR weight. Your SC10 has wedge one way, the SCTE has wedge the other. Some users really care about getting it 50/50 left to right, I could care less because all I care about is getting the cross close. Getting it perfect is an impossible the scales aren't perfect. IMO within 5-10 grams is close enough.
I have no idea how you got a Losi that light. Off the top of my head, the one I weighed was like 400 grams heavier than the AE truck. Yours appears to be that much lighter. I was not aware it was physically possible to strip 800 grams out of the SCTE. Not that I doubt your numbers, but are you sure you got the scales on and zeroed before you weighed anything?
CraigMBA is offline
Old 03-06-2012 | 08:26 PM
  #18772
ilanstylz's Avatar
Yeah I haven't used the scales much but I did make sure to read the instructions completely and waited for it to be zeroed before I put the losi on. If you look on the losi scte thread there is another losi that was weighed in at 5.10 lb's........... As far as how its done I can't really tell you lol as I bought the scte this way. I know it has all the bells n whistles to make it lighter such as the chassis, tlr tuning kit, etc etc.........
ilanstylz is offline
Old 03-06-2012 | 08:38 PM
  #18773
Jody
Mine clicks too under acceleration. Sounds like I have baseball cards in my spokes. I've gutted it and rebuilt it, hoping to find something. Idlers fine, outdrives only semi wobbly (replaced not too long ago), and no obvious binding. Found my front tensioner was up at 0, but otherwise Stumped. I did the bearing in a bearing diff trick since I had 'em out. Clicker didn't seem blown out. Hoping it was front belt...
maddysdaddy is offline
Old 03-06-2012 | 09:40 PM
  #18774
I installed them on day one of the build and haven't had any issues. I had a lot of problems on my ruslter with the stock shafts bending till I got the Ti's for it, so I figured it was the thing to do.
Difference there is that the traxxas shock shafts are weak chrome steel, and the TiN shafts are hardened steel with TiN coating.. they'll only be tougher if they also used hardened steel instead of a softer steel in this case too.
Arakon is offline
Old 03-06-2012 | 10:13 PM
  #18775
Oasis's Avatar
It was my Losi that was weighed..and it's not stock, it has the Bump chassis, TLR tuning kit, Lt wt out drives, Ti turnbuckles and it's still a tank..
Oasis is offline
Old 03-06-2012 | 10:17 PM
  #18776
CraigMBA's Avatar
I wasn't going to throw you under the bus, but since you piped up....
Do you think it's possible to strip out another 800 grams and retain a rolling chassis without tossing out the motor, battery, and half the driveline?
CraigMBA is offline
Old 03-06-2012 | 10:35 PM
  #18777
Wild Cherry's Avatar
Originally Posted by lodhammerdin
I did not get lucky sir and your bet is wrong, sorry.
Temp's are right around 160-170 depending on the ambient temperature.
that about the time I could expect so its not luck . At Trcr I get a bit hotter, maybe due the extra traction @ Trcr & my fat trigger finger..
usually came in 180 to 195 ..used a 12T
Wild Cherry is offline
Old 03-06-2012 | 10:42 PM
  #18778
Oasis's Avatar
I don't know where their losing it from..I have most of the "big" weight loss items and I'm not sure where the 800 grams more would come from..maybe if you ditched the battery tray and ran a 380 size motor....I'm not doubting that you could lose some major weight but I'm shocked that some of them have them down to 5.8 pounds race ready..my SSC Slash weighed 6.2 pounds race ready....what wt oil are you running in the SC10..yellow springs..?
Oasis is offline
Old 03-06-2012 | 11:00 PM
  #18779
CraigMBA's Avatar
37 front, 35 rear, 1.2 conventional pistons both ends, four 4.8 rate yellow springs. I building up another set of shocks with 1.1 pistons just in case I don't have enough pack in the rear.
CraigMBA is offline
Old 03-07-2012 | 01:20 AM
  #18780
I heard from other drivers that the clicking you describe might be coming from slop and abnormal wear with the sun gears in the diffs. One driver suggested using the diff outdrive washers as shims on the inside of the diff, between the sun gear pin and the sun gear washers. See page 8 of the kit manual. This tightens up the mesh between the outdrives, the sun gears and the diff case. I hear that over time, the sun gear washers become concave, creating the clicking noise. Doing without the outdrive washers evidently doesn't hurt the diff or the outdrives.
Some find they only need to shim one sun gear. Others shim both sun gears. Also, if you have a nitro clutch shim kit, you may find something that will fit. Of course, you can buy a diff rebuild kit for about $11 and use those washers to shim the diff. You want to eliminate the slop while still allowing the gears to easily turn without binding. I plan to do this when I tear down my diffs next time.
Steven
PT Raceway in Green Level, PA, indoor carpet off-road & oval
AE SC10 FT, AE SC10 4x4, AE T4.1, AE B4, AE B44 FT
SBWheels2008 is offline
