SC10 Thread
After doing a lot of reading and testing, I came across something I thought I would share with you guys to make your day.
The center bushings in the AE shocks cause the shock to bind. We have discussed this in this forum. I found it doesn't just do this when the shock is at full extension, but it also does this when the shock has to change direction.
The bushing is 3.6+ mm thick. I found that if you sand it down to 3.45 mm and then slightly break the inner sharp edges (edges on the shaft) with a body reamer, you can make the shocks much more consistent.
The end cap on the bottom of the shock is a little tight as well. Again... just simply taking a body reamer to the inner edges relieves this as well.
Your shocks will build better and you will be able to match rebound as well.
The on track performance is significant.
Have fun!
TEX
Have fun!
TEX
I love the gear diff. I put 3000 in for my SC10 and run 2000 in my B4. I have not found any reason to change back to a ball diff. Everyone that picks up my car ask how often I rebuild my diffs because they are always spot on. I don't have to rebuild them and have not found any reason to move away from using them.
If Cav or Maifield kick my rear end... I highly doubt it would be because of the ball diff they are using. I'm old and slow!
The gear diff just makes these classes very relaxing to race in.
Gear diffs.
Lipo batteries.
Brushless motors.
Now we just race.
My 2 cents.
TEX
Gear diffs.
Lipo batteries.
Brushless motors.
Now we just race.
My 2 cents.
TEX
The batteries in it are rechargeable and it shows full power on the transmitter. I have never heard a transmitter beep continually like this one does though. I just waterproofed my electronics with liquid electrical tape though if that would have anything to do with it.
Why on earth not?
Seriously, I don't think the diff balls are any big deal, but the thrust balls are a ginormous big deal. Best $9.65 I ever spent on my SC10 - that's thrust balls and diff balls AND shipping.
http://www.rctech.net/forum/r-c-item...ce-rctech.html
And if anyone if looking to switch to ceramic balls, you DEFINITELY should check out the link up above that Craig posted... they are excellent balls, at a truly unbeatable price (and "no", he didn't pay me to say that
So has anyone had any success with the Gear Diff?
I setup this balldiff, using a guide sticky on the offroad forum, and It's grindy as Hell. I flopped the disks and did it myself and although the diff is "working" it still sounds like ass. I have new plates and balls, I just am at the point where I don't want to bother. I love tuning with the rear diff oil like my 4x4, but I know if you're anybody, you run a balldiff. As I followed the guide to the T, it slipped so much it wouldn't even go. so I tightened it up to a grindy sounding clusterF.
Should I just start over with new balls and plate? Or has anyone had any luck with a 5k Gear diff or so?
I ran a ball diff in my B4.1 than a gear diff. wasn't able to feel any advantage over the ball. I put some Ofna 3k diff oil in the gear and off I went. works just fine. I have ran my fastest laps with it.
I just got sick of the always needing to adjust it or rebuild it, making sure it doesn't slip.
I have reinstalled a Ball diff just to see how it felt now. I went back to the gear diff. just fits me better I guess., just my opinion
Ball diff, gear diff....I believe it's situational on the track type and personal driving styles. If you check the AE setups you will notice some guys are running gear diff's with good results.
From my short time running Short Course trucks I've noticed a bit of difference in the diff's. Now, this is just my experience with the two diff's and no setup changes were changed other than the diff.
Gear diff = Worked really well on high bite tracks where traction is good. I got great steering while on the throttle and it had no problems with side traction or forward bite. The problem for me is, that's not the type of dirt at my closest track. It's clay with OK traction when wet, but once it dries out it's slippery. When I try to get on the throttle mid turn with the gear diff, it would loose traction and spin out fast and forward bite was not so great as it wanted to fish tail on the straits. I did try different diff oils, but results for me were the same.
Ball diff = Worked really well on medium to low traction type dirt (did not drive it on the high bite track). I was able to get on the throttle more aggressively coming out of corners and it stopped spinning out and fish tailing. Which was great for my local track. The one negative I noticed was that I lost mid corner steering while on the throttle. So I had to drive it harder into the corner and square up before I got on the gas or feather the throttle through the corner.
I'm going to make some chassis adjustments to regain some of the on-power steering while keeping the ball diff as I preferred it in this truck. Which is a bummer for me since I'm a gear diff guy from my 1/8th scale days and tons of diff oils to choose from.
This is just my interpretation and experiences as I'm not a Mechanical engineer (just a career Mechanic by trade) and know the design philosophy behind the gear diff vs. ball diff.
On a second note:
The word around the water cooler(track) was to use carbide balls in the diff and ceramic on the thrust bolt. Yes the ceramic bearings will last longer than the carbide but were more susceptible to slipping because of the hardness and low friction. But worked fantastic on the thrust bolt.
I can see this have some kind of truth to it as I used ceramic bearings (17+ years) at work (which are water lubricated and impervious to harsh chemicals) and the reason we use ceramic bearings is because of the hardness and low friction. Which makes them very dependable.
Do any of you notice them slipping and have to tighten them a bit more than the carbide?
On a second note:
On a second note:
On a second note:
Just a quick question... I noticed after doing the JConcepts 12mm hex conversion and buying JConcepts 12mm hex wheels with BarCodes on em, it seems as if my tires stick out a bit more from the Pro Line Pro 2 Silverado body. They almost get stuck in the body when I push down on the rear suspension.
Did I buy the wrong flipping wheels?
I run the jconcepts hexes on my truck with jconcpets hazard rims with no problems. It's right at the ROAR legal limit. Can you post a pic?
The hazard rims have a 3mm off set so they will stick out farther than the stock rims.
~But not so far as to hinder the body. I run them myself with the jconcept hexes.
I dont have a pic at my office but will try and take one when I get home. I bought the slash wheels but it was my undestanding that all hex style wheels will now work on the SC10 with the conversion.
hey guys just a quick question on the sc10
I'm really on the fence here. I race Tc and wgt in the summer and 12 scale in the winter months.
there a big thing going on with short course truck in the area. and was curious how you guys like the sc10,
I'm on the fence for either 2 wheel drive or the 4x4.
I hear in 4x4 you need a 4 pole to be competitive. I was curious if my present electronics that i have from TC would work with a 2wd.
Also is there anything I should be careful if buying one and what is needed to be competitive. like upgrades or ???? thanks in advance
I love my factory team sc10, wouldnt buy anything else, havent broken a part yet.
No, different trucks need different offset wheels. After the hex conversion, you can run the SC10RS/SC104x4 wheels, wheels for the Losi SCTE, or the Proline wheels for the ProTrac conversion. The offset on the regular Slash wheels make it too wide.
