SC10 Thread
Old 12-23-2011 | 08:07 PM
  #8536
Jerm13's Avatar
Originally Posted by nadan805
The rules say you can use any stock tires. From what I have been reading, the losi SC truck has the nicest stock tires. Get the nice tires, F/R spring kits, shock oil, and a decent lipo (25c or higher discharge rate). This class is all about driving, you will not achieve any significant advantages with your truck setup.
Definetly the Losi Eclipse SC tire are the best "stock" tires. I have seen some pretty wild dremel jobs on Traxxas and other kit tires to help them at a track I run at but the Losi's kick there butts. They sell them seperate, so get a set of Losi's and a set of stock wheels for your ride and you will be one set up on the comp. Find a good comfortable set-up that works for you and you got no where to go but to the front!
Jerm13 is offline
Old 12-23-2011 | 08:37 PM
  #8537
Originally Posted by barry1me
Chris,
I mounted it right on the top of the battery holder.
Did you just use the stick on adhesive mount to the top of the battery strap?
Chris
ravencr is offline
Old 12-23-2011 | 09:55 PM
  #8538
Chris
Thats correct
barry1me is offline
Old 12-24-2011 | 04:06 PM
  #8539
Cain's Avatar
Tech Legend
Hey guys. I finally put my daughters SC10 back together that I picked up used.
Good electronics on it for a good price. Only real issue is that the gear diff looked a bit beat up and I can hear the gears clicking every so often when I test it out.
so my question is this, I am used to building ball diffs, and this has a gear diff. The plastic outer teeth that mesh with the rest of the transmission looks good however the internal gears did look warn.
Is it worth it to stick with the gear diff for kids usage or, should I just upgrade her to a ball diff since that is what I know. I know they say the gear diffs are supposed to be highly realiable and she will be using stock motor power.
If I do decide to go with a ball diff, other than the obivous ball diff setup (outdrives, gear, diff and thrust balls, etc) is there anything else I need to do to fit one of this in on a car that originally was using a gear diff?
Thanks again.
Cain is offline
Old 12-24-2011 | 04:10 PM
  #8540
SpraydbySprague's Avatar
From: Conducting aggressive board meetings at my local track
Thanks again.
Be sure to purchase the ball diff specifically made for the SC10
The SC10 uses a metric bearing on the diff out drives and the transmission case is slightly wider than the older B4/T4 case. The out drives are made to fit the SC10 gear box perfectly.
SpraydbySprague is offline
Old 12-24-2011 | 04:20 PM
  #8541
Cain's Avatar
Tech Legend
thanks for the info!
Cain is offline
Old 12-24-2011 | 06:00 PM
  #8542
brent701's Avatar
I would keep the gear diff if your kid is going to drive it. Just rebuild it.
The ball diff is nice juat lots more work
brent701 is offline
Old 12-24-2011 | 06:06 PM
  #8543
Cain's Avatar
Tech Legend
thanks for the info. Is there a part # for just the gears to replace? i see a rebuilt kit for all the internals, but need only the gears.
Cain is offline
Old 12-24-2011 | 07:47 PM
  #8544
Registered User
I would just get the rebuild kit instead of just replacing part of it that way you know it is all fresh
Ryno B4.1 is offline
Old 12-24-2011 | 07:50 PM
  #8545
brent701's Avatar
Gear diff rebuild kit #9829
brent701 is offline
Old 12-25-2011 | 10:17 AM
  #8546
Lake Ober's Avatar
Default Fellow SC10'ers... I NEED YOUR HELP!
Hello all! I am hoping that some of you in here can help answer some questions I have about the SC10. I have recently decided that I would like to start racing short course at my LHS, and have done lots of research on the best SC options... coming to the conclusion that I want to get an Associated 2wd SC10. However, I am going to be running in the "modded" class and don't know what my best option is.
I looked on eBay and found a new SC10 with no electronics for $190. Then, I went on Tower Hobbies and found a new 2wd SC10 brushed RTR model for $199. I plan on putting a Castle Creations motor/esc in it so I was planning on getting the roller... but for $10 extra I mine as well get the brushed RTR. But my question is, if I get the brushed SC10, can I just put the CC Sidewinder SV2 right into the brushed motors place... or am I going to need special brushless mounts? What do you guys think is the best route to go if I plan to put on my own motor, ESC, receiver, and servo?
One other question... if I were to buy a stock 2wd SC10 and plan to race it, what are some upgrades that you guys would recommend right off the bat? I know when it comes to my Traxxas Mini Erevo, there is a list of upgrades that EVERYONE recommends to newbs, so I didn't know if there was one for the SC10. Thanks for all of your help... I appreciate it!
Lake Ober is offline
Old 12-25-2011 | 10:28 AM
  #8547
Jerz616's Avatar
If you plan on putting your own ESC and motor in it I would just suggest buying the Factory Team kit. Its like 239.00 on tower hobbies. You will get all the upgrades you are asking about and a better truck. You get better shocks and all the little blue goodies that come with the FT kit. Just upgrading to the V2 shocks vs. the RTR is like $80 bucks by itself. And trust me you will definitely want the V2 shocks over the RTR. Just my .02 though.
Jerz616 is offline
Old 12-25-2011 | 10:43 AM
  #8548
Lake Ober's Avatar
Thanks for your help! Now that I take a look at the Factory Team kit, I agree it's a nice option. Do you know if the only difference between the RTR and the Factory Team Kit is the shocks? Also, I would assume the Factory Team Kit is setup for a brushless motor?
I plan on going the 2wd route because after talking to guys at my LHS, I was told that the 2wd version is cheaper and much more reliable. Do you think that the 4x4 is worth the repair time and cost that it is, or would you recommend the 2wd to? Thanks!
Old 12-25-2011 | 11:15 AM
  #8549
njnewc's Avatar
If Your Order Totals: YOU SAVE Use Ad#
$100.00 - $124.99 $15.00 016R1
$125.00 - $149.99 $20.00 016R2
$150.00 - $199.99 $25.00 016R3
$200.00 - $224.99 $30.00 016R4
$225.00 - $249.99 $35.00 016R5
$250.00 - $299.99 $40.00 016R6
$300.00 or more $50.00 016R7
Here are some codes for Tower Hobbies. Now your FT SC10 will be 210.00, or if you spend more than 300 you will get 50 bucks off... Merry Christmas... I completely agree you should get the FT truck... Comes with better shocks, battery strap, ball Diff, Carbon arms, shock towers, CVD's, more tuning options, JConcepts tires on the rear... All the pretty blue stuff, It's just a better truck... IMO... "Setup for Brushless"... There is no difference in the setup of the truck. But to get the full potential out of these newer trucks I would reccomend Brushless, I personally run Viper electronics, but there are a ton of options. I suggest going to your local track and see what everyone else is running. This way you will have help if you have some issues or if you need help with setup, gearing, etc...
Start off with 2WD... IMO...
njnewc is offline
Old 12-25-2011 | 11:31 AM
  #8550
Lake Ober's Avatar
I saw the codes that Tower has on their homepage, but these are even better! Are these codes that you get for being a member? Thanks a ton! I plan on ordering the truck tonight along with the RPM chassis brace kit, front and rear RPM a-arms..so these codes will definitely come in handy. Are there any other hop ups you'd recommend for me right off the bat? Maybe J Concept subcultures for the front, new rims, or a screw set? Thanks for all of your help guys, this is all quite helpful!
