Like Tree5Likes
SC10 4x4 Thread
Old 02-20-2012 | 06:01 PM
  #17896
Evil Genius jr.'s Avatar
Just ordered some saddles!!!!!!
Evil Genius jr. is offline
Old 02-20-2012 | 06:09 PM
  #17897
MantisWorx's Avatar
Originally Posted by Resqnu
Mantis, trying to learn what does each of these adjustments do:
3-3 block
1mm under rear camber link
1notch shorter on rear camber (don't understand)
3-3 block, gives increased on power steering and a little rear rotation on entry.
does stiffen the rear up though so its not great on super rough tracks.
1mm under camber link and shorter link both increase entry rotation but also give more traction on exit.
With the center dif you need to adjust your driving style slightly , you can enter the turns much more aggressive without the fear of the back coming around on exit.
MantisWorx is offline
Old 02-20-2012 | 06:11 PM
  #17898
hELllNino's Avatar
3-3 block
3-3 block - more anti squat in rear (thanks cameron kellog)
1mm under inner camber link ballstud - lowers roll center slightly to get more roll or "lean" in corners
shorter rear camber link - move ballstud on rear hub carrier in one hole, shortens camber link, makes camber change greater when rolling, keeping tire contact patch in corner on outside rear wheel flatter in relation to ground
hELllNino is offline
Old 02-20-2012 | 06:15 PM
  #17899
Cameron Kellogg's Avatar
3-3 block
Move the outer rear camber link to the inside hole on the rear hub. The 1mm goes under the inner camber link ball stud.
Cameron Kellogg is offline
Old 02-20-2012 | 06:17 PM
  #17900
Originally Posted by hELllNino
3-3 block - more toe in on rear, makes car turn quicker
3-3 is more anti-squat. The toe is the same for both blocks. 3 per side.
Old 02-20-2012 | 06:19 PM
  #17901
Resqnu's Avatar
Originally Posted by MantisWorx
3-3 block, 1mm under rear camber link, 1 notch shorter on the rear camber link. this allows you to rotate before the apex and will give you better drive on exit. I am now discovering that alot of this on power push is coming from the rotation of the motor........ more on this later.
Thanks guys, explained very well.
Resqnu is offline
Old 02-20-2012 | 06:27 PM
  #17902
hELllNino's Avatar
well, i feel kinda dumb now
Old 02-20-2012 | 06:33 PM
  #17903
Resqnu's Avatar
What does more or less anti-squat do? I'm searching but can't find why Im looking for.
Resqnu is offline
Old 02-20-2012 | 06:40 PM
  #17904
RahjahDat's Avatar
Default shocks
hey guys!!! i have a new factory team 4x4 kit and i wanted some opinions. First, i like the factory team shocks that came with the kit, but someone told me that the kyosho velvet shocks are better? first will they fit? and can someone confirm that they are better?
RahjahDat is offline
Old 02-20-2012 | 06:53 PM
  #17905
Not on the 4w. The FT shocks are fine. You might like the RCShox pistons though.
Old 02-20-2012 | 06:54 PM
  #17906
CoyoteSlash's Avatar
Originally Posted by Mizchief
If you can handle a slash 4x4 you should be fine, just get used to not needing as many spare parts
I never break anything on my Slash 4x4, other than "worn out" Drivelines. =P
Don't confuse "Factory Team" with "Team Kit"
Either way, everyone goes on and on about Kyosho shocks and Springs. My Factory team upgrades for the 4x4 are fantastic, rebuild fast and never leak. And they are silky smooth.
CoyoteSlash is offline
Old 02-20-2012 | 06:57 PM
  #17907
More anti-squat produces less rear traction on power by effectively increasing the rear spring rate in proportion to how much forward power is being applied.
The velvet shocks are better quality shocks compared to most, but they aren't big bore and that is more important with these heavy trucks.
Krio is offline
Old 02-20-2012 | 08:34 PM
  #17908
janga's Avatar
recently i bought my first rc.
i took the motor out for something and the next time i raced it was driving funny. i do not know where they came from or what they are but two peices had been wedged under the battery they looked like this
janga is offline
Old 02-20-2012 | 08:52 PM
  #17909
Those are from the outer CV joints. You are 3w drive right now.
  #17910
They're the CVA Pin and stud. Look at your Axle assembly on your manual, or the PFD on rc10.com and it'll be easy for ya.
Sc10 4x4 manual
