Like Tree5Likes
SC10 4x4 Thread
Old 02-03-2012 | 08:57 AM
  #16501
Originally Posted by Triple B
I have been searching all night and I can not find anying thing on the "cavs set up"
Wife bought me a RTR for X-Mas....put on a set of Bar Codes & sway bars and did my first race at WCRC last night. Had a lot of fun ended up 4th truck was very loose off the corners
Looking for a good starting point for Diff Fluids, Shock Fluids, Sway Bars, Spring Rates and Ride Hights for WCRC
I did feel like a loner.....The only SC10 4X4 in a gaggle of Losi
Bob
I run 30wt front and 27.5 rear for shock oil with FT yellow springs all around. Yellow front and white rear for sway bars. 24mm front and rear ride height. Since you have no slipper or diff mods I would run 30K front and 7K rear for the diffs. I would however suggest getting the center diff from Rcshox.com (what I run now and it is glorious). But if you're not ready for that upgrade I say at the least get the MacTheKnife clutch basket as it a huge improvement over the stock slipper configuration (ran that too). Add a chassis brace to help the belt skip.(I have a couple extra I could let you have for one for pittance.)
Try to read thru this thread there are a bunch of upgrade options you can run that the guys here have come up with that will greatly improve this truck
FYI you are not alone.
jamr1130 is offline
Old 02-03-2012 | 09:14 AM
  #16502
vito's Avatar
Originally Posted by Chris Jarosz
Unfortunately there won't be an upgrade kit.
Seeing as how they were just announced, I don't think you will see them for a few more weeks.
It was a ton of fun! Always my favorite race of the year!
thanks
vito is offline
Old 02-03-2012 | 09:29 AM
  #16503
IRM616's Avatar
just got my some new turnbuckle(blue aluminum) and ballstud. does anyone know how to read the numbers on it???or what order? does that mater? thanks
IRM616 is offline
Old 02-03-2012 | 09:38 AM
  #16504
It's got numbers on it? I didn't even know that. I just eyeballed it off the old turnbuckles and did it one at a time.
jamr1130 is offline
Old 02-03-2012 | 10:18 AM
  #16505
bajabro's Avatar
What exactly do you mean "the center diff"?
bajabro is offline
Old 02-03-2012 | 10:22 AM
  #16506
http://rcshox.com/shoxshop/catalog/p...products_id=58
Krio is offline
Old 02-03-2012 | 10:42 AM
  #16507
Cameron Kellogg's Avatar
Does not apply for assembly. They are all the same.
The numbers on the ball stud are just mold numbers. If they have a number over time that does not form right they can track it down to which one it is.
Cameron Kellogg is offline
Old 02-03-2012 | 10:46 AM
  #16508
johnbugman's Avatar
hey guys to run emulsion style shocks on the sc10 4x4 do you just cut the bladder out to a o ring?
johnbugman is offline
  #16509
johnbugman's Avatar
and are we leaving the bleeder screw out too?
Old 02-03-2012 | 10:48 AM
  #16510
FRONTI3R's Avatar
No... you remove the black rubber bladders and put them in your parts bin. You will need the screw in the shock cap for emulsion... or the oil would squirt out.
You should already have an o-ring on the shock body.
FRONTI3R is offline
Old 02-03-2012 | 10:49 AM
  #16511
Mizchief's Avatar
Originally Posted by Chad Smith
Anyone run these saddles?
http://www.hobbyking.com/hobbyking/s...ddle_Pack.html
Im curious to see how they fit inside of the b44 saddle tray, are they to tall?
I use the 5100 65c's and they fit perfect in the RcShox exotech inline mount.
Mizchief is offline
Old 02-03-2012 | 10:57 AM
  #16512
johnbugman's Avatar
just checked shock caps. there is no o rings inside.
Old 02-03-2012 | 11:03 AM
  #16513
vito's Avatar
my kit came with o rings for the caps in a small bag with the pistons
vito is offline
Old 02-03-2012 | 11:08 AM
  #16514
johnbugman's Avatar
ok let me check.. maybe i missed them in parts bin
Old 02-03-2012 | 11:09 AM
  #16515
johnbugman's Avatar
ah ha! found them! thanks guys. i heard you should leave bleeder caps out. is this bs or what?
