Like Tree5Likes
SC10 4x4 Thread
Old 01-28-2012 | 07:11 AM
  #15991
moto44's Avatar
Originally Posted by Misfit138
You want to do the saddle conversion and get a clutch basket from MTK or the center diff from RcShox.
I got the MTK clutch I was thinking that when jumping and being on the gas the clutch is grabbing causing the car to rotate to the right. Thats why I thought maybe the center diff would help.
moto44 is offline
Old 01-28-2012 | 07:17 AM
  #15992
Misfit138's Avatar
Then go with a saddle conversion. That is meant to balance out the truck.
Misfit138 is offline
Old 01-28-2012 | 07:21 AM
  #15993
Misfit138's Avatar
Originally Posted by tom2tone
I have a couple questions..
What gearing should I start with? Tekin pro4 4000kv and a MMP. Plus I just installed the MTK clutch basket and garodisc.
What sway bars should I start out with for front and rear?
Thanks in advance!
I'm running a 14t with my Pro4 4000kv with an RX8. Yellow sway in front and Blue in rear.
Old 01-28-2012 | 07:34 AM
  #15994
tom2tone's Avatar
I'm running a 14t with my Pro4 4000kv with an RX8. Blue sway in front and Yellow in rear.
Thank you sir! I'll try that and see what i think. I can't wait to get this build done and drive this baby!!
tom2tone is offline
Old 01-28-2012 | 08:00 AM
  #15995
Misfit138's Avatar
I do have my current limiter set at 50%. I don't know if that helps with the MMP. I'm also running SMC 5200mah 60c saddle packs if that helps you as well.
Old 01-28-2012 | 08:27 AM
  #15996
tom2tone's Avatar
I'll have to adjust the MMP and see what I can figure out. I do want to buy some new lipos for the truck. But thought I would try it "as is" for now and go from there. Thanks again for the help!!
tom2tone is offline
Old 01-28-2012 | 08:44 AM
  #15997
jsamarin's Avatar
i'm running 15/62 with my 4000kv, and for swaybars, you deffinatly want to run yellow in the front, and either blue or orange on the back. running the yellow on the front calms the steering down (which the truck needs)and helps with traction rolling and running a softer bar in the back gives you more on power grip in the rear end coming out of corners.
jsamarin is offline
Old 01-28-2012 | 08:45 AM
  #15998
Mizchief's Avatar
Originally Posted by MantisWorx
Thanx!! if your track isnt too rough try the 3-3 block it will give you better acceleration but you may have to change shock settings in the rear (soften up) to get it to act right.
I am working on V2 of the center dif, first part is being tested today. if all goes well you will get your acceleration back
What are you changing? or is that top secret
I was thinking about putting a slipper pad between the washer ring and the slipper plate to add a little more friction between the two metal parts.
Mizchief is offline
Old 01-28-2012 | 08:47 AM
  #15999
Mizchief's Avatar
I am running the stock set-up with the stick pack and I am noticing when I jump my truck it always seems to lean towards the right. Is this more of a balance issue where the dual batteries would help this or by going with the center diff would help this?
Mine did that to before going with the saddles. If you haven't already, fill the weight slots on the center chassis on the side opposite the battery to balance it out. When it happens on the track just punch the throttle while in the air to level the truck out.
Mizchief is offline
Old 01-28-2012 | 08:52 AM
  #16000
jsamarin's Avatar
does anyone know where you could buy a somewhat thin sheet of lead. Im wanting to cut a piece and mount in under my saddles to get some weight as low as possible. I think someone on here has done this a while back, but i cant remember who it was. Any feedback would be great
jsamarin is offline
Old 01-28-2012 | 08:59 AM
  #16001
Pro golf shops sell rolls of thin lead for golf clubs, that might work.
jnyrcr is offline
Old 01-28-2012 | 09:03 AM
  #16002
Wild Cherry's Avatar
Originally Posted by Mac The Knife
And that's what the clutch basket was designed for. With the standard slipper, if you set it for a dusty, or loamy track it would glaze the pads halfway through a heat and slip more. The spur would get hot enough to melt or warp from the heat generated by the slipper.
Sorry ,
if your slipper grazed & heated up like you just described?
You must of set it way to loose ...
Wild Cherry is offline
Old 01-28-2012 | 09:08 AM
  #16003
Lead roof flashing , thin and perfect for want your looking for ...
Old 01-28-2012 | 09:32 AM
  #16004
johnbugman's Avatar
Originally Posted by Cain
anyone got a recommendation where to purchase 4 scales for a good price?
I bought 4 food scales from walmart for 5 bucks a piece
johnbugman is offline
Old 01-28-2012 | 09:41 AM
  #16005
Posted this a few days ago with little response:
MMP and pro4 4600- should I run the MMP in full sensored mode of smartsense?
Thanks,
riverdog is offline
