JConcepts Thread
#4668
Mugen Eco
Curious if you have plans of releasing a Hi-Flow body for the Eco?
if so, when?
I'm a bit jealous of the nitro drivers
if so, when?
#4669
Well if you never had an issue mountin the wings to a Kyosho then you probably didn't put it on one. They line up great for he 44 and 4 but the rb5 mounts are wider and they are right on the crease so u have to bend them a little. I just wish they would have came with the punisher for the rb5 too instead of just the finnisher when the new kit came out.
#4670
Anyone have issues with the new J Concepts mono wheels? I bought 2 full sets of barcodes blue and green compound and decided to use these new wheels. I run a kyosho RB5 wc and and when I tried to install these the front wheels rubbed on the hub and would not spin freely and with the rear rims I was only able to see 2 threads of my axle. Not enough to secure the rim to the car. I am certain I purchased the correct rims JCI3348 and JCI3347. They say it will work with RB5 and B4 hex cars. $60 in tires glued to rims I can't use! waste!
#4671
dear jconcepts body design team,
on behalf of rally fans out there,
please make rally car bodies that would fit
4wd short course trucks using short course
wheels and tires. subaru hatchback or sedan
prefered of course... proline's version of a
rally body is a joke.
THANK YOU.
THANK YOU.
#4672
I asked this same question over on the B44.1 thread but figured I might get a quicker response here.
I'm working on a dirt oval project that is B44/B44.1 based and was curious to know if the front and rear driveshafts from the BJ4 are the same lengths as the B44/B44.1? JConcepts has an aluminum set and I'm trying to shave all of the weight I can, especially rotating weight.
#4673
#4674
Was wondering if any one has used the orange short course barcode? I ordered these from tower thinking they were just a step over supersoft.. thinking they might last a little longer. Tower listed them as soft.. http://www3.towerhobbies.com/cgi-bin...?&I=LXAGCE&P=7 but now I seen blue-softs released.. these gonna be garbage? Lol
#4675
Soon...Waiting on decals
They are actually considered soft, but they are a different rubber compound made for blue/black groove warm/hot surfaces. I can see how their description can be a little miss leading though.
Not at this time.
We have run these wheels on the RB5 while using the standard track width in the front. If you run the narrow setup in the front, the wheel will rub. We have run the rear wheel with great success, but you need to use a 4mm serrated wheel nut. Many companies make these including JConcepts .
Thank you
if so, when?
if so, when?
THANK YOU.
THANK YOU.
#4677
Here is a pic of the #0116 wing I mounted last week onto the new RB5 WC kit to confirm fitment on the newest kit. We have also just finished a new Hi-Clearance wing #0125 for the RB5 series cars that uses the same wing mounting locations.
#4678
sweet cant wait to run the new finisher body on my WC
#4679
Can't wait to order the 22T Punisher body and have Larry paint it up for me!
