RC10T4.1 Thread.
Old 01-22-2012 | 12:01 PM
  #286
Originally Posted by racer1812
IMO, if you can notice that flex, if there is any, you should be standing next to the Ryan's on the drivers stand.
Agreed. That's why I run the RPM ball cups. No difference in handling, huge difference in keeping me in the race when my truck clips a pipe or comes down wrong after big air.
Hinecken is offline
Old 01-22-2012 | 03:40 PM
  #287
What wheels should I use after I convert to 12mm hex fr and rr? Also I hear that the b4 front hex axles are going to allow for the same width overall? This true? Thx!
Hopper99 is offline
Old 01-22-2012 | 04:43 PM
  #288
Cain's Avatar
Good question. I know the old academy GV2T used hex wheels.
Maybe kyosho? They have a quick change wheel that appears to have a hex of some sort.
Cain is offline
Old 01-22-2012 | 06:08 PM
  #289
thecman26's Avatar
I got a set of TQ SX10T truck wheels for my hyper 10TT and those were 12mm hex with no quick change issues... Just good luck finding them anywhere. A-Main used to carry them, not any more.
thecman26 is offline
Old 01-22-2012 | 09:05 PM
  #290
I am the new owner of a T4.1 Brushless RTR that I got to have fun at the track with my Son when driving his slash. I am new to RC driving other than bashing with my sons slash.
Today was first day with it at the track and I probably spent more time wrenching on it than driving it. Broke 2 ball cup ends a rear arm and had a steering ball cup end come off twice. Yeah I know driver better
Question is what can I do to make it a little more forgiving for a new driver.?
I think RPM stuff all around might be in order until I get better. Any other suggested part changes or differences?
Is there anything else or any set up tips that make it easier to drive aside from going slow?
Thanks Eric
eric_rc is offline
Old 01-22-2012 | 10:54 PM
  #291
With all the trouble in finding hex wheels, why even bother?
Hinecken is offline
Old 01-22-2012 | 11:14 PM
  #292
Well if say the 22t or rt5 rims fit correctly it would be no trouble. If I have to search all over to find some rare obscure wheel then ofc I wouldn't convert.
Hopper99 is offline
Old 01-22-2012 | 11:54 PM
  #293
This portion of this post is a continuation of my prior post about the McMaster x-rings. I ran them for about 6 packs over a 2 week period. They definitely leak. Way more than the stock o-rings ever did. In addition, they have a small initial stick. I will not be using them again. I also bought the o-rings made of the same material (75 durometer fluoroelastomer). They stuck to the shaft so much that I didn't even bother to try them. My next order from McMaster is going to be for red silicone o-rings that SHOULD be a direct replacement for the stockers.
Next up is a continuation of my pic from last night. I noticed that the aluminum pivot balls seem to wear and get sloppy after a while. RPM makes delirin pivot balls, so I figured I'd give them a try and am quite happy with the results. A little mod to the lower front pivot balls to eliminate the flange and they're awesome! I left the flange on the rears as it provides just enough clearance to keep the springs from rubbing the turnbuckle. I also dremel'd the shock caps so I could use these as well (which is what was shown in the pic last night.
Tonight I decided to rebuild my shocks. I'm no shock rebuilding expert by ANY stretch. Therefore, I could never achieve 0 rebound (my desired amount). I always had some, albeit a small amount. And, if I'm going do a rebuild, why not try out the vcs2 upgrade kit. :-) This rebuild kit converts the shocks to bladder type. After grinding the eyes to fit the delrin pivot balls and drilling a vent hole, I assembled one. Wow! It took 0 effort to achieve 0 rebound. Also, they shocks feel WAY smoother to me. It's a pretty unbelievable transformation as far as I'm concerned. I don't think I'll ever go back to emulsion style. The following is a pic of my new frontend.
ufoDziner is offline
Old 01-23-2012 | 12:01 AM
  #294
thecman26's Avatar
Oh yeah I forgot about the 22T wheels, they should be good! RT5 rims would be a lil more difficult.
Old 01-23-2012 | 06:14 AM
  #295
has anybody ever tried adding a little clay inside the rear wheels to make the car more responsive to throttle or brake input while flying in the air?
JungleGeo is offline
Old 01-23-2012 | 07:30 AM
  #296
Cain's Avatar
So you are in essence wanting more weight on the wheels?
Only time I have seen people add clay was to balance the wheel. But I don't see why the concept wouldn't work.
As for the benefits of using hex wheels, etc. other than not having to make sure you line up the pins perfectly, being able to rotate the tires front and rear if you run on tracks where treaded fronts are the hot ticket would be a plus.
Cain is offline
Old 01-23-2012 | 07:48 AM
  #297
SirKarnage's Avatar
Thats why I did it. But I still use the JConcepts T4 Rear wheels on all 4 corners, the pins are ok (they work) - and there is not slop as with the QC setup. I would much prefer hexes all around, but havent found the right wheels yet. (yes, looks do count sometimes too!)
SirKarnage is offline
Old 01-23-2012 | 07:53 AM
  #298
Cain's Avatar
what are you using for rims?
The T4.1 I will be using will have the quick change wheel setup all around. Looking forward to seeing how well that works out and how quickly you can actually change the wheels.
Cain is offline
Old 01-23-2012 | 08:04 AM
  #299
I would imagine that would only increase the unsprung weight and lesson the suspensions responsiveness. The clay would also have to be perfectly balanced so it wouldn't cause wobble.
Hinecken is offline
Old 01-23-2012 | 08:10 AM
  #300
Timmahhh's Avatar
Agree. Xfactory has a slipper flywheel that would do the same thing without adding unsprung weight. Its intended to have the opposite effect on a 4 gear trans, but on a stock 3 gear it would have the effect you're looking for. Just be careful because it will probably reduce throttle response a bit and make your truck a wheelie monster.
Timmahhh is offline
