RC10B4.1 FT/WC
Old 01-14-2012 | 11:22 PM
  #9781
Registered User
Originally Posted by Jake S
maifield running some interesting stuff
kyosho pink / kyosho gold springs.
25c reedy lipo.
really nice aluminum rack!
Those are Losi not Kyosho springs correct???
Ryno B4.1 is offline
Old 01-14-2012 | 11:44 PM
  #9782
idrummerboy13's Avatar
Default recent pic
I am actually thinking about drilling a hole in the chassis the way ryan does, much nicer,also will throw the transponder in front of the servo.
It looks funny on top
I like my glued servo savor
That battery will be in my kit once I can get the shop to order, Ill pick between the short packs or that wolf pack. I think my kit can move faster in the tight sections with that battery, All the fast guys here switched over to it..to bad reedy is out
idrummerboy13 is offline
Old 01-15-2012 | 12:12 AM
  #9783
Eric Thompson 2's Avatar
What rear hubs is Maifield running in that pic?
Eric Thompson 2 is offline
Old 01-15-2012 | 12:28 AM
  #9784
pink_sleeve's Avatar
Those are Kyosho springs. Losi doesn't offer a pink front or a gold rear. Also you can tell by where the color marks are located. Kyosho marks there springs 1 coil down where losi marks there springs on the very end coil.
pink_sleeve is offline
Old 01-15-2012 | 12:31 AM
  #9785
Zero degree factory team hubs. I'm pretty sure that the carbon piece is not the C plate though. I think it's the same as the A but made out of carbon fiber. I can ask him tomorrow when i go down to the rcfactory where they are running at to be sure.
Old 01-15-2012 | 12:40 AM
  #9786
patiofurniture's Avatar
We actually just got the shorty pack back in stock! So order now, because they are going fast!
patiofurniture is offline
Old 01-15-2012 | 01:27 AM
  #9787
Please do. I was wondering about that carbon piece.
Old 01-15-2012 | 01:30 AM
  #9788
SoccerSting's Avatar
Will the rpm front chassis brace for the SC10 work on the b4.1?
SoccerSting is offline
Old 01-15-2012 | 01:56 AM
  #9789
mellow's Avatar
+1 ask him everything you can!
mellow is offline
Old 01-15-2012 | 03:17 AM
  #9790
Originally Posted by DaveW
The larger rotor gives you less of a useable powerband. Its definitely punchy, and brakes come on harder (drag and push). I went back to the standard rotor and worked on my speedo settings...
*EDIT*
I wanted to add to that i was using the Works 13.0mm rotor. There are two 13.0mm rotors...
I'm going from the standard 12.5 down to the 12.0mm I understand what it's supposed to do, was just wondering if anyone else tried it and had thoughts on it
Track today is going to be so loose (brand new layout, no groove yet) so it's going to be hard to really put any power down yet.
Bob Barry is offline
Old 01-15-2012 | 06:44 AM
  #9791
Oh thank god you read this thread lol
ill be getting 2
Old 01-15-2012 | 08:20 AM
  #9792
Actually you'll want the 80430. There is a long thread on here about 2-stage pistons that got me intrigued. Initially I ran a different brand and was happy with the performance, but not with the fit, so I switched to the RPMs. I'm running a T4.1, and use the red pistons with 25wt front and rear. When our local "fast guy" drove my truck (per my request to see if it felt like it pushed to much to him) he kept asking my about my suspension because of the feel. He's running a b4.1 with reds and 30wt now. I'm not sure if he has run any lighter weights for testing or not. 30wt felt to heavy to me, as my truck would bounce down the rougher parts of the track (just like it did with the stock AE pistons and 30wt). With my current setup, the chassis stays level and the suspension works it's butt of in the rough areas. So, my opinion is that the real advantage with the 2-stage pistons is when the track gets rough, my lap times stay more consistent whereas the others slow a little more due to the bouncing. When the track is smooth, there appears to be little to no advantage as I see it.
Do they last forever? Not sure yet. They appear to be made from the same material that RPM uses for everything. Based on that, they probably will last a LONG time.
What kind of washer setup do you use at the shock body bottom? Are you talking about the spacers for limiting? I run the stock numbers and am happy with the results thus far. However, I haven't done any testing in this area.
Can you safely go with some pretty stiff springs using these? If you want to, I don't see why not. I tried silvers in the rear because my truck is a little heavier in the rear due to an oversize aftermarket wing, but I ended up going back to green.
LMK if I can answer/clarify anything or help in any way.
Originally Posted by jf+
You the man... when I finally looked those up (RPM part no.80420) they look like a good approximation of what I'm talking about. So, go on, is everything great with these? Do they last forever? What kind of washer setup do you use at the shock body bottom? Can you safely go with some pretty stiff springs using these? Details, please! (as you can tell, pretty excited about the idea of these things, just wondering about the execution)
ufoDziner is offline
Old 01-15-2012 | 08:59 AM
  #9793
DaveW's Avatar
Comin from TC (AWD with far more grip than most dirt tracks) i never needed the 12.0mm. But if going from the 12.5 to the 12.0 is anything like going from a 13.0 to the 12.5... id say you will like it a lot on a slippery surface. Both of us made a step down in rotor size for traction/control.
With the Tekin RS i had to add 6-8 more boost on the 12.5 compared to the 13.0, and the 12.5 was far easier to throttle. The trigger felt more in the middle than the top 1/3rd with the 13.0.
DaveW is offline
Old 01-15-2012 | 09:57 AM
  #9794
Wild Cherry's Avatar
Buying two ....
Wild Cherry is offline
Old 01-15-2012 | 10:17 AM
  #9795
If I didn't just drop 500 bucks on 4 new batteries a few months ago I'd think about trying them as well.
nhraman is offline
