RC10B4.1 FT/WC
#8926
I have everything on that list except the slipper plate. How much of a difference does the vented slipper plate make? I figured just another gimic LOL
#8928
My Novak has a cap on it and my buggy runs just fine with a Savox servo. my MMP needs a glitch buster or the CC BEC. I have used both, both had the same end result. No more glitching.
#8929
#8930
my tekin RS speedos have a cap also but 2 out of the 4 tekins i have needed an additional receiver cap to prevent motor cogging at low speeds.
#8931
Thanks guys for the info
#8932
#8933
Although I highlighted the most important thing here. I agree.....but someone should make it blue
#8934
I am running the vented hub on the outer side and I can't really tell if it is doing anything but looking cool. lol I run my slipper tight like you.
#8935
they seem to have a little more side bite than I do so I might change things a little.
#8936
What pad you using? lol
#8938
Kot.....oh those.
currently the newer gold pads, color changed a little while back. Not sure if there was a reason or a big difference.
I have tried the HD pads in my buggy, they work fine but are a little touchy to get adjusted. I like them in my T4 though.
currently the newer gold pads, color changed a little while back. Not sure if there was a reason or a big difference.I have tried the HD pads in my buggy, they work fine but are a little touchy to get adjusted. I like them in my T4 though.
#8940
I was told that you were just supposed to do something to the white pads every 2 or so runs to make it smooth or something, not really sure, but with the gold ones you don't need to, so Ive been told, so that's why I use the gold ones
