The Speed Passion Thread >
Like Tree57Likes
Old 12-25-2011 | 04:17 PM
  #8566
Originally Posted by TeamWTF
Hey All,
Just put an order in for a V3 1cell (Been wanting to try one for a while - Because they are so light)
I race 17.5 open TC and was wondering how will this motor differ from a regular V3? I see it has a lower KV so I will start with adding a tooth or two... Other then that any suggestions?
Which reminds me, I read on here that the 1 cell had a higher KV... I just looked at the manual online and its much lower... Which is correct?
Cheers
Phill
I have been running the 1cell 17.5 for a while now in the no timing class with the 20+ board in it. I'm actually gearing it 2 teeth less then my v3 with the 20+ board. Timing on the motor set to 30. 1cell is also running cooler then the v3.
SRW141 is offline
Old 12-26-2011 | 02:38 AM
  #8567
andyw2's Avatar
Default SP 17.5r comp v3 versus ultra stock
Can anyone tell me the performance difference between v3 17.5t competition motor with zero timing and the specific v3 ultra stock motor.
andyw2 is offline
Old 12-26-2011 | 04:40 AM
  #8568
azz187's Avatar
Just downloaded the new Reventon app! So when will the new esc hit the shops?? Can't wait...
azz187 is offline
Old 12-26-2011 | 11:09 AM
  #8569
morgoth's Avatar
Hey guys,
I just bought a 10.5T Speed Passion V3 for my Xray T3. I started with onroad racing 2 months ago and a 17.5T boosted Speed Passion motor since that's the class most guys run. After 2 months I'm the fastest guy at the track that runs 17.5T so it isn't really exciting for me anymore (and 17.5T doesn't have enough bottom end imo, it's way to easy to drive for me).
I'm looking for a good starting FDR for indoor. The track is about 14m*30m. The other tracks I drive on are about the same. (Currently, I drive with a FDR of 6.4 on our track with a 17.5T boosted motor and it's pretty close I think.)
morgoth is offline
Old 12-27-2011 | 01:13 AM
  #8570
KELVIN KHNG's Avatar
Default Reventon on sale already?
Solara
Is the new esc available in the states already? If not when can we get our hands on it?
KELVIN KHNG is offline
Old 12-27-2011 | 04:09 AM
  #8571
Ooj
Anyone got a boosted 1/10 touring set up for the 4.5 MMM? Would it be similar to the Marc Rheinard ETS v3 4.0 boosted setup from ETS but reduce all the timing by about 10 degrees to account for MMM's extra timing?
Ooj is offline
Old 12-27-2011 | 07:52 AM
  #8572
Cain's Avatar
Originally Posted by Cain
I got my programmer lcd professional box in.
Pretty much using this on my daughters vehicle so I don't need the latest and fastest setups so my question is this,
I noticed with the latest software it says you cannot use any of the onboard or older regular card setting items. Is this permanent if I choose to switch back to an older firmware?
Also, for firmware 1.33 I see two versions available under the speed passion 2.0 GT LPF ESC download list but one of them says its for the GT2.1 only?
What firmwares that are available can work with the Speed Passion 2.0 LPF ESC?
For the programmer box itself, if I update it to the latest firmware can you still access all the old firmwares that the ESCs need?
What stock ESC firmware other than the current one works well?
anyone?
Cain is offline
Old 12-27-2011 | 09:42 AM
  #8573
V3 will always be better if you are comparing to the ultra sportsman....the ultra sportsman is design for hand out motor class.
Solara is offline
Old 12-27-2011 | 09:43 AM
  #8574
Originally Posted by KELVIN KHNG
Solara
No..not yet, I am hoping middle JAN for the S and R version. PRO will be after MARCH....
Solara is offline
Old 12-27-2011 | 09:45 AM
  #8575
I think that will be a good starting setup....less timing is always better to start if you are not sure what to start.
Solara is offline
Old 12-27-2011 | 09:46 AM
  #8576
I saw the add on radiocontrolzone for the new speedo.
My question is this, what SCT was that in the background? Mid motor design with saddle lipos down the middle?
Speed Passion new 2WD SCT = Ananta 2WD SCT....coming FEB 2012.
Solara is offline
Old 12-27-2011 | 09:51 AM
  #8577
anyone?
OK...I assumed you download this file already. Then unzipped and installed on WINDOW and setup the interface for SP ESC.
http://www.speedpassion.net/uploadfi...30GT110323.zip
Update the LCD card with the latest software, please see this video
+ YouTube Video
This software, will work on all GT series ESC...2.0 and 2.1 both...does not matter which one, both works. It will NOT work with the older V1 or V1.1. It will not work with the new REVENTON one.
And now...once you have the software uploaded to the ESC, you can always change to other software that you prefer to have...for example, you can load NO TIMING 508...then load 205 for mod, then load 323stock for open stock or 119 mod for boost mod...then back to 508...you can always change software.
I hope I answered your question...
Solara is offline
Old 12-27-2011 | 10:17 AM
  #8578
What is the difference between 119 and 323 ?
i actually run the 323 with an x12 4.5 octawind, and it s realy smooth.
If i switch on the 119, what can i expect ? Is it wotk with boost/turbo like the 323 ?
or is it like old software with supercharger 1-2-3-4-5-6 etc... value
Manson is offline
Old 12-27-2011 | 10:38 AM
  #8579
Cain's Avatar
+ YouTube Video
Thanks. I'll give that look tonight. I was just concerned that updating to the latest stock software on the ESC was something you couldn't back out based on how the instructions were worded to me at least. This is for my 8 year old daughter so I want something I can tune if needed with boost (classes here are just full mod), but wasn't ridiculous. right now I believe its 205 mod on the ESC.
Cain is offline
Old 12-27-2011 | 11:30 AM
  #8580
jgraham37128's Avatar
How does this motor compare to the DUO 3 or RevTech 17.5? Has anyone used one with the optional ring for the 30-50 timing?
jgraham37128 is offline
