RC10B4.1 FT/WC
Old 12-23-2011 | 08:11 PM
  #8791
SourDieselX's Avatar
is the +8mm chassis worth the extra cost? could someone kindly educate me a bit in regards to the +8mm chassis? this will be my first jump back into 1/10 scale 2wd buggy in over 10 years, lol. could use all the help possible!
SourDieselX is offline
Old 12-23-2011 | 08:14 PM
  #8792
YankeeFan123's Avatar
Overall more stability especially into corners and sweepers. It is worth the extra cost IMPO and I really like mine
YankeeFan123 is offline
Old 12-23-2011 | 08:25 PM
  #8793
B4TravSC10's Avatar
+1, I like the 8mm
B4TravSC10 is offline
Old 12-23-2011 | 09:40 PM
  #8794
I never drove the car without the +8 so I can't compare, but my car is very easy to drive and I'm sure in the right hands, or eventually mine with more practice, it's quite fast too.
Oh and Angelo, I'm not gluing my servo saver....... NO WAY lol. I hit too much stuff right now
Bob Barry is offline
Old 12-23-2011 | 10:00 PM
  #8795
Alright, so I've seen a couple different options as far as the +8mm chassis, the regular one and an aluminum one, what would be recommended? My SC I upgraded to an billet chassis due to the fact that the truck was to light, how do our buggies hold?
Old 12-23-2011 | 10:12 PM
  #8796
T-BirdJunkie's Avatar
With a fullsize servo, shorty pack, and no extra weight ThunderbirdJunkie is at 1485g RTR, body and all.
That's 14g underweight. ROAR and IFMAR state 1499g min weight.
T-BirdJunkie is offline
Old 12-23-2011 | 10:24 PM
  #8797
Are you guys running diff fluid in your FT T4.1s? If so, what weight? My local track is high bite clay, so i'm going to try 5k first.
GatorsUF is offline
Old 12-24-2011 | 12:59 AM
  #8798
Wild Cherry's Avatar
Default B4.1 V2 Shock Tuning Tip
I know , posted it already before ...
wish to repeat
Of all the good tuning suggestions I have told you guys to try ?
The switch to the standard white shock bushing instead of the black on the V2 shock really improves the cars performance.
Its now officially a
Must do
when rebuilding your shocks on your B4.1 ride....
Attached Thumbnails RC10B4.1 FT/WC-standard-shock-rebuild-kit-7440.jpg
Wild Cherry is offline
Old 12-24-2011 | 02:12 AM
  #8799
gdbracing's Avatar
do they sell these white thingys on amain?
gdbracing is offline
Old 12-24-2011 | 07:16 AM
  #8800
brent701's Avatar
try 3k diff fluid and 2 gears.
or 3k and 4 gears
The weight will change if you run only 2 gears
brent701 is offline
Old 12-24-2011 | 07:17 AM
  #8801
brent701's Avatar
wish to repeat
Must do
Standard white shock bushings? I don't have those on my shocks.
I have a spacer in between the 2 o-rings and small limiters. those white things in that pic aren't on my shocks.
brent701 is offline
Old 12-24-2011 | 07:58 AM
  #8802
Jerz616's Avatar
Jerz616 is offline
Old 12-24-2011 | 08:16 AM
  #8803
Cappy's Avatar
http://www.amainhobbies.com/product_...-Rebuild-Kit-4
Cappy is offline
Old 12-24-2011 | 08:31 AM
  #8804
8mm chassis (A must have)
rear ballast weight and other weights placed in chassis (A must have)
Kyosho velvet shocks (In my opinion the best upgrade I've done to the car)
I run associated springs, lower eyes, and new style spring cups on them.
Glued servo saver (A great cheap upgrade)
B-Fast diff balls and ring kit (works awesome)
0.0 rear aluminum hub blocks
This is just a few things I've done to my car to (IMO) make it better
nhraman is offline
Old 12-24-2011 | 09:59 AM
  #8805
SoccerSting's Avatar
Has anyone gone from Barcodes to Scrubs on the front of a b4.1 and is there a noticeable difference? Or which ones are better?
SoccerSting is offline
