NEW HOBBYWING STOCK SUPERCHARGED SOFTWARE >
Like Tree4Likes
Old 12-23-2011 | 09:54 AM
  #7306
Fabricio's Avatar
Just tried the 930, seem to me that it didn't make too much difference at all.
Will test on the track again, but giving it some air acceleration seems the same.
Hope on the track it shows some difference.
Fabricio is offline
Old 12-23-2011 | 09:59 AM
  #7307
What settings are you using on the ESC? Turbo Slope, RPM, etc, And whats your FDR.
You need to post as much information as possible before anyone can give you an educated guess on setup.
Cheers,
Shawn.
Shawn68z is offline
Old 12-23-2011 | 10:00 AM
  #7308
No, I didn't, but should have worked with 119, at least that is what I think.
Will try, got nothing to lose.
Fabricio, post what settings you were running with 119. I, along with a lot of other driver in our club use it in 10.5 and it is very fast.
scoyle is offline
Old 12-23-2011 | 10:01 AM
  #7309
Originally Posted by Benzaah
Like many big kids at Christmas i have Santa's money burning a hole in my pocket. Unfortunately for HW an Orion R10 pro is coming my way but at least hobbywing made some money out of me OEM style instead of all of it as i would have preferred to be bolting in a new V3.
Everyone can rest assured now that i have made this purchase the new V3 will be released shortly
Im with you on this! I was waiting for the V3, but our big indoor race is coming in 2 weeks, so I broke down and bought another 120A 1S. Turns out it didnt make the wife happy, buying to many things for myself near Xmas!
Happy Holidays,
Shawn.
Shawn68z is offline
Old 12-23-2011 | 10:11 AM
  #7310
Fabricio's Avatar
Cheers,
Shawn.
Shawn, below is the speedo setup, I upgraded it to the 930, didn't changed anything on it.
Here it goes:
1 Running mode: For/Brake
2 Drag brake: 0%
3 Voltage prot: 3.0V/Cell
4 DRRS Punch: Level 9
5 Brake force: 50%
6 Reverse force: 25%
7 Initial brake: 0%
8 Neutral range: 6%
9 Boost timing: 36
10 Turbo slope: 18
11 Overheat prot: Enable
12 Turbo timing: 24
13 Start RPM: 4000
14 Turbo delay: 0,3 sec
15 Timing ACC 350
Fabricio is offline
Old 12-23-2011 | 10:12 AM
  #7311
Fabricio's Avatar
Scoyle, just changed it to the 930, to make an attempt, but just posted the setup fo the speedo the way I uploaded it is.
Fabricio is offline
Old 12-23-2011 | 10:16 AM
  #7312
Fabricio's Avatar
Funny thing is, just turned it on now and shows
"Hobbywing"
V1.07_110119
Them when I press ok it shows the esc version that is the 930, is it normal?
Another thing is that I am using the SP Pro LCD, is that a problem?
Fabricio is offline
Old 12-23-2011 | 11:13 AM
  #7313
EpuL Leman's Avatar
"Hobbywing"
V1.07_110119
dear fabricio,
i think the V1.07_110119 is the LCD programming card version. you could also upgrade the programming card to V1.08XXX from the hobbywing USB link 1.64
the ESC version yes is the XXX930 version.
i think it's a normal
EpuL Leman is offline
Old 12-23-2011 | 11:28 AM
  #7314
Default Where have all the Hobbywing download sites gone?
Hi,
I recently have been running my Extreme Stock ESC in blinky mode.
I want to start running in advancing mode and have spent some time today trying to find the download link for it.
I've tried several of the links posted here but they all return the browser code 504.
Can anyone post a working link for me.
Also since I am moving from blinky can someone suggest settings that are faster but gentle.
Thanks in advance
donwhit is offline
Old 12-23-2011 | 12:24 PM
  #7315
EpuL Leman's Avatar
Originally Posted by donwhit
Hi,
Thanks in advance
here you go..
http://www.hobbywing.com/upload/soft....64_111011.rar
Old 12-23-2011 | 12:51 PM
  #7316
toydrifta's Avatar
Originally Posted by scoop
What was the heat like on the motor? The fdr seams high. I would go down to nearer 6.5 or 7? Now familiar with your car though.
Thanks for reply Mate
Temp around F131 guess its okay
I will be gearing down to 6.4 at least
i went to the local cycling track this morning
just to bash around gps strapped on 82.5 km/h
top end on a very short straight incredible
toydrifta is offline
Old 12-23-2011 | 01:52 PM
  #7317
Here it goes:
2 Drag brake: 0%
5 Brake force: 50%
7 Initial brake: 0%
8 Neutral range: 6%
9 Boost timing: 36
10 Turbo slope: 18
12 Turbo timing: 24
13 Start RPM: 4000
15 Timing ACC 350
I am assuming you are running an FDR around 7.0-7.5 ? I would bring your Boost in at a higher RPM, 8000-10,000, and bring it in ait quicker 300rpm/step. You can bump the boost up alittle more, to 40.
Other than that. I cant see a problem there. Could be gearing, you mentioned you have a hobbywing motor? Maybe someone can chime in, but I have never run one before, but I have heard they like to Rev. So, maybe FDR towards the 8 range.
Shawn.
Shawn68z is offline
Old 12-23-2011 | 01:57 PM
  #7318
M7H's Avatar
M7H
Try disconnecting and reconnecting the sensor cable, and see if that changes anything in the rpm from the motor while testing in the air......
If not, I would replace the cable.....
M7H is offline
Old 12-23-2011 | 02:51 PM
  #7319
COBRARACING's Avatar
http://www.hobbywing.com/index.asp
our new website .Please give us some feedback on the website and if there is anything different you would like to see or any different fucntions you would like implemented .
COBRARACING is offline
Old 12-23-2011 | 03:07 PM
  #7320
Originally Posted by InCaRnAtE
Here it is
Hardware Version 427_V1.0
Software V3.0_11090_MOD
Running Mode - Forward Only with Brake
Drag Brake Force - 10%
Low Voltage Cut-Off - 3.0V/Cell
"DDRS" Start Mode - Level 7
Maximum Brake Force - 100%
Maximum Reverse Force - 10% no idea why because it's a forward only
Initial Brake Force - 0%
Neutral Range - 6% Narrow
Boost Timing - 0 deg
Turbo Open Time - 24 deg/0.1 sec
Over-Heat Protection - Enable
Turbo Timing - 10 deg
Boost Start RPM - 1000 rpm this one is greyed out and non adjustable
Turbo Open Delay - 0.4 sec
Boost Timing ACC - 50 rpm/deg this one is also greyed out and non adjustable
Sorry for not replying sooner but I was away.
This is a Speed Passion software, I would recommend to load the HW software on your 2in1 box then the HW ESC software and take the set-up from there.
olly986 is offline
