RC10B4.1 FT/WC
#8688
I have been using barcodes front and rear but since I have been gone for so long, I was just seeing what else is out there.
And are you sure that you are starting with slicks and going to pins later??? I would think it would be the other way around. Pins until a groove and then the slicks once its grooved. and btw, i hate slicks LOL.
#8689
Just bought a B4.1 and was curious about the hex conversion. Tried searching through the thread, but it comes up with a lot of non relevant posts.
Parts I'll need are:
sc10rs steering blocks
b4.1 hex front axle
clamp on hex front and rear
22 rear wheels and RB5 front wheels.
Is this correct? How about the bearings in the front? Does it use the same bearings as before? And is there a crush tube in there?
Sorry for the repeat of this question for the one thousandth time I'm sure.
b4.1 hex front axle
#8690
#8691
From: Conducting aggressive board meetings at my local track
We run green.
Just say green, Bob.
He's easily confused. We're running green.
I SAID GREEN!!!!
I SAID GREEN!!!!
#8692
LOL I see what you did.... you didnt read the entire thing and thought that was one question :P
naa what I was saying is originally I was curious as if there was any other tires that resembled a taper pin for the rear. The first part of my reply was basically that I hadn't really looked at much out there because we had only been running barcodes.
The OTHER part was an reference to motorama and me being surprised that you would start out running slicks and go to a pin later
LOL
Now that I confused everyone everywhere LOL........
Oh and we run golds Chris...... :P
LOL
#8693
LOL
LOL
I also dont understand y pink bk bars work, green v2 barcodes dont!? they make u feel like your on ice
#8694
LOL
LOL
#8695
Oh yes Panther Swith 2.0's!!! Good thinking!!!
#8696
I run on a very tight indoor track (68x40) which has med/high grip. Typically run BK bar/Barcodes. Just got back into truck, so I'm still trying to find a setup. I posted a few pages back, in hopes of getting some setups from the AE guys who watch this site, but no luck.
Go Pack!
Go Pack!
I need to change the gearing for a little more top end and a less low end, I can barely touch the throttle. Not sure what size to go with.
Brakes are insane, even with the setting on the Transmitter all the way down, wheels still lock right up.
Also, not sure what fluid to put in the gear diff, it unloads at the slightest mention of a bump or turn.
#8697
Losi tires were always inconsistent..... one batch awesome, one batch horrible
#8698
b4.1 hex front axle
b4.1 hex front axle
Items to do the hex conversion:
ASC9880 - Team Associated Hex Steering Block Set
ASC9881 - Team Associated Hex Front Axle Set
ASC3977 - 3/16 x 3/8 normal wheel bearings (4 pcs)
ASC6943 - 8/32 wheel nuts (I like the JCI2076 or JCI2075)
12mm hex adapters
PRO6077-00 and PRO6076-00 or JCI2081 and JCI2091 or ASC7497 (plastic)
Hex front wheels
PRO2735-02, PRO2734-04 or ASC9690, ASC9691
Hex rear wheels
PRO2736-02, PRO2736-04 or TLR7100, TLR7101
I didnt list JConcepts wheels as they are not current in stock at Amain and I haven't personally messed with the Kyosho wheels... but they should fit.
#8699
Registered User
No crush tube is used, due to the C clip used as the bearing stop
12mm hex adapters
Hex front wheels
Hex rear wheels
12mm hex adapters
Hex front wheels
Hex rear wheels
